Multitool.org
Skeletool Saw Holder 4208
Full Member Posts: 107
« on: April 05, 2014, 06:56:29 AM »
Just on a whim I took an extra t-shank blade and gently ground one of the T's to fit the Skeletool bit holder. The blade wobbles side-to-side, and can be wrestled out, but in actual use the saw stays put well enough to cut. I cut a #10 screw without issue.
I have a Surge and Crunch for my saw-holding needs, but die-hard Skeletool users might like this one, if someone hasn't already done it! Never hurts to have a hacksaw in your glovebox.
Re: Skeletool Saw Holder
« Reply #1 on: April 05, 2014, 07:19:37 AM »
I guess I should mention that my first photo is slightly smurfed. The grinding should happen on the side of the "T" that is going in the "valley" of the bit holder. The remaining "T" should be left untouched as that side engages nicely with the bit holder lock.
So in other words, you can choose the orientation of the teeth depending on which "T" you grind to fit.
Not only did I take a bad photo, I also (in my opinion) ground the wrong side!
Absolutely No Life Club Posts: 7,015
« Reply #2 on: April 05, 2014, 12:36:46 PM »
A solution for blade wobble: Skeletool Jigsaw Blade Mod
Absolutely No Life Club Posts: 9,733 You're amongst friends.
« Reply #3 on: April 05, 2014, 01:25:40 PM »
Superb mods my friend! I especially like the bit holder. :D
SAW
« Reply #4 on: April 05, 2014, 08:35:37 PM »
Great solution to the blade wobble Syncop8r. Shoulda' known someone already thought of this  :cheers:
Admin Team Absolute Zombie Club Posts: 23,213
« Reply #5 on: April 05, 2014, 08:43:52 PM »
A very useful mod though, thanks for sharing. :salute: Those little jig saw blades don't cost much, but boy would it ever be nice to have one along some day if you had to cut through a heavy wire fence or remove a padlock or the like. :tu:
« Reply #6 on: April 05, 2014, 08:50:03 PM »
I agree J-sews; being able to cut metal is a big slice of the utilitarian pie. It's really neat to have that kind of capability, all in a small pouch by your side 24/7.
Newbie Posts: 24
« Reply #7 on: October 10, 2018, 07:38:42 AM »
Does anyone have a link to the video posted that eliminates blade wobble? Or just a short description of how to do it?
Thanks!
« Reply #8 on: October 10, 2018, 08:38:05 AM »
I can't remember what it was.  :facepalm:
Maybe shrinkwrap around the blade end.  :dunno:
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $5.00
PayPal Fees: $0.49
Net Balance: $4.51
Below Goal: $295.49
 2%
June Donations
Page created in 0.05 seconds with 32 queries.
© 2018 Defender Web & Tool
