Knife - a SAK Recruit or an older Gerber LST. I used to carry a bigger knife "just in case" I needed a back-up weapon, but came to the realization that I'm no knife fighter and, if its gotten to that point I should be running!...Pistol - a Keltec P32. No, it's not a death ray, but it will make someone think twice about continuing their anti-social behavior as I fill their abdomen or cranium with small attitude adjusters.
I'm a bit of both. At work my usual load is SAK, larger folder, slipjoint, and multi. The large folder is my box cutter and all-around utility blade, usually my Kershaw Needs Work. The slipjoint is for opening packages and doing cutting around customers who may not be thrilled with the AO Kershaw. The scissors, can opener, and large screwdriver see lots of use on the SAK. As for the multi, there are times where it doesn't see any use at all during the day, and others where it doesn't seem to make it back into the sheath, it's doing so much!
Quote from: charlie fox on January 04, 2013, 06:35:26 PMPistol - a Keltec P32. No, it's not a death ray, but it will make someone think twice about continuing their anti-social behavior as I fill their abdomen or cranium with small attitude adjusters.If the anti-social person thinks the same way as you it probably wouldn't end well for the both of you. Worse though, you're sort of playing god when you decide what is anti-social and what isn't. I don't think violence is ever the answer. Just saying..
At some point recently, I started dumping a lot of the stuff I had in my purse, thinking 'This is dumb'.I still had a little 'Survival tin' in there, a bit larger than an altoids tin, and it has one of those thermal emergency blankets in it. Even that, I was thinking was kind of stupid.Then, the other day, a father and his two sons died of hypothermia on a hike in the Ozarks. And i can't help but think it might not have been that way, for the want of a stupid $2 survival blanket.http://www.webpronews.com/father-sons-die-hiking-in-the-ozarks-2013-01The weather in these parts can swing wildly, and what started off as a 50 degree F afternoon soon turned to freezing rain. Maybe my little survival tin isn't such a bad idea after all.
I had a situation y'day that someone needed multiple lighters to light candles with and didn't bring them. My wife came up to the studio because she knows that I carry multiple lighters. I don't need three or four lighters that I carry but I'm the 'go to' in these situations
you da man Stealth ! i'm sure you have 'back-up' cigars too ?
Heinz, I have often thought "why not have several lighters" instead of these folks who swear by 'flint and steel' (i'm by no means a wilderness type, just interested) and as for knobbing about with string and friction i understand it's cool. i understand it's good knowledge to have in a 'what if' situation but more emphasis on "remember that (those) lighters" sounds like really sound advise to me ! if you can remember a fire steel why not take a lighter ? (this is not meant to be a criticism, just a musing)
I have no idea what that survival blanket is exactly but regarding the reflection or not of IR the frequency of the radiation is also a factor. So something that reflects low f radiation may not reflect higher f radiation (low f -> long wavelength, ? => simply put a "bigger" ray which needs more space to pass through something).This may explain why there could be a difference observed between the reflection of body heat and heat from a fire etc. (see greenhouse effect). Theoretically body heat should be more easily reflected.Also, assuming the same efficiency in reflection (not right anyway) a big heat source reflected will be felt more than a small source reflected.and so on....end of boring you lot.
