They should choose the Surge arrangement for the next generation of Wave/Charge.
Besides that, I do think you need to somehow make the clip more matching, too
Nice one, with superb finish!What is the method for oxidizing? By heating or something like that?
that's bad a$$
Quote from: Psycopyro on February 22, 2016, 09:22:37 PMNice one, with superb finish!What is the method for oxidizing? By heating or something like that?OXYAction, Napisan etc laundry whitening/brightening products you can get for few $$ in supermarkets.Simple and cheap, but very effective.
Finally got around to finish my 'Oxy-ReCharge' project today. Since for me the MTs need to not only work well but must also look good (Zoidberg, get that smirk off your face! ) I sometimes put a little too much emphasis on the appearance, but can't help it, sorry So I decided to oxidize the Ti scales to force that well known darker shade of Titanium that normally takes years to develop by a normal oxidation process, plus few extra details you don't see everyday done on an MT.Mods:- Swapped stock Charge pliers with the Rebar pliers with replaceable wire cutters.- Awl also from Rebar - this one wasn't a simple drop in as it required a little bit of 'meat' taken off the top arch closer to the tip so that the pliers would close properly inside the handle. - Oxidized Ti scales; although not that visible from the photos, these are now 2-3 shades of gray darker than the original Ti scales. I'll see if I can borrow a standard Charge TTi from a colleague of mine sometime next week for comparison photo.- Blued pivot screws; I originally wanted to acid etch these but like the blued finish better this time as it's near perfect fit with the Ti scales, almost identical. You wouldn't tell the scales and screws are made from a two very different materials.- Flattened the dome on screws. While I like button top screws very much, I found a flattened top being in sync with the flat edges of the Ti scales. You may like this or not, but I believe LM should have included slightly flatter screws on a factory standard Charge.Anyway, that's about it and I'm really stoked how it all came out in the end. (Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
Quote from: pietervn on October 22, 2014, 09:39:44 AMG'Day,That looks REALLY good. I'm a big fan of the Ti Charge, and darkening the scales looks fantastic. Would you mind sharing how you did it?I have heated a set of scales for the rainbow effect, but I think this looks very nice, almost gunmetal gray. Never thought about the screws, I might give them a bit of heat... Well done,PeteThanks mate...not hard, oxidized them for about 15mins. Will drop you a PM. Cheers.
Quote from: babola on October 21, 2014, 12:19:22 PMFinally got around to finish my 'Oxy-ReCharge' project today. Since for me the MTs need to not only work well but must also look good (Zoidberg, get that smirk off your face! ) I sometimes put a little too much emphasis on the appearance, but can't help it, sorry So I decided to oxidize the Ti scales to force that well known darker shade of Titanium that normally takes years to develop by a normal oxidation process, plus few extra details you don't see everyday done on an MT.Mods:- Swapped stock Charge pliers with the Rebar pliers with replaceable wire cutters.- Awl also from Rebar - this one wasn't a simple drop in as it required a little bit of 'meat' taken off the top arch closer to the tip so that the pliers would close properly inside the handle. - Oxidized Ti scales; although not that visible from the photos, these are now 2-3 shades of gray darker than the original Ti scales. I'll see if I can borrow a standard Charge TTi from a colleague of mine sometime next week for comparison photo.- Blued pivot screws; I originally wanted to acid etch these but like the blued finish better this time as it's near perfect fit with the Ti scales, almost identical. You wouldn't tell the scales and screws are made from a two very different materials.- Flattened the dome on screws. While I like button top screws very much, I found a flattened top being in sync with the flat edges of the Ti scales. You may like this or not, but I believe LM should have included slightly flatter screws on a factory standard Charge.Anyway, that's about it and I'm really stoked how it all came out in the end. (Image removed from quote.)(Image removed from quote.)(Image removed from quote.)wow! amazing! ... very good works ...can you please tell me how you darken the titanium?
Babola's Acid Wave project
Quote from: zoidberg on June 20, 2016, 11:50:41 AMBabola's Acid Wave projectThat method (acid etching using ferric chloride) works on steel, copper etc but doesn't on Ti, unfortunately. Ti darkens thru oxidation.
Secondly, after I posted my Oxy-ReCharge mod over at EDCF couple of members over there asked me if I could post my next mod in steps, kind of tutorial style.
To darken Titanium, it has to oxidize. I use simple and cheap method with Napisan, OxyClean or any other oxidizing stain remover you can find in your local supermarket.Warm up the water in a small container, add powder (approx 1 Tbsp per cup of hot water), agitate slowly and wait. Remove the Ti bits from liquid and wash under the tap. Repeat as required to reach desired darkness.Nothing to it, really.
