Show off your Sak mod's!
wales Offline magentus
  • mmmmm SAKrelicious
Re: Show off your Sak mod's!
Reply #5130 on: January 17, 2018, 02:14:57 PM
After using the E Blade Farmer I realised I needed the main blade more so the Farmer has been rebuilt as a standard Farmer. Well, not quite. I added a hollow rivet.
Pics from Der Werkstatt last night and out 'n' about this morning:
Reply #5131 on: January 17, 2018, 09:14:08 PM
Nice job Mate but you would be better using a tile to work on  :whistle:
Reply #5132 on: January 17, 2018, 09:52:04 PM
I've been after several nice big tiles for a while now.
Reply #5133 on: January 17, 2018, 10:09:25 PM
Speechless  :D
us Offline David Bowen
  • Multitool Enthusiast
  • Site Manager
Reply #5134 on: January 17, 2018, 11:02:15 PM
My custom saks.
Tinker with orange G10 and Aluminum handle
Vic Scientist made from spare parts
Cadet with blue died bone handles
Vic soldier with bone handles and nickel silver bolsters
Sent from my SM-G935V using Tapatalk
se Offline stoneshank
Reply #5135 on: January 18, 2018, 12:59:47 AM
My custom saks.
Drrrrtooooooool
Sent from my SM-G935F using Tapatalk
  • Site Manager
Reply #5136 on: January 18, 2018, 01:16:04 AM
My custom saks.
Drrrrtooooooool
I think the tinker is titanium and G10 but the guys says he was sure it was aluminium. How would I tell? Both are non magnetic
Sent from my SM-T377V using Tapatalk
Reply #5137 on: January 18, 2018, 04:12:43 PM
Hardness of it should give you some info. If you can find an angle where you can try to inflict a small dent. Or if you can remove the scales to find an unseen side maybe? Looks great though!
wales Offline hiraethus
  • I brake for cake
Reply #5138 on: January 18, 2018, 04:54:49 PM
Set fire to it?  >:D
Reply #5139 on: January 18, 2018, 04:57:12 PM
Reply #5140 on: January 20, 2018, 02:27:35 PM
"Whittling Recruit" - 2xRecruit with a MFV saw between. It's meant to be used for when I whittle away from home, around non-knifey peebles :)
au Online Huntsman
Reply #5141 on: January 20, 2018, 11:00:24 PM
Looks interesting SS - Nice work - Thanks for posting
Can you show us all the tools and summarise the mods please
Looks like you:
- Added a saw layer
- Added a full blade layer - with the main blade converted to a Wharncliffe blade
- Converted the CO SD into a narrow SD - Or is that a chisel (for whittling)
- File work on the back of all tools
- Looks like there is another layer ???
Thanks
PS. Weird seeing snow given we are in the middle of summer - It's been up to 40° recently !!
Reply #5142 on: January 21, 2018, 01:32:45 AM
Looks like you:
- Added a saw layer
Thanks
The base I built on is a recruit. The recruit has two wharncliffe blades and I indeed made wood chisel out of the openers. I removed the fin on the can one ship I got a small plain chisel and a larger (bottle). I wanted to try out sakmodding mostly because of the challenge and partly to offer myself more tools.
I added a MFV wood saw at the center and the another recruit on the other side of it. I turned the small blade into a clip point (ish) and the large one I left in a disaster. I did the same mod to the openers but made them concave to add versatility.
Caveat; nothing is perfectly made. This was my first try at a full mod, once only reshaped blades before and made some wooden scales so this was a new, but fun!, challenge.
I have already dismantled it. I webbed to clean all the parts up, redo some things that I learned from and change in the MFV blade (made into a sheepfoot blade) instead of the failed main-blade.
Next up- how do open this? Placing new nailnicks is hard so I might try (already have) nailnicks continuing across the backside of the blade. I might also try to get tools to thread a screw down into the back (Emerson style? Haha) .
My roomie had to go to bed early so I left things halfway (tried this time to thin the pivots before I cut it up into four small ones)  . This is so much fun!
Reply #5143 on: January 21, 2018, 08:35:48 PM
The bushings that I peen the pivot at, which side of the bushing should be turned outward? It's the wider right? F.... Ah well, will try a third time sometime later ;)
Reply #5144 on: January 21, 2018, 08:56:53 PM
Yes the wider side should look outwards.
Good luck!
id Offline jaya_man
Reply #5145 on: January 22, 2018, 04:30:28 AM
Good luck!
For a better illustration...
Reply #5146 on: January 22, 2018, 03:36:58 PM
Good luck!
For a better illustration...(Image removed from quote.)
Thanks.
The way I built it up is:
1. Opener layer
2. Knife layer
3. Wood saw layer
4. Knife layer
5. Opener layer
So one of the recruits are reversed. This makes the small knife+ keyring thingie reversed too and some other results because of the way I want it in the layer order. The opener layers "has"  to be the furthest out so I can use them the way they are intended (wood chisels) (picture 1)
Knife layers are pretty straight forward. Two wharncliffes, one clip point and one sheepfoot. Blades are currently functional but ugly AF. (picture 2)
Wood saw layer is probably the only one I have not screwed up yet (picture three)
Last but worst is that the clue that the toothpick/pincer is on opposite side of the keyring (picture 4) which means I pretty much assembled everything wrong HAHA!
I'm having a very good time with this, albeit very humbling. I wrong into the project with a clear idea what I wanted, clear expectations of success and a 100% "Jesus take the wheel" attitude and my ad hoc way of doing things. Some times things work out, some times they don't and you learn something instead.
Sent from my Victorinox Climber using Tapatalk
« Last Edit: January 22, 2018, 03:42:18 PM by stoneshank »
Reply #5147 on: January 23, 2018, 07:40:19 PM
Ok! Forth time's the charm! We don't talk about the third.
Got it all together now, sorted out nailnicks and started evening out the rough areas.
us Offline ironraven
Reply #5148 on: January 24, 2018, 03:47:20 AM
When you turned the bottle opener into a chisel, did you use a grinder or just a stone and/or sandpaper? And what angle?
I've been thinking about doing something similar with a spare Camper.
se Offline Fortytwo
Reply #5149 on: January 25, 2018, 11:12:49 PM
And does it keep an edge? I tried getting an edge on the inside of the of the opener, like on the older models, but couldn't seem to get it any sharp. Might just be me though.
Reply #5150 on: January 26, 2018, 01:52:03 AM
I used a Mora diamond sharpener. It didn't really take much time and while, due to the steel , you have to go over the edges when you whittle every now and then, the chisels really surprised me at how well they work!
The second set of openers on the other side of the layers are curved (concave) to give me more options. The canopener tool turned out to be too narrow to make concave so it it more V-shaped atm which is good for making lines.
I'm reassembling it all together tomorrow againto see if I can get a 5 layer 84mm to work. So far I've done rookie mistakes but learned each time so hopefully this v4.5 will be ending nicely. If not I might reconsider the wood saw layer to keep it more compact.
 Speaking of compact ! I got impressed by someone's compact with wood saw earlier so I might do that as I will have a spare saw.
Back again about sharpening- uttering a Tormek t4 would be best but not needed. Victorinox steel is rather easy to reshape.
Sent from my wood fire using smoke signals
« Last Edit: January 26, 2018, 01:54:12 AM by stoneshank »
se Offline Fortytwo
Reply #5151 on: January 26, 2018, 12:49:23 PM
I see, guess I'll try to invest a little more time then and see if that solves it.
  • I brake for cake
Reply #5152 on: February 24, 2018, 10:54:20 PM
My latest creation:
Yeah, OK, it's a Climber and the only thing out of the ordinary is the ground-off keyring loop. But I made it from leftovers because a) I don't have a three layer SAK with scissors and 2) I haven't built a SAK for at least a year.  Good to be back at it. :D
Reply #5153 on: February 24, 2018, 11:06:30 PM
great mods  :salute: I made some stagalike scales from micarta for my Super Tinker  :tu: I'll do some for my waiter next  :salute:
Reply #5154 on: February 24, 2018, 11:15:03 PM
My latest creation:
Are those white scales?  ???
  • I brake for cake
Reply #5155 on: February 24, 2018, 11:25:25 PM
No, yellow.  smurfty photo. :P
es Offline ThePeacent
Reply #5156 on: February 25, 2018, 04:04:04 PM
 :like: those scales!!   :tu: :tu:
My toys:
se Offline kottskrapa
Reply #5157 on: March 08, 2018, 10:43:58 AM
Latest work! Used the wrong liner and will change the scales after it is used for a while.. Knife less and thanks Pablo for some tips
Reply #5158 on: March 08, 2018, 10:47:29 AM
Nice work! Good to see more bladeless mods recently  :cheers:
Reply #5159 on: March 08, 2018, 11:16:19 AM
Thanks! Yes and I got really inspired.. Feels good to have an option other than the style ps for when not being able to bring something with a blade
