Syph007 · 6035 · 1299000
us Offline Monrogue
  • Wooooo!
Reply #3570 on: February 28, 2016, 12:27:25 AM
Classy looking  :cheers:
+1
K-Tibbs
se Offline Fortytwo
Reply #3571 on: February 28, 2016, 05:58:52 PM
Any chance of doing the mag glass in stainless??
Some of the cheap knock-offs do this already, you should be able to get one cheap and see if you could transplant it.
us Offline tattoosteve99
Reply #3572 on: February 28, 2016, 07:01:33 PM
Tried that. Doesn't work.
se Offline Fortytwo
Reply #3573 on: February 28, 2016, 07:40:44 PM
Ah, ok, that's too bad.
ca Offline Syph007
  • SAK Surgeon
Reply #3574 on: February 28, 2016, 08:41:41 PM
The best option for a silver mag glass woudl be to make one of nickel silver.  If you use non heat treated steel its going to not be smooth at all, and heat treating is a pain.  Brass and or nickel silver slide like butter though on SAK backsprings.   :tu:
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #3575 on: February 28, 2016, 08:46:51 PM
Ok. Make some nickel silver :pok:
ca Offline Syph007
  • SAK Surgeon
Reply #3576 on: February 28, 2016, 09:08:28 PM
Reply #3577 on: February 28, 2016, 09:11:33 PM
ca Offline Syph007
  • SAK Surgeon
Reply #3578 on: February 29, 2016, 03:06:52 AM
A fellow Canadian posted a video of his favorite instagram members... This guy's stuff looks familiar... :D
Once I the Tormach in I'm hitting youtube with a bunch of video content.  I keep meaning to do it but its something Ive been feeling guilty about not making use of.
At 18:45 :D
« Last Edit: February 29, 2016, 03:11:40 AM by Syph007 »
us Offline captain spaulding
Reply #3579 on: February 29, 2016, 03:12:29 AM
Awesome!  :tu:
I'm the milk man!
us Offline sLaughterMed
Reply #3580 on: February 29, 2016, 04:20:47 AM
At 18:45 :D
Nothing like free advertising :2tu:
Laughter is the best Medicine
ca Offline Syph007
  • SAK Surgeon
Reply #3581 on: March 01, 2016, 05:12:44 PM
The bladeless ones are for sure growing in popularity.  :D
us Offline OHIO
Reply #3582 on: March 02, 2016, 08:35:03 PM
I've read up to page 30 and I'm curious as to what the liners are made of. Specifically the colored ones.
Just ordered some pivots and flat heads.  First project is going to be a solo.
I work in aerospace and have quite a bit of titanium at my disposal. Once you shape your scales do you heat treat them?
ca Offline Syph007
  • SAK Surgeon
Reply #3583 on: March 02, 2016, 08:39:35 PM
Just a straight up conversion of an electrician today.
ca Offline Syph007
  • SAK Surgeon
Reply #3584 on: March 02, 2016, 08:44:10 PM
I was anodizing aluminum liners to get some colors but those dont last super long and will chip eventually.  I mostly just stick to bare metals now, brass and nickel silver.
Ti liners you can anodize a few colors but again the problem of durability as the oxide coating is pretty thin.
No need to add any heat to Ti alloys for my purposes.  You actually want to avoid heat as it significantly hardens the material and makes drilling and tapping a chore.  This is why waterjet beats laser to cut out Ti parts, no heat issues.
The only times I can think heat would be needed is if you need to bend Ti alot, or to 'reset' the spring position of a Ti liner lock or lock bar, or if you are doing one of the chisel grind box cutter Ti blades, then you'd want it hard as possible.
« Last Edit: March 02, 2016, 08:50:13 PM by Syph007 »
us Offline OHIO
Reply #3585 on: March 02, 2016, 10:12:29 PM
Cool.  I've got an argon box to do a local heat treat if need be and I could always drill and type prior to heat treat.
I'll post some pics once I get done with my first.
Those pocket clips you've posted, the two hole ones. Are you making those or outside vendor?
ca Offline Syph007
  • SAK Surgeon
Reply #3586 on: March 02, 2016, 11:08:20 PM
http://www.knifekits.com/vcom/index.php?cPath=60_101_379
ca Offline Syph007
  • SAK Surgeon
Reply #3587 on: March 08, 2016, 11:39:26 PM
I completed a Ti/brass conversion of a CT Lite today and forgot to post the in progress pics of liner making.
The CT layer and light module layer each needed 2 special liners of unique shape and also thicker than standard ones at 0.040" so I had to hand cut those.  Its good to be reminded now and then why waterjet rules for liner cutting.
The cheat trick I do though is to only cut and polish the inside of the liners and leave a few mm large on all the back sides of the liners.  Then I make a Ti/brass sandwich and grind/polish them all together and then not only does it ensure the liners are all even with the scales, I dont have to hand cut those parts.  :D
ca Offline Syph007
  • SAK Surgeon
Reply #3588 on: March 08, 2016, 11:51:22 PM
And here is the monster in all it's glory.  I lucked out and the pivots needed were exactly 1.000 inches, so I spliced 2 half inches ones together for each and didnt have to alter the length at all.
Reply #3589 on: March 09, 2016, 12:12:22 AM
A Beautiful Beast  :cheers:
us Offline tankerG
Reply #3590 on: March 09, 2016, 12:31:25 AM
Yes, that is a beautiful beast.
Me thinks you're going to have alot of calls for the brass mag holder and brass liners all polished up and shiny.
The weight must start to be a consideration when you get that thick. Ti scales instead of cellidor, brass liners instead of aluminum - plus all the tools. At some point the thickness and weight must work against comfortable EDC.
But - if that were my knife - I wouldn't notice the weight in my pocket much. Because I'd have it out showing it off all the time! :rofl:
ca Offline Syph007
  • SAK Surgeon
Reply #3591 on: March 09, 2016, 12:40:42 AM
Oh yes it is a weighty one for sure.  I hope the owner was going to carry in a belt pouch.  :D
Reply #3592 on: March 09, 2016, 12:46:54 AM
Omg, that's got to have some good weight to it! The belt pouch is one thing but he better have a good solid belt too!
ca Offline Syph007
  • SAK Surgeon
Reply #3593 on: March 09, 2016, 12:50:32 AM
Maybe I could add backpack straps as back layer tools?
I do love brass liners even though they add to the weight.  Maybe in the future I can skeletonize them to reduce the weight.
us Offline SAK Guy
Reply #3594 on: March 09, 2016, 01:01:29 AM
- Robert
Quo Fata Ferunt
Reply #3595 on: March 09, 2016, 02:08:17 AM
This is spectacular.  Some really outstanding work  :tu:
us Offline Monrogue
  • Wooooo!
Reply #3596 on: March 09, 2016, 04:13:05 AM
My TiRogueneer is noticeably heavier than my MechaRogue, even though they are roughly the same size.  The Ti SAKs are beauties though :tu:
K-Tibbs
us Offline neillcurrie
  • Wanted: SpydeWrench
Reply #3597 on: March 09, 2016, 03:08:02 PM
Syph, Was wondering when you are going to offer a solid brass cyber bit-holder and mini flashlight component ;)
Seriously though: great work. I love this thread.
ca Offline Syph007
  • SAK Surgeon
Reply #3598 on: March 09, 2016, 04:53:26 PM
Ive only come accross 2 people who used the flashlight module in my years of modding, so I probably wont tackle that one. :D  The bit holder for sure.  I dont know if it should be brass or nickel silver, or maybe Ti would be best.  Ti could work actually since its not a backspring tool, it just free rotates. Hmm Ti that thick would be pricey... but then it could be anodized too... hmmm Well we'll see.  Im still patiently waiting for the Tormach to make its way to Canada and then learn how to use it, but for sure I can see making up some custom parts to get a SAK up to its max blingy potential.  :D
us Offline tankerG
Reply #3599 on: March 09, 2016, 05:05:37 PM
Oooooh, skeletize me a titanium and brass SAK!!! :tu:
I wonder how much you could remove from such a knife and still have it be durable? With the screws and pivots it should be stiff enough to carve out a fair amount of scale.
But then you'd have the law of diminishing returns kick in. The less metal means more labor (and higher cost). You kinda reach a point where the knife weighs nothing and costs a fortune! :twak:
« Last Edit: March 09, 2016, 05:08:53 PM by tankerG »
