The Smoothie - Metro's ultimate juice.
ca Offline Metropolicity
  • Hack Virtuoso
Re: The Smoothie - Metro's ultimate juice.
Reply #30 on: March 22, 2013, 05:01:14 PM
Alright, polished alumide set of scales ordered.
If anything these will make a nice set of scales in combined with the skeleton frame in addition to being a fitting test for the stainless ones.
Why stop now?
Shapeways - Metro's Q-branch:
de Offline lowtech
Reply #31 on: March 22, 2013, 05:23:55 PM
Now we´re talking. and if you are at it, maybe you could offer them in a kit with precision fabricated shims to reduce the clatter of the Surge and a nice milled down Bluntnose head...  8)
I´m waiting what´s there to come for my surge...
That's a whole other project. I need to see how the stainless steel scales for the juice scales up.
I purposely started with the Squirt to see if such things could be done. The Surge scales redo will be a huge challenge, since there is no precedent or anything to work off of.
Since the Charge TTi is what I am emulating, there is no reason to design scales for it :)
For the record, the Surge chatter is due to the frame of springing back, if you squish the gap for the plier head if you disassemble, it will GREATLY reduce the chatter.
I wonder if Leatherman is watching....are you?
I did not want to nag or be impatient. Just looking forward to it, and the "Kit" idea just crossed my mind as i am spoilt by teh swiss finish and have seen that you put very much thought and effort in your products - I was thinking about dismantling, maybe polishing parts and careful reassembly of my Surge anyways when i read your next idea.
And teh Bluntnose head would be very welcome. Maybe i can just send you mine ;-)
  • Hack Virtuoso
Reply #32 on: March 22, 2013, 05:26:39 PM
Just normal Surge heads? I have a couple of new spare ones. Just looking for a bunt nose? Pm me and we can set up the p4 et al.
Why stop now?
de Offline lowtech
Reply #33 on: March 23, 2013, 03:07:29 PM
PM sent
  • Hack Virtuoso
Reply #34 on: March 23, 2013, 03:43:54 PM
Now back on target. Shapeways sent me am emailing saying the plastic scales are off to the robots to print. Fingers crossed on no problems.
I haven't done this level of 3d print work since design school. Lots of fun!
Why stop now?
nl Offline Wootz
Reply #35 on: March 23, 2013, 04:57:52 PM
It's all abracadabra to me. Enjoying your tinkering nevertheless.  :popcorn:
gb Offline Farmman
Reply #36 on: March 23, 2013, 07:42:28 PM
Looking good Eric.  Printing scales, really does drive home how far I need to go as I sit here with a bit of brass and sandpaper.  Keep up the good work.
  • Hack Virtuoso
Reply #37 on: March 23, 2013, 07:45:09 PM
It's in part a laziness, but it's also in part a performance thing. By designing and printing digitally, I can repeat my failures/successes with relative ease. I am actually not one to sit down with a stock of brass hack away at it, I spend days, sometimes weeks figuring out how to do things.
If I discover a good way, picture, then post to capture the idea, however stupid or good it maybe :)
Why stop now?
  • Hack Virtuoso
Reply #38 on: March 23, 2013, 08:12:57 PM
Did a little fiddling today. Took an old user S2 I had and decided to even out the handles and remove the offending can/bottle opener.
In the process, I wanted to take a photo of another way to install the back springs.
As mentioned before, the way I installed the knife and tool backsprings is sliding it into as far as it can go, closing the blade/tool to hold the spring in place, holding it in place with a clamp or vice and then taping it into place.
The plier/inside tool springs are quite a bit stronger because of the short throw they have. The process is similar except I found that putting the end of the spring and the entire tool into the vice and slowly closing the vice would seat the springs nicely.
The end result is something like this.
I had made the middle flat driver into an awl.
Compared to another s2.
Even Steven.
Why stop now?
  • Hack Virtuoso
Reply #39 on: April 01, 2013, 01:02:21 AM
Used the skele-smoothie today to do most of the wiring, plastic shard cleaning, installation and clean up work on my new DIY millennium falcon lamp made from a flea market find.
The flat bit was perfect for taking off the plate, the wire cutters made short work of the lamp cord and the pliers worked very well to adjust the depth of nipple (teehee)
Why stop now?
us Offline Nhoj
Reply #40 on: April 01, 2013, 01:18:55 AM
Nice lamp! I like how you were able to also give the base the look. Just don't put a lightbulb that will get too hot in!
ca Offline wndrstrck
  • Leatherman, GEC, SOG, Parker
Reply #41 on: April 01, 2013, 01:21:31 AM
Is there anything you don't MOD?
Nice work there Metro!
Sent from my Galaxy Note II
"To be prepared is half the victory" Miguel de Cervantes
  • Hack Virtuoso
Reply #42 on: April 01, 2013, 01:33:49 AM
The base plate is the underside of the falcon. I trimmed it with some styrene.
Why stop now?
us Offline stealth007s
Reply #43 on: April 01, 2013, 04:36:04 AM
Nice Eric :tu:
Terry
us Offline Continent
Reply #44 on: April 01, 2013, 11:24:38 PM
Metro,
Sorry if you mentioned this earlier and I missed it, but where did you get the replacement pivots for the Juice?
  • Hack Virtuoso
Reply #45 on: April 02, 2013, 12:06:25 AM
Metro,
No worries. I got them from knifekits.com
They are the 1/8", .5 long ones.
Why stop now?
Reply #46 on: April 02, 2013, 03:19:55 AM
Thanks, Metro!!!
  • Hack Virtuoso
Reply #47 on: April 02, 2013, 05:05:04 AM
Thanks, Metro!!!
no problem!
I ordered a whole bunch more for a commission I have. Pretty good customer service they have.
Why stop now?
  • Hack Virtuoso
Reply #48 on: April 06, 2013, 02:37:51 AM
When it rains it pours. Traded a whole bunch of tools for more Juices and I have over a dozen juices enroute to me.
Why stop now?
  • Hack Virtuoso
Smoothie - Squirt parts in a Juice?
Reply #49 on: April 13, 2013, 11:46:16 PM
This looks promising. Squirt tools in a Juice? All that needs done is a small notch needing to be milled into the backspring cam area.
« Last Edit: April 14, 2013, 12:12:35 AM by Metropolicity »
Why stop now?
  • Hack Virtuoso
The Smoothie - Juice Cap Crimper!
Reply #50 on: April 13, 2013, 11:47:13 PM
Also, playing around today and made a cap crimper on a juice head. Not for cap crimping but for holding on to wire handles, rods, ummmm other stuff. It's 1/8 in diameter and a 3/16" counter sunk on one side.
Don't mind the purple, I am using the scales as place holders till I get those darn steel ones in.
Somehow I managed to save a set of KF4 scales (with some minor damage)
« Last Edit: April 14, 2013, 12:12:54 AM by Metropolicity »
Why stop now?
  • Hack Virtuoso
Reply #51 on: April 16, 2013, 05:45:25 PM
holy crud, Shapeways lost the ENTIRE order of three sets of Juice scales. They are printing it again but such a pain.
Why stop now?
  • Hack Virtuoso
Reply #52 on: April 20, 2013, 06:01:51 AM
Umm...so this happened. Thanks to Syph007, I have a full set of BO Juice parts ready to be assembled into, yes, you guessed it...a Tactical BO Smoothie..
Tasty!
I don't have them yet, but also included in the batch is a Ultrafire A2R5 steel light, a PocketWrenchII and a Zebra 701. Man oh man...
Why stop now?
us Offline Breezy12
Reply #53 on: April 20, 2013, 08:17:33 AM
Tasty!
 :drool: :drool: :drool:
Can't wait to see the results!  :)
de Offline lowtech
Reply #54 on: April 20, 2013, 11:29:34 AM
 :tu: This is gonna look  really nice!
But i must confess I especially do like not battered, but worn down from use BO where you can see that a tool has been used many times.
ca Offline Syph007
  • SAK Surgeon
Reply #55 on: April 20, 2013, 03:10:44 PM
I think BO on LM tools is a real asset.  Ive had my juices rust on the inside.  Especially the springs where they contact the frame.  So BO'ing would have prevented that, even if the tools wear the inside will be protected, prolonging the life.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #56 on: April 20, 2013, 06:31:44 PM
Ooh I would carry a BO Juice without any argument :tu:
  • Hack Virtuoso
Reply #57 on: April 26, 2013, 03:42:43 PM
Fingers crossed the BO parts and the new steel scales get here today.
If so, this weekend is going to be bad a$$ juice time.
Why stop now?
  • Hack Virtuoso
Reply #58 on: April 27, 2013, 02:18:56 AM
Teaser pic. A whole lotta fitting still needs be done.
Why stop now?
us Offline carlb
Reply #59 on: April 27, 2013, 02:57:35 AM
Nice!
NOTErized!
