Login
Register
Menu
Home
Help
Forum
Tool Talk
Leatherman Tools
Difficulty with Blade Deployment
alanmoortician
7 ·
2407
« previous
next »
Print
Pages:
1
Go Down
alanmoortician
Newbie
27
on:
March 21, 2013, 06:54:12 PM
Hi guys,
The clip point knife on my Surge is a lot harder to deploy than the serrated blade on the other side. The serrated blade swings out smooth and with little resistance, but the clip point knife seems to be "stuck" and requires much more force to push out into the deployed position.
I was wondering if any of you fine folks could help me fix this problem? Has anyone else experienced this?
Delta10
Jr. Member
65
Re: Difficulty with Blade Deployment
Reply #1 on:
March 21, 2013, 07:46:09 PM
Sounds like the pivot is tighter on the one side. I'd loosen it a hair and see if that makes a difference.
kkokkolis
Absolutely No Life Club
6,354
Τετραφάρμακος
Reply #2 on:
March 21, 2013, 07:58:21 PM
I am an absolute beginner with a Surge (or any Leatherman) and I had the same problem. It was easy to fix the tension with the proper Torx (I believe it is T10- beware, the Leatherman bits aren't suitable, you need a "safety" Torx with a hole in the middle). Don't turn it too much. It might get easier with use.
Penny Folders
My SAKs & MTs
My EDC & SDC
Merit Badges
CanadianLMfan
No Life Club
3,334
All Lurkers Please Join :D
Reply #3 on:
September 11, 2013, 11:22:17 PM
I have trouble with my Wave's blade, too.
You need to loosen the screw for easier blade deployment.
Leatherman
captain spaulding
Absolute Zombie Club
20,793
What's the matter, kid? Don't ya like clowns?
Reply #4 on:
September 12, 2013, 12:09:30 AM
Is the tool New or Used? It could just need a good cleaning to clear out gunk from inside the pivot. If its new it will most likely loosen up with use. If it does not you might have to loosen the screw a tiny bit.
I'm the milk man!
Etherealicer
Admin Team
Zombie Apprentice
12,034
Reply #5 on:
September 12, 2013, 03:19:24 PM
My brand new charge did also not open smoothly, so I generously applied graphene, now its as smooth as Lieutenant Commander Data's Face.
Aloha
Global Moderator
Point Of No Return
31,235
Reply #6 on:
September 12, 2013, 05:06:26 PM
air in a can and 3 in one oil.
give the pivot a shot of air to dislodge any debris and a drop or so of oil and work the blade (open and close it ) while watching tv or sitting around. if its new it will loosen with use if that doesn't help on to loosening the torx screw a bit as others have said.
the above method worked on a used charge tti I got and I didn't have to loosen the torx. good luck.
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
Leatherman Tools
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$115.65
PayPal Fees:
$7.03
Net Balance:
$108.62
Below Goal:
$191.38
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
