Yep the wenger 93mm alox are the same as vics, so no problem. As for the bail if you are adding layers, you'd probably have to make a new bail, unless it could be stretched enough to be used. You'd also need 3mm tube stock for the bail pin. Someone must have done this, I havent though.
