Great find! Can you list the benefit on tools compared to the original Victorinox bits?Original bits:Slotted 3mm, 4mmPhillips 0, 1, 2Torx 6, 8, 10, 15Inbus 1.2mm, 1.5mm, 2mm, 2.5mm, 4mm
This one.
Quote from: coSAK on November 28, 2014, 12:42:01 PMGreat find! Can you list the benefit on tools compared to the original Victorinox bits?Original bits:Slotted 3mm, 4mmPhillips 0, 1, 2Torx 6, 8, 10, 15Inbus 1.2mm, 1.5mm, 2mm, 2.5mm, 4mmPZ0 / PZ00Torx 7&9Adapter to 1/4" square (see picture 2 bottom center)Also a screwdriver is superior/faster if you have tons of screws.
I use the 4mm bits from a generic screwdriver set from Home Depot, cost about $5 for 50+ bits of all types. A small magnet JB-welded into the cybertool holds the ball-less bits perfectly.I made a couple of extensions from the parts left over, one is a 4mm extension, the other is an extension that goes from 4mm to 1/4". Covers all bases. There's a thread or two on the best parts etc.
Quote from: kkokkolis on November 28, 2014, 12:47:59 PMThis one.Do this bits work with the CT (without adding a magnet)?
Quote from: Etherealicer on November 28, 2014, 12:53:53 PMQuote from: kkokkolis on November 28, 2014, 12:47:59 PMThis one.Do this bits work with the CT (without adding a magnet)?No, they are regular 4mm, but I added a magnet anyway. Yours have springed balls, I missed that detail.
Great find, Beat. How much does the bit kit go for?
Can your say that again?
Quote from: enki_ck on November 28, 2014, 10:54:59 PMCan your say that again? You easily pay $10 for a beer in Zurich ($20 for an exotic might be exaggerated)
Quote from: Etherealicer on November 28, 2014, 11:17:24 PMQuote from: enki_ck on November 28, 2014, 10:54:59 PMCan your say that again? You easily pay $10 for a beer in Zurich ($20 for an exotic might be exaggerated)Yeah, quite crazy prices really. You should came here for a few Even if you travel by plane it might be cheaper than going out for a night on a town in Zürich. Domestic is a bit over $2 and most of the other stuff you can get for under $3. (in bars that is) Any special brews might cost a bit more but nowhere near Swiss prices.
Quote from: neillcurrie on November 28, 2014, 02:27:23 PMI use the 4mm bits from a generic screwdriver set from Home Depot, cost about $5 for 50+ bits of all types. A small magnet JB-welded into the cybertool holds the ball-less bits perfectly.I made a couple of extensions from the parts left over, one is a 4mm extension, the other is an extension that goes from 4mm to 1/4". Covers all bases. There's a thread or two on the best parts etc.Agreed, for a lot of applications a magnet is the solution. However, I get a bit paranoid if I have to replace the CPU fan on Server that has to go back on-line ASAP. I don't like to take chances on these occasions despite the fact I have never had problems with magnetic bit-holders.
Quote from: Etherealicer on November 28, 2014, 02:47:57 PMQuote from: neillcurrie on November 28, 2014, 02:27:23 PMI use the 4mm bits from a generic screwdriver set from Home Depot, cost about $5 for 50+ bits of all types. A small magnet JB-welded into the cybertool holds the ball-less bits perfectly.I made a couple of extensions from the parts left over, one is a 4mm extension, the other is an extension that goes from 4mm to 1/4". Covers all bases. There's a thread or two on the best parts etc.Agreed, for a lot of applications a magnet is the solution. However, I get a bit paranoid if I have to replace the CPU fan on Server that has to go back on-line ASAP. I don't like to take chances on these occasions despite the fact I have never had problems with magnetic bit-holders.I wouldn't worry about losing any bits that are held in just by a small magnet.I did the magnet-add to my cybertool, and I can pick up the whole CT34 using just the bit in the holder and swing it around. Those magnets are incredibly strong, yet you can get the bits out of the holder OK. Maybe not so if your hands are slippery with oil or grease
Quote from: neillcurrie on November 28, 2014, 02:27:23 PM[...][...]I get a bit paranoid if I have to replace the CPU fan on Server that has to go back on-line ASAP. I don't like to take chances on these occasions despite the fact I have never had problems with magnetic bit-holders.
I'm not worried about loosing bits, its sheer paranoia concerning the mixing of magnets and electronics
Quote from: Etherealicer on March 24, 2015, 05:09:07 PMI'm not worried about loosing bits, its sheer paranoia concerning the mixing of magnets and electronics Not a problem. I've used magnetic screwdrivers for over a decade servicing office electronics and computers without issue. NOT having a magnetic screwdriver is a bigger issue. Dropping one screw can make a 1/2 hr job last all day...
But, that is the time when you should NOT be changing your procedure or equipment. You should be doing what you have always done, with the equipment you always use, so mistakes are less likely to happen.
Any recommendations on where to purchase these tiny magnets? Sent from my iPad using Tapatalk
Quote from: BASguy on March 26, 2015, 05:05:05 AMAny recommendations on where to purchase these tiny magnets? Sent from my iPad using TapatalkAmazon USA, and ebay has lots of them. I went for about 20 from a Hong Kong supplier, and they came fast, and for about $1.99 shipped. They are amazingly retentive of the CT bits.
Amazon USA, and ebay has lots of them. I went for about 20 from a Hong Kong supplier, and they came fast, and for about $1.99 shipped. They are amazingly retentive of the CT bits.What keyword search did you use? I can't seem to locate them.Sent from my iPhone using Tapatalk
