[Listed]Toftys Jigsaw Holder - USD 48.00
Guest · 1 · 214
EDCSource
  • Guest
on: January 22, 2014, 07:00:07 PM
I present my Jigsaw Holder tool, designed to hold both types of jigsaw blades (but primarily the larger type) and clip into the lanyard attachment slot on either a Leatherman Wave or Charge multitool (although not the Surge). The main body of the tool has been 3D printed in stainless steel with M3 threads tapped into its top. It comes with stainless steel grub screws and an 1.5mm hex driver bit. Due to the nature of the material it is possible to snap off the post with the locking notch in it, if handled in an excessively rough manner during installation and extraction. When purchasing this item the customer should specify which multitool; either the Wave or Charge, the Jigsaw Holder will be used on. This is because of slight differences between the two multitools which may require slight modification to the Jigsaw Holder to ensure the best possible fit. This shall be performed before the item is shipped. Although all effort will be made to ensure a perfect fit, due to subtle variations in the multitools themselves, this cannot be guaranteed. However a couple of minutes with a file or dremel type tool would be all that might possibly be needed. I would suggest that anyone intereste
Source: Toftys Jigsaw Holder - USD 48.00
Total Receipts: $10.00
PayPal Fees: $0.69
Net Balance: $9.31
Below Goal: $290.69
 3%
