Syph007 · 6035 · 1299536
ca Offline Syph007
  • SAK Surgeon
Reply #4410 on: January 31, 2017, 05:40:49 AM
You can use the Antikythera Mechanism gear template. :D
Do you follow clickspring on youtube, he is starting to do a build of that mechanism.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
gb Offline shibafu
Reply #4411 on: January 31, 2017, 10:52:30 AM
I need to etch the scales to get the higher voltage colors and the best chemical for that is hydrofloric acid.  I found a source but havent got any yet.
Exceptionally dangerous stuff, be careful.
https://en.wikipedia.org/wiki/Hydrofluoric_acid#Health_and_safety
https://web.utk.edu/~ehss/training/has.pdf
« Last Edit: January 31, 2017, 11:00:08 AM by shibafu »
ca Offline Syph007
  • SAK Surgeon
Reply #4412 on: January 31, 2017, 03:03:40 PM
Oh I know all about it.   Killed lots of artists who used it to etch metals.   Im only going to use it in the back shed with an exhaust vent.  Its sold as rust remover in the US and I can order it from there.  Noone in canada sells it.
This stuff is what the other Ti etchers have been using
https://www.amazon.com/Whink-1081-Rust-Stain-Remover/dp/B000LNQNM0/ref=sr_1_1?ie=UTF8&qid=1485871172&sr=8-1&keywords=whink
ca Offline Toolslinger
  • Thread Killer 2015
Reply #4413 on: January 31, 2017, 03:33:22 PM
What about Multi-Etch? I've seen some YouTubers using it. Not sure what the chemical makeup of it is, but it's supposed to work well for Ti Anodizing.
ca Offline Syph007
  • SAK Surgeon
Reply #4414 on: January 31, 2017, 04:16:33 PM
Bought some but its a pain to work with.  Needs to be heated on a hotplate and has a short shelf life when mixed.
Reply #4415 on: January 31, 2017, 05:28:38 PM
Good to know.
Stay safe if you go the Hydrofluoric Acid route. I still remember the horror stories my Chemistry teachers used to tell about labs that used it...  :ahhh
au Offline Huntsman
Reply #4416 on: February 02, 2017, 01:52:08 AM
Be careful Syph
Here's a report about a lab technician in Oz who carked it due to HF poisoning - Some good recommendations about how to handle HF in the report!!
http://www.ab.ust.hk/hseo/tips/ch/ch005.htm
ca Offline Syph007
  • SAK Surgeon
Reply #4417 on: February 02, 2017, 02:44:03 AM
Be careful Syph
Ya skin contact is very brutal with HF.  That guy should not have been sitting when working and must not have had the shield down far enough.  Crappy way to go out.
That whink rust remover is far lower concentration than what they would have been using considering this is a consumer product and people use it indoors.  I dont use any chemicals indoors though, all nasty stuff in back yard shed.
ca Offline Syph007
  • SAK Surgeon
Reply #4418 on: February 02, 2017, 09:50:25 PM
compact deluxe tinker today.  :D
us Offline 4everYoung
Reply #4419 on: February 02, 2017, 10:27:04 PM
I think you may have just created my dream SAK. 🤤 absolutely beautiful!!!
se Offline Fortytwo
Reply #4420 on: February 02, 2017, 10:44:52 PM
Maybe you have already answered this but how do you get around the problem with the liner "indent" as mentioned in this topic by Gareth?. Even if the real problem (overlapping tools) is only applicable when mixing new and old parts the spring is still thicker than the blade without the indent. Doesn't this result in a wiggly blade?
ca Offline Syph007
  • SAK Surgeon
Reply #4421 on: February 03, 2017, 01:35:49 AM
I make 0.015" phosphor bronze washers to fill out the gap.
Reply #4422 on: February 03, 2017, 01:59:16 AM
More beautiful work Syph :dd: :like: :like:
se Offline Fortytwo
Reply #4423 on: February 03, 2017, 02:11:16 AM
Thank you, you are always very helpful!
Reply #4424 on: February 03, 2017, 03:05:19 AM
Another beauty! :tu:
si Offline lister
Reply #4425 on: February 03, 2017, 03:48:51 PM
Scale tools in metal scales... interesting, very interesting indeed.  :like:
I am not sure that I ever noticed that in your work before now. But I see it is not a new feature. I suppose that there must be a liner beneath the scale to provide a covering for the slot of the tool? And most importantly, can you make a 93mm model with that feature?  :drool:
se Offline Fortytwo
Reply #4426 on: February 03, 2017, 04:34:05 PM
I seem to remember Syph saying that no, he doesn't use a liner. Instead he makes use of the spring to hold the tool in place, quite ingenious.
ca Offline Syph007
  • SAK Surgeon
Reply #4427 on: February 03, 2017, 05:23:00 PM
No liner, since the backspring is bent to accomodate the backtool on the blade layer, I make use of its position to retain the tweezers.   When I convert a SAK to the Ti scales, less liners, its saves about the same thickness as a pliers layer in total thickness and is quite significant.
That same trick cant work on a 93mm since the springs are flush to the bottom of the sak.
Here's a pic of the inside of the backscale.
« Last Edit: February 03, 2017, 06:39:02 PM by Syph007 »
gb Offline Oxford_Guy
Reply #4428 on: February 04, 2017, 02:34:45 PM
"We broke into Mir using a Swiss Army knife. Never leave the planet without one." - Chris Hadfield, Astronaut
ca Offline Syph007
  • SAK Surgeon
Reply #4429 on: February 04, 2017, 05:08:37 PM
Ive been working quite alot lately trying to get some orders finished up.  I got these 2 done last night.
The 2 layer with pliers and nail file Im sure is a first for me.
us Offline Monrogue
  • Wooooo!
Reply #4430 on: February 04, 2017, 05:39:54 PM
Good stuff :tu:
K-Tibbs
us Offline zrxoa1
Reply #4431 on: February 07, 2017, 02:53:16 PM
I've been trying to read thru this thread, but it is sooooo long!  Good reading but alot of posts!  So if this has been covered, my apologies...
Can you do a bail on the end of one of your creations?
Awesome work, by the way!
Sent from my Nexus 6 using Tapatalk
us Offline zrxoa1
Reply #4432 on: February 07, 2017, 02:54:26 PM
Remember those 154cm blades I had made a looong time ago.. well I finally got one in a knife.
I make the thick spacer out of Titanium, and yes this has a bail with tapered tips to fit in torx T9 screws.  :D
Never mind my previous post, found the answer!
ca Offline Syph007
  • SAK Surgeon
Reply #4433 on: February 07, 2017, 03:02:58 PM
I havent made a bail yet, but Im sure there is a way.  I think machining one from flat Ti stock probably makes the most sense to try.
ca Offline Syph007
  • SAK Surgeon
Reply #4434 on: February 07, 2017, 10:44:28 PM
Finally found a guy named Steve to buy this SAK!   :rofl:
No corkscrew/phillips cutout on this one.
us Offline zrxoa1
Reply #4435 on: February 08, 2017, 01:49:42 AM
I saw one of your creations on eBay...Is that the normal pricing for your beauties? If so, well out of my reach!   Gorgeous though!!!
ca Offline Syph007
  • SAK Surgeon
Reply #4436 on: February 08, 2017, 03:40:36 PM
I'd say 90% of what I do falls into the 250-350 range.  Depends on what options people want, and how many SAKs it takes for donor parts.
ca Offline Lardlad
Reply #4437 on: February 08, 2017, 08:19:37 PM
Well worth the cost, the workmanship is amazing.  I have certainly never regretted my purchase.
Reply #4438 on: February 09, 2017, 02:30:17 PM
Very elegant! :-)
ca Offline Syph007
  • SAK Surgeon
Reply #4439 on: February 09, 2017, 10:10:57 PM
A bit of yeoman action today.  :D
