Syph007 · 6035 · 1299525
id Offline jaya_man
Reply #4380 on: January 25, 2017, 04:30:49 PM
 Am amazed as always :like: :drool:
gr Offline Sakpan74Gr
Reply #4381 on: January 25, 2017, 04:34:27 PM
Hey Syph, I was cutting bread with a fully serrated Victorinox kitchen knife, and I had an idea. What if you took the blade of such a knife and modded it to fit in a SAK? Is it possible? It would be thinner than the main blade, so you would need a new thinner spring. Or you could make pen knife blades out of it.
Στάλθηκε από το HUAWEI VNS-L31 μου χρησιμοποιώντας Tapatalk
ca Offline Syph007
  • SAK Surgeon
Reply #4382 on: January 25, 2017, 04:37:36 PM
Yes totally possible.  I would surface grind a backspring to make it thinner.  I have a small serrated kitchen one and its quite well made.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #4383 on: January 25, 2017, 04:41:42 PM
If only I could get the green light from "She who must be obeyed"!😉😂
us Offline s1xty7
Reply #4384 on: January 25, 2017, 05:18:09 PM
Man, that polished steel knife is downright sexy.  Something about polished metal is just so appealing.  Sure, there are a few drawbacks like fingerprints and a bit slippery due to the smooth finish, but when its shined up it sure does look great.  I hear there are some wax based products that help with the fingerprints.
Thanks for sharing and great work as always!
Edit: I meant to add this as well.  The anodizing on the Ti is holding up well.  It's been nearly a year since I got the knife and almost 5 months since I got the scales.  Starting to wear a little at the edges on the high points, but you have to look at it closely to really notice.  Not bad for daily carry in a pocket full of keys.
Another day at the beach.  Maybe I should get a house there?
« Last Edit: January 25, 2017, 05:34:35 PM by s1xty7 »
00 Offline Mechanickal
Reply #4385 on: January 25, 2017, 05:32:51 PM
Oh my, that full metal jacket looks awesome!
I won't find any of those on a flea market anytime soon I guess :(
us Online MadPlumbarian
Reply #4386 on: January 25, 2017, 05:57:28 PM
Another beauty! :tu:
ca Offline Syph007
  • SAK Surgeon
Reply #4387 on: January 25, 2017, 05:58:31 PM
Ya Id expect it to wear like alox, the edges and high points, but the color in the texture should hold on.
Reply #4388 on: January 25, 2017, 06:06:43 PM
Syph007 is on some next level ISH!!!!
Been following this thread now for a while and you sir have always upped your own level of awesome.
Reply #4389 on: January 25, 2017, 06:12:18 PM
He's always had my attn!
Reply #4390 on: January 25, 2017, 06:19:18 PM
Syph007,  just purely out of curiosity, seeing that you have that machine now and all, would it be possible for you to make Leatherman parts?
I don't even know what  :think: maybe blades?  Pry tool?  Marlin spike?  I don't know I was just thinking out loud.
ca Offline Syph007
  • SAK Surgeon
Reply #4391 on: January 25, 2017, 06:44:46 PM
Yes for sure.  I did make some brass and Ti juice scales.
Reply #4392 on: January 25, 2017, 07:31:41 PM
You work a lathe too syph?
ca Offline Syph007
  • SAK Surgeon
Reply #4393 on: January 25, 2017, 08:13:36 PM
No, ive been using my mill to make any small round parts I need.  Works no problem for small stuff.
us Offline Monrogue
  • Wooooo!
Reply #4394 on: January 25, 2017, 08:21:01 PM
Ditto ;)
That polished steel is :drool:
K-Tibbs
Reply #4395 on: January 25, 2017, 08:48:14 PM
More excellent stuff with the polished look Syph :o :like: :like:
Have you made any progress on the 91mm Ti glue on scales? :think:
gb Offline Oxford_Guy
Reply #4396 on: January 25, 2017, 09:52:16 PM
The Vic saw works well for baguettes...
"We broke into Mir using a Swiss Army knife. Never leave the planet without one." - Chris Hadfield, Astronaut
ca Offline Syph007
  • SAK Surgeon
Reply #4397 on: January 26, 2017, 03:37:54 PM
I wanted to come up with a new scale look and Im feeling something steampunk would be cool.  So far Ive got some gear vectors that I like and Im thinking.  Maybe an old clock face where the cross would normally be and some gears and pulleys... This is just something to engrave and anodize for a different look.
ca Offline Syph007
  • SAK Surgeon
Reply #4398 on: January 26, 2017, 08:31:32 PM
Still playing around, but I might try this to see how it looks.
Reply #4399 on: January 26, 2017, 08:46:34 PM
What if you were to place the gear around the pins?
Reply #4400 on: January 26, 2017, 11:11:49 PM
Very cool stuff so far Syph 8) :like:
That also would be cool to see :o :like:
00 Offline Ombudsman
  • Rite of )+( Passage
Reply #4401 on: January 27, 2017, 01:35:31 AM
You can use the Antikythera Mechanism gear template. :D
au Offline Huntsman
Reply #4402 on: January 27, 2017, 03:42:46 AM
Looks interesting Syph -
I think the clock face should be vertical relative to the length of the SAK - ie not at 90deg as you have it
Also agree a cog around a pin would be cool - But I guess space maybe a constraint !!
mc Offline Gerhard Gerber
Reply #4403 on: January 27, 2017, 02:08:07 PM
You said steampunk and I though steam train..........what about scaling the gears, adding the arm (??) to make it look like the drive of a locomotive?
Brilliant theme idea anyway  :tu:
ca Offline Syph007
  • SAK Surgeon
Reply #4404 on: January 27, 2017, 02:24:11 PM
I have a bunch of brass gears that I bought to build an actual working steampunk mechanism, but I couldnt figure out what to make it do except maybe eject the tweezers from the scale.  Or just spin each other for a fiddly hand toy...  But then if i wanted a mechanism on the shcale what can I use that is clear to cover it.  I dont think there are many options that I can cut and shape except polycarb. Plexiglass would crack if dropped.  Where is transparent aluminum when you need it.
That would look awesome.  I suppose if I solve what to cover a scale with I could put any type of clock or watch mechanism in there.
« Last Edit: January 27, 2017, 02:25:12 PM by Syph007 »
ca Offline Syph007
  • SAK Surgeon
Reply #4405 on: January 30, 2017, 06:32:02 PM
I still build alot of blue tiox super tinkers.  This has become quite a standard request.  Here the only difference is I removed the keyring from the opener layer spring.  Ground off the piece of spring with the hole and then sanded and buffed it.  It doenst even look like there ever was one now.
Reply #4406 on: January 30, 2017, 09:01:22 PM
Love the color!
se Offline Fortytwo
Reply #4407 on: January 30, 2017, 09:31:08 PM
Love the color!
+1, the cross really makes it look extra professional. It's nice to see the single piece liner as well, that takes the knife another step above stock configuration.
Reply #4408 on: January 30, 2017, 09:44:38 PM
I can see why it's popular! Have you tried doing the Tiox scales in green or purple yet?
ca Offline Syph007
  • SAK Surgeon
Reply #4409 on: January 31, 2017, 05:39:16 AM
I need to etch the scales to get the higher voltage colors and the best chemical for that is hydrofloric acid.  I found a source but havent got any yet.
