Show off your Sak mod's!
Re: Show off your Sak mod's!
Reply #5430 on: May 06, 2020, 04:12:34 PM
That's cool. :like:
id Offline jaya_man
Reply #5431 on: May 06, 2020, 04:16:50 PM
Thanks Pabs :hatsoff:
00 Offline o_6
Reply #5432 on: May 13, 2020, 08:57:14 AM
it Offline SirVicaLot
Reply #5433 on: May 13, 2020, 03:38:40 PM
Very cool scales!  :like: 8)
Reply #5434 on: May 13, 2020, 07:12:33 PM
Very nice set of tools, too!
 :tu: :tu:
us Offline rfogle
Reply #5435 on: May 14, 2020, 02:49:54 PM
Hi all! I joined quite a while ago to ask a few questions but didn't have much to contribute personally. I've been getting into modding recently and now I have something to show off  ;)
Here's my daily driver, a Classic SD with brass scales made my me, put together with stainless steel hardware. I put it together "backwards" because I use the knife more than the scissors, and it has always bothered me a bit the the knife points toward the keyring. Next up I'm working on a Waiter with a pocket clip, which I think would be the perfect picnic knife.
Reply #5436 on: May 14, 2020, 03:29:45 PM
That looks nice! Could we see a close-up of the classic please?  :popcorn:
Reply #5437 on: May 14, 2020, 05:29:55 PM
+1 and +1
 :cheers: :tu:
fr Offline m47mu74nt
Reply #5438 on: May 14, 2020, 06:54:14 PM
THIS is way nicer than my own TrailGuide interpretations !!
but mine has a chisel instead  :whistle:
us Offline rfogle
Reply #5439 on: May 14, 2020, 07:28:59 PM
Here ya go  :)
It occurred to me this morning that if I put the knife on the other side, I could have it go the direction I wanted while keeping the "Victorinox" stamping on the front. The way it is now, the stamping is on the back. I'll have to remember that for the next one!
Reply #5440 on: May 14, 2020, 07:58:07 PM
Here ya go  :)
Can't you just unscrew the scale and turn it around? The alignment is pretty much the same, right?
 :think: :think:
Reply #5441 on: May 14, 2020, 09:21:40 PM
Here ya go  :)
Very nice, thank you!  :cheers:
us Offline rfogle
Reply #5442 on: May 14, 2020, 11:06:42 PM
 :think: :think:
I could, but I don't care that much haha! Good excuse to give this one to a friend and make another.
Reply #5443 on: May 15, 2020, 07:41:04 AM
Always good to make new friends :D
Reply #5444 on: May 15, 2020, 05:19:40 PM
 :D :D :D :D
au Offline Jspiggle
Reply #5445 on: May 18, 2020, 02:31:12 PM
I know Ive got my own thread but just gotta slip this one in here  ;) ;) ;) They aren't spydernox for once  :o
au Offline Huntsman
Reply #5446 on: May 18, 2020, 04:03:13 PM
Great stuff JS and RF  :hatsoff:    :tu:
us Offline rfogle
Reply #5447 on: May 21, 2020, 04:50:17 PM
Here's a new one - a Rambler with brass scales and liners. I like the engraving on this one better than the debossed cross on my Classic, plus it was easier to make. Found some stainless Torx hardware too.
Reply #5448 on: May 21, 2020, 08:58:34 PM
Very nice!  :drool:
Reply #5449 on: May 21, 2020, 09:10:55 PM
Did a quick combo tool mod today. It always bothered me that the Compact doesn’t have a means to turn a #2 Philips. They are the most common screws on my premises, so a SAK without a Philips is annoying. The combo tool is just slightly too large at the tip to fit into a Philips head, so I figured I take the disc sander and see if I can fix that.
Plan was to take off a bit of the upper rim, so the bottle/can opener function still works as intended. I did it on my waiter first, being the cheaper SAK and all.
Here is the before in comparison with the tip of the regular can opener:
Here it is after. Works just just fine now:
 Due to the angle of the combo tool it is slightly out of alignment with the screw head angle. Means the butt of the SAK turns in a larger circle than the tool when using it. So, I would not use it extensively, but it is good enough to fasten the occasional loose screw  :cheers:
za Offline Max Stone
Reply #5450 on: May 21, 2020, 09:46:43 PM
Good mod Sir Vic.  :like:
Combo tool is definitely in the butt category for me.  :facepalm: I’ve switched back to having an opener layer...stronger, more versatile tools, and I get to keep my small blade. I’ve learnt to live with the extra couple mm.  :cheers:
Reply #5451 on: May 21, 2020, 10:46:45 PM
 :cheers: This little adjustment fixed the biggest issue I had with the combo tool.
id Offline jaya_man
Reply #5452 on: June 12, 2020, 01:35:48 PM
Am currently doing a mod for a relative... while waiting for the actual scales to arrive (being anodized from standard silver to a different color) thougt I’d practice peening... and boy is it still far from perfect :facepalm:
Reply #5453 on: June 12, 2020, 01:45:40 PM
Nice job jaya. I would be very happy with that peening. Especially for a user :tu:
pt Offline FInixNOver
Reply #5454 on: June 12, 2020, 01:46:45 PM
X2
Enviado do meu Redmi Note 9 Pro através do Tapatalk
id Offline jaya_man
Reply #5455 on: June 12, 2020, 01:47:24 PM
It’s still a work in progress... unequal height to the peens...
Reply #5456 on: June 12, 2020, 01:49:09 PM
Of course you can always send it to the Netherlands if you're unhappy with the result.
id Offline jaya_man
Reply #5457 on: June 12, 2020, 01:49:42 PM
Reply #5458 on: June 12, 2020, 01:51:43 PM
:dunno:
I could try.
But seriously I like your modding work.
id Offline jaya_man
Reply #5459 on: June 12, 2020, 01:54:34 PM
I was actually busy doing Jalox clones to give to my sons when they’re old and responsible enough...
