Question about 91mm saw / metal file / fishscaler backsprings
Quartz · 37 · 4420
Offline Quartz
Re: Question about 91mm saw / metal file / fishscaler backsprings
Reply #30 on: September 17, 2014, 12:24:45 AM
Here is a bunch from, your guess is as good as mine.
LOL, ok. Didn't realize you had a pile of raw parts, I thought you threw that together from some other knife you were currently working on.
And yes, I think the grey mag / long driver switchover was around 2007 area. I'm less concerned about that, since the new shorter driver is good enough and leaves more space for other options. The catch stop is a little weird, but that can be ground down easily enough if need be.
Offline Quartz
Reply #31 on: September 17, 2014, 12:25:42 AM
The scissor spring is a lot narrower than the phillips though, right? Would that still work reliably?
us Offline GigaHz
Reply #32 on: September 17, 2014, 12:28:12 AM
2.4mm is what I get for a scissors back spring.
Offline Quartz
Reply #33 on: September 17, 2014, 12:36:48 AM
So 2.75 for the phillips vs 2.4 for the spring.  Based on your measurements for the saw/file, I guess .1mm is normal, but this is like .35mm. I don't really know a lot about metallurgy or metal stress tolerances, would a difference that large cause problems long term? (If I'm going to go through the effort of building this damn thing, I'd like it to last a good decade).
us Offline GigaHz
Reply #34 on: September 17, 2014, 12:39:14 AM
New vs old Phillips spring.
Offline Quartz
Reply #35 on: September 17, 2014, 01:32:34 AM
Thanks for all your help btw.
us Offline GigaHz
Reply #36 on: September 17, 2014, 01:40:36 AM
No problem.
