[Listed]ZERO TOLERANCE JB2 SHROUD CUTTER - USD 44.99
Guest · 1 · 251
EDCSource
  • Guest
The Zero Tolerance JB2 Shroud Cutter is constructed of 13C26 stainless steel with a tough, Tungsten DLC coating in matte black. The business end is a 270 cutting notch with a .34 inch entry point. It easily slices through cord, webbing, belts, boot laces and even clothing. The JB2s non-exposed cutting notch ensures cutting only occurs where and when you want it. The JB2 also features a carbide glass breaker, Oxygen tank wrench and hex head slip wrench. SPECIFICATIONS: Steel: Sandvic 13C26 stainless steel with Tungsten DLC coating Handle: Handle information not available for this product.Blade Length: N/AClosed Length: N/AOverall Length: in.Weight: 2.4 oz. (3.4 oz. w/sheath) FEATURES: 270 degrees of non-exposed cutting surface Carbide glass breaker Oxygen tank wrench Slip-wrench accept 3/8, 7/16 and in. hex heads Jump rated sheath
http://www.edcsource.com/auction_details.php?auction_id=112636
