Cracking rig you've got there mate, and a free UKPK can't be bad either, ya jammie sod
Quote from: micky d on February 13, 2008, 12:08:23 PMCracking rig you've got there mate, and a free UKPK can't be bad either, ya jammie sod Have you got a UKPK Mike ? Dunc
I've had one in the past and they are a very good alround usefull knife . Makes a great edc but its only downside is it looks a bit scary and like you said ignorant Pc's may take a dim view Must say I'm not bothered about that , cross that bridge if I ever get to it The big thing is he makes them for Swisstools too Horizontal carry Dunc
I love kydex, while it's nowhere near as good looking as leather, it is way tougher and more practical
Thats very true mate, my main problem with leather on these shore's (uk) is it's very easy for the leather to become saturated, and takes an absolute age to dry out again
Plus leather retains moisture on the tool or knife, increasing the likelihood of rust or corrosion. I got a vintage Cold Steel tanto a year or so ago that had never been used, but the blade was a mess because it had been stored in leather.Besides, if it's cold enough to crack kydex outside, I doubt I'd be out there myself! Def
A cautionary tale about Kydex:A buddy of mine lost a fairly expensive custom knife due to Kydex sheath failure during a winter backpacking trip. He was seriously bummed out when he went to use his knife and discovered it missing!Temps had been ranging from -10F lows to +15F highs for several days. The Kydex had cracked all the way through and released the knife at some point during the afternoon walk, because he remembered having used it at lunch.He almost decided to backtrack along the trail to try to find the knife, but didn't because it was basically hopeless due to the depth of snow.
Is it not kydex? my bad! but the point still stands....i think!
We have that kind of weather here too- I call those "Inside Days." If God (or Darwin) had wanted me to go out in that weather, I'd have fur as thick as my husky's!I've been out in it, I've worked out in it, and I've even come home and had my uniform frozen to my skin, and I figure I've done my time in it! And, I've been out in even worse than that, and so my rule is now that I just don't go out in that weather!Besides, anything other than a fixed blade knife is virtually useless at those temperatures. You may get away with operating a set of pliers like on the PowerLock, but one handed opening blades and other implements are pretty well negated by thick gloves or mitts. Def
Hmm well the website does say zytel, but just come across this link which says that they stopped using kydex and switched to zytel sometime in 2006. So when did you buy your F1?!
