When I thought I'd lost my black Climber recently, my dad said I could have his unused SAK that had been in a draw since he bought it. He handed me a red Climber - cool I thought
. Until I opened it and found some unidentified substance has got into one end and the small blade seemed to be corroded into place
It looked like the aluminium liner had corroded slightly jamming the blade. Using my somewhat sketchy knowledge of chemistry, I remembered that sodium hydroxide dissolved aluminum oxide and that I had some NaOH crystals... I made up a solution of the NaOH and while it was still hot (it does this itself
), I poured it into the end of the SAK and was surprised at the steam and vapour that appeared when it hit the aluminium. After a few seconds I rinsed it out and dried the knife on radiator for a few hours.
After a sparing lube with mineral oil, the knife is as good as new!
- Or was I too preoccupied with other thoughts, like: if toast always lands jam side down, and a cat always lands on its feet, what happens when you strap a piece of toast, jam side up, to the back of a cat?
