P.S. I agree with JMJ - I would have gone at the plastic container with the main blade rather than the metal file.
You must have some really weird wood and plastic in Greece !
While I like the combo tool very much, it's too thin for more serious work.
Are you sure your knife is Swiss and not Chinese?
Obviously there are some jobs for which a SAK is simply not the right tool, and or your particular model lacks the right tool.
So we all agree on what was already the consensus: SAKs are flawless representations of perfection that can pretend to fail at a task when misused though they do so just for fun. Damn, I thought this could be a good topic . OK, back to my cave I go now.
Quote from: nate j on September 06, 2013, 12:44:03 AMObviously there are some jobs for which a SAK is simply not the right tool, and or your particular model lacks the right tool. That is why they should all have a partner or two. I've never had a SAK fail on me, except for the toothpick- they pick up too much crud for me to put in my mouth. That said, I've bought a bunch of them that are a little screwed up over the years for when I can have the space to start modding, and they are cases of someone forgetting that they have a pocket knife held together with 1/10" pins, not a prybar.
These are pocket tools. I'm not going to attempt to cut down a tree with my Huntsman or Farmer. I apply reasonable expectations to my tools and I'm not disappointed.
Quote from: sawman on September 06, 2013, 06:28:44 AMThese are pocket tools. I'm not going to attempt to cut down a tree with my Huntsman or Farmer. I apply reasonable expectations to my tools and I'm not disappointed. Yes, you can!(sort of) Although the tree is only limb thick, it really demo how skill is just as important as the tool.
Quote from: kkokkolis on September 05, 2013, 04:51:06 PMAre you sure your knife is Swiss and not Chinese? *Sigh* Yes, sure and certain. The sound these things make is practically inmistakable I think. So we all agree on what was already the consensus: SAKs are flawless representations of perfection that can pretend to fail at a task when misused though they do so just for fun. Damn, I thought this could be a good topic . OK, back to my cave I go now.
The greatest failures I can think of concerned the wood saw and the metal saw. The other time was this March. A wooden chair's foot rest had broken in half and leaving it that way was dangerous, someone was bound to get stabbed by its pointed remainings. I tried to remove it with the saw on my Vic Ranger. The wood was so dry it shrieked that awful sound and the saw kept bouncing off to no avail. I had to use an old hacksaw in the end.
The problem here is woodworking technique and the tool you chose. The hacksaw worked because the smaller teeth wouldn't skip on the grain (I assume the hacksaw blade had a metal cutting blade on it, as most do). The woodsaw has deep, aggressive teeth and using them for fine work, such as trimming broken ends, will cause the wood to splinter and/or the teeth will skip. Next time: start with the metal saw first in order to get a kerf, and then switch to the woodsaw. That should work better.Also, that shrieking sound you heard was the saw binding up. Any saw will bind if your technique is off.
My first Vic failed me slightly when someone borrowed it and tried to use the knife as a pry bar (despite there being a far more functional opener layer).
Ruining the knife by applying too much force on the back-mounted Philips seems to be a recurring problem. Also breaking the tip of the Vic combo tool and the Vic can opener (using it as a screwdriver). I have done neither myself, but a friend of mine ruined the can opener of his 84 mm Vic exactly that way.Having trouble sawing through hard, dry, fibrous wood with a rather "un-ergonomic" saw doesn't sound unreasonable to me.
