58mm file variation(s)
dks · 6 · 1598
on: September 28, 2012, 05:47:06 PM
I was looking at some recent 58mm SD type files and noticed that there were two distinct types.
On the one type the side of the screwdriver tapers in from the file side and on the other type from the opposite side. The blade markings could not be used to distinguish between the ages of these files.
The ones with the taper on the file side had a slightly rougher and older looking file surface, so I assume they are older.
When did the change occur. I think I read about the change somewhere but Icould not find it...
The 3 on the right taper from the file side:
closeup (reversed)
us Offline Marius
Re: 58mm file variation(s)
Reply #1 on: September 29, 2012, 12:39:12 AM
Interesting observation!
Do they all have the same thickness at the tang?
Reply #2 on: September 29, 2012, 08:03:42 AM
They all look the same shape and thickness all around
Also the screwdriver tips on the two types are exactly the same, just reversed.    ???
I expected to have at least a hundred answers from the experts by now....  :D
Reply #3 on: September 29, 2012, 12:40:49 PM
I'd not noticed the changes before, good spot. :tu:
us Offline ICanFixThat
Reply #4 on: September 29, 2012, 06:27:51 PM
Very good spotting!   :tu:
I had not noticed that change before, but I've noticed some differences in the textured file.  I think there might be more than a couple different changes in the texturing, but some of them could be just due to manufacturing tollerances.
Reply #5 on: September 29, 2012, 08:57:25 PM
It is obvious that I have too much spare time.......  :facepalm:
 :rofl: :rofl:
