The SAK Whittling Club
Smaug · 791 · 125409
se Offline RF52
Re: The SAK Whittling Club
Reply #480 on: July 20, 2018, 03:59:02 PM
Nice
se Offline stoneshank
Reply #481 on: July 21, 2018, 01:35:03 AM
Got my phone to the store for repair and got a slowass s5 borrowed meanwhile.  Will try to take some pics with it!
- stoneshank
Reply #482 on: July 21, 2018, 04:00:15 PM
Some more pictures if the penguin.  I made it out of two pieces of spare wood, by making a hole through one of them where the other would fit.  Took really little time when comparing how long some other projects took.
- stoneshank
Reply #483 on: July 21, 2018, 04:06:24 PM
Some small projects in making spoons, for eating or to meet out spices.
- stoneshank
Reply #484 on: July 21, 2018, 04:12:20 PM
Took a branch,  cleaved in two then made a two part face of  ' The Joker ' with the outside parts. What made me do it was watching some sidetrack stories about how the Joker skinned his own face and some other acts of insanity.
- stoneshank
Reply #485 on: July 21, 2018, 04:24:34 PM
Went about the same way as the previous post with the crazy clown.  First the background. A stormy sea with Japanese art inspired clouds. There is also a sail on the left side belonging to the viking explorer ship in picture nr 2.
Picture nr 3 is the mid part . It's meant to be a compass with a silk band in the background ( which disappeared in the noice).
Picture nr 4 is the right part of the foreground. In a "here be dragons " spirit, a giant turtle about to fall on the ship.
Pic 5. Full picture.
- stoneshank
Reply #486 on: July 21, 2018, 04:28:44 PM
Random pieces
- stoneshank
Reply #487 on: July 22, 2018, 05:35:51 PM
Walking stick in progress. Brought the Champ with me today for the file. Made a measuring string to help making the pattern.
- stoneshank
« Last Edit: July 22, 2018, 05:37:21 PM by stoneshank »
us Offline VICMAN
Reply #488 on: July 22, 2018, 05:42:48 PM
- stoneshank
The walking is coming along nicely stoneshank! :like: :tu: :tu:
au Offline TazzieRob
Reply #489 on: August 08, 2018, 05:31:19 AM
I need to modify my Recruit and get started on some carving
I re-profiled the small blade using the Surge file. Straight line from the heel part of the blade to the tip
us Offline El Corkscrew
Reply #490 on: August 08, 2018, 06:55:43 AM
 :like: Great job!  :tu:
Reply #491 on: August 08, 2018, 12:16:09 PM
Cheers!
First attempt at a Chris Lubkemann style rooster
Sent from my E5823 using Tapatalk
Reply #492 on: August 09, 2018, 05:42:26 AM
Knife needs to be sharper, tail very hard to do. As a first try it looks a bit like a rooster. Was just going by memory from the little book of whittling.
This has been made out of a piece of apple tree
Reply #493 on: August 13, 2018, 02:16:01 PM
I spent a bit more time on the blade, got it nice and sharp. I have also put a chisel edge on the cap lifter. The can opener lost its tooth (as long as you don't take too much off it still situation the right height) and screwdriver tip, and got a convex grind, still needs some touch up. I've been working on another rooster, bit bigger, and different wood
Reply #494 on: August 13, 2018, 02:17:23 PM
Will this stay in portrait?
Reply #495 on: August 14, 2018, 03:27:29 PM
WOW, TazzieRob! I kind of gave up on posting here as it felt like too few added content to warrant a thread of its own and here you choice and hit it out of the park!
I prefer that shape you got in the blade but I noticed on "proper" carving knives the tilt of the blade is "inwards"and not "outwards" (like yours and mine I made).
- stoneshank
Reply #496 on: August 14, 2018, 03:35:03 PM
Adding a new reply as my first post disappeared due to app crashing :(
Anyways.. My reply came out a bit too aucthorian and teaching, which I didn't mean to.
I pondered the blade tilt reasoning and I guess it is that a inward tilt gives me control and strength earlier and I don't risk to slip and cut myself due to early slip. Added picture with lines and such
- stoneshank
« Last Edit: August 14, 2018, 03:36:57 PM by stoneshank »
Reply #497 on: August 14, 2018, 03:37:48 PM
This looks like a carving book example, looks great!
- stoneshank
Reply #498 on: August 14, 2018, 03:39:54 PM
Adding picture for obligatory thread picture!
- stoneshank
Reply #499 on: August 14, 2018, 04:09:26 PM
Great work, guys! Makes you want to give it a try, too...
 :salute: :tu:
Reply #500 on: August 15, 2018, 02:04:29 AM
- stoneshank
Thanks Stoneshank! It's something I've been meaning to get into for a while, just needed to pull my finger out and have a go. Please keep sharing your carving  :salute:
Reply #501 on: August 15, 2018, 02:27:38 AM
I pondered the blade tilt reasoning and I guess it is that a inward tilt gives me control and strength earlier and I don't risk to slip and cut myself due to early slip. Added picture with lines and such(Image removed from quote.)
- stoneshank
I get what you mean, though small carving knives like the Mora 120 and 106 have a belly and a sweep "outward" to the tip, as you put it. I think this aids in slicing cuts, but for finer detail that's when a straight blade is better, and a thinner blade too. For me, I could have modified the pen blade straight across, but this would have taken more time to file/grind more than double what I took off, and put a decent edge back on. I may do this in the future, but happy to just go with what I have for the moment. Now that I've done it I'm pleased with the result, just had a bit of hesitation at first about taking the plunge. Even if I'd smurfed it up I'm sure I could have still turned it into a useful too.
Sketch of what I'm talking about
Another benefit of a small straight edge it it is easier to sharpen, no need to tilt the blade to get the tip.
The can opener mod I figured if I didn't like it I could grind off the shark fin and just make a smaller chisel. It is definitely harder to sharpen due to the geometry than the flat screwdriver chisel which is wickedly sharp. I haven't tested it out yet for spoon bowl gouging.
I have another recruit, I could either modify or combine with this one, though I'm interested in trying a Hiker so the saw is incorporated for harvesting material.
Reply #502 on: August 15, 2018, 02:29:23 AM
- stoneshank
Thanks mate, I know everyone has to start somewhere and I'm reasonably pleased with this as a first attempt from memory only
Reply #503 on: August 15, 2018, 02:35:26 AM
- stoneshank
Thanks for rotating that one  :cheers: I'm liking how this one is turning out even though the wood is not that great. It is Photinia Robusta and gives quite irregular growth shape. I've taken more out of one side to get it to line up with the tail more, though that probably wasn't necessary. Life isn't perfectly symmetrical, I should try and work with the piece I have more than to try and make it do what I want or think I want
I've been watching some carving videos, Doug Outside has quite a few good ones
Reply #504 on: August 15, 2018, 02:37:59 AM
 :salute: :tu:
Absolutely! Glad I have contributed to the inspiration like others have inspired me here to have a go!
Reply #505 on: August 15, 2018, 02:47:03 AM
Pic 5. Full picture.(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
- stoneshank
This is one of my favourites of your work, fantastic job! I love the depth to it, that Viking ship looks so good
Reply #506 on: August 15, 2018, 11:43:27 AM
Thanks! And Pfrsantos, join in!
Will try to post some pictures but currently trying to make a keychain to my brothers son, and a wall thingie where he can hang his keys. He's .. uhm.. four for years old I think. He's into something called "Paw Patrol" so in trying to, after googling this unlikely band of dog heroes, make something with that. The wall mount is "done"in the rough way and just needs hours spent while the actual keychain failed yesterday, the rough version looked more like a rabbit that a dog
- stoneshank
Reply #507 on: August 15, 2018, 12:43:30 PM
That's not bad for a first attempt, take what you have done and the next one will be better  :tu:
Reply #508 on: August 15, 2018, 01:05:08 PM
The tail is currently my nemesis. The "fan" just isn't working for me. Not sure if I meed to let it dry out first, try more of a feather stick with smaller curls, thin down the stick first or if the wood is just not good for it.
Reply #509 on: August 15, 2018, 03:05:35 PM
Looks good to me though!
- stoneshank
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
