Do they do a copper space pen?
Used the file on my Charge to take a little off the pins and bushes of this Vic Compact to fit new scales:Then a couple of Crunches to apply a bit of pressure whilst the quick-drying epoxy went off:Seems to have stuck them on well enough, I guess time will tell, lol.
Just doing my day to day job. Leatherman did some overtime today. Broke the bit but. Have got enough spare ones at home.(Image removed from quote.)
No pics, but I used my SS ST300 to cut up some smoked sausage for breakfast...that knife is SHARP!!!!Sent from my Nexus 6 using Tapatalk
Cutting an orange for lunch.
Quote from: Gohard on August 12, 2016, 12:47:50 PMCutting an orange for lunch.Is that a huge brake disc you're using as a table there?
Quote from: Kevin Davey on August 15, 2016, 08:59:23 AMQuote from: Gohard on August 12, 2016, 12:47:50 PMCutting an orange for lunch.Is that a huge brake disc you're using as a table there?Yes. It is.
Quote from: Gohard on August 15, 2016, 10:42:25 AMQuote from: Kevin Davey on August 15, 2016, 08:59:23 AMQuote from: Gohard on August 12, 2016, 12:47:50 PMCutting an orange for lunch.Is that a huge brake disc you're using as a table there?Yes. It is.It's looking a bit rough, it could do with a skim. Or you could see if you can dress the surface with your wave file
Quote from: Kevin Davey on August 15, 2016, 10:46:06 AMQuote from: Gohard on August 15, 2016, 10:42:25 AMQuote from: Kevin Davey on August 15, 2016, 08:59:23 AMQuote from: Gohard on August 12, 2016, 12:47:50 PMCutting an orange for lunch.Is that a huge brake disc you're using as a table there?Yes. It is.It's looking a bit rough, it could do with a skim. Or you could see if you can dress the surface with your wave file Zoom in and look at the cracks. Need some body filler.
First use of rebar with bit extension today, to change the batteries in my wireless mouse at work. I don't like the retention of the bit adapter on the philips driver of the rebar. I'm thinking a mod in the future and add the bit exchanger from a wave/surge.I wonder if Loki has any in stock (Image removed from quote.)
Quote from: Kevin Davey on August 15, 2016, 01:34:14 PMFirst use of rebar with bit extension today, to change the batteries in my wireless mouse at work. I don't like the retention of the bit adapter on the philips driver of the rebar. I'm thinking a mod in the future and add the bit exchanger from a wave/surge.I wonder if Loki has any in stock (Image removed from quote.)I have never had any problems with mine and I have used it for years now A bit holder would be good for a lot of people though but I like the dedicated Phillips best Loki usually has stuff like that in stock I would shoot him a OM if you really want one
Quote from: Poncho65 on August 15, 2016, 01:39:12 PMQuote from: Kevin Davey on August 15, 2016, 01:34:14 PMFirst use of rebar with bit extension today, to change the batteries in my wireless mouse at work. I don't like the retention of the bit adapter on the philips driver of the rebar. I'm thinking a mod in the future and add the bit exchanger from a wave/surge.I wonder if Loki has any in stock (Image removed from quote.)I have never had any problems with mine and I have used it for years now A bit holder would be good for a lot of people though but I like the dedicated Phillips best Loki usually has stuff like that in stock I would shoot him a OM if you really want one The adapter is one I bought for the Juice XE6 but I'm guessing they are the same ones for the rebar.I've got the saw/file adapter off a surge coming from Loki to see if I can mod it to fit and lock in a rebar. If I can get it in I can bin the saw and make more room for other mods.
Quote from: Gohard on August 15, 2016, 01:25:49 PMQuote from: Kevin Davey on August 15, 2016, 10:46:06 AMQuote from: Gohard on August 15, 2016, 10:42:25 AMQuote from: Kevin Davey on August 15, 2016, 08:59:23 AMQuote from: Gohard on August 12, 2016, 12:47:50 PMCutting an orange for lunch.Is that a huge brake disc you're using as a table there?Yes. It is.It's looking a bit rough, it could do with a skim. Or you could see if you can dress the surface with your wave file Zoom in and look at the cracks. Need some body filler.I noticed them, but thought there's life in it yet If there is anything like here, they run them till they fail. Which I find surprising considering they are hauling a couple of hundred tons of slag or pig iron around at a time. Needless to say they get right of way everywhere
