New SOG multis?
rdub934 · 87 · 11259
us Offline rdub934
Re: New SOG multis?
Reply #60 on: January 24, 2015, 10:43:35 PM
Still, though, this probably matches up comparably to other light duty, pocket-carry tools such as the Gerber Balance or Octane, or the Leatherman Skeletool (which is known to fail if used for heavy tasks).
ch Offline Etherealicer
Re: New SOG multis?
Reply #61 on: January 24, 2015, 10:53:35 PM
That is exactly my question. How bad is it? I mean the last task my pliers had to fulfill was shortening wooden skewers to the shashlik would fit into my frying pan :D
Re: New SOG multis?
Reply #62 on: January 24, 2015, 11:16:21 PM
Not even close!
Look at the Skele, Balance and Octane, and how these forces are transmitted to the head. The go back to the pic above. Remember that pathetic little pin is only on one side of the head. Think how wire cutters are sited very close to the pivot to be most effective, well that pin is even nearer and so subjected to more force, is only in a cast material (not usually good with tensile or shear forces), and will gradually weaken with every use. Having never broken my original Switchplier (because I don't use it), I can't be more definitive in what the breaking point is ...
At a guess, I'd say Dime would be a nearer comparison, because if you overload those the backspring buckles - but remember you are trying to stay at that level of duty on a fuller sized tool where it's very easy to apply that little bit too much force
us Offline JAfromMn
  • Stranger in a Strange Land
Re: New SOG multis?
Reply #63 on: January 24, 2015, 11:54:12 PM
I love the looks of the new switch pliers.
It's to bad it won't be a quality tool.
Defend the Hive!!!
ca Offline Syph007
  • SAK Surgeon
Re: New SOG multis?
Reply #64 on: January 25, 2015, 04:29:11 AM
If its the same cast pin design and it breaks, I'll drill it out and replace it with a hardened steel dowel pin.  :D
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Re: New SOG multis?
Reply #65 on: January 25, 2015, 05:13:51 AM
Just checked the Patents for the Switchplier:
Hand tool with retractable jaws US 5829329
Hand tool with retractable jaw assembly US 5957013
And is not being referenced recently by SOG
So you must be right Trad !  They didn't do anything to improve the mechanism.
That says 1998. I wonder if there the same now?
us Offline rdub934
Re: New SOG multis?
Reply #66 on: January 25, 2015, 04:00:34 PM
http://www.trademarkia.com/switchplier-75714205.html
I bet it is the same. Tradmarkia page for SwitchPlier - filed in 1999, but check this out, "REGISTERED AND RENEWED
3/16/2011". Have they been sitting on a re-release for 4 years? Lol
Re: New SOG multis?
Reply #67 on: January 25, 2015, 05:20:26 PM
Ok I'm totally ignorant when it comes to steel and such. But I conclude from the above, that the pin would hold if done from hardened steel, right? Now check the design again. Unlike the images of the Switchplier the pin is not part of the plier-head. So, maybe the original design was good, but they changed it when it came into production to save money. So, if I understand this correct, all we have to hope for is that they don't jump hoops and make it correct this time.
ca Offline Syph007
  • SAK Surgeon
Re: New SOG multis?
Reply #68 on: January 25, 2015, 05:32:41 PM
Yep most folders used hardened steel stop pins in construction and those take alot of shear force, so its totally doable.  I understand the convenience of having them cast as part of the plier head but that is a very weak design and Id be shocked if they repeated it blindly to have the same failure rate.  That would just be absurd.
Im excited to get one and take it apart though! :D
Offline Ryo Saeba
Re: New SOG multis?
Reply #69 on: January 31, 2015, 02:36:39 AM
I want one.
nz Offline babola
  • The Tinkerer
Re: New SOG multis?
Reply #70 on: January 31, 2015, 09:57:02 AM
EDC and OCD. A wicked mix.
us Offline JBW1
Re: New SOG multis?
Reply #71 on: January 31, 2015, 05:49:58 PM
Did the Wright Brohers draw that??
us Offline rdub934
Re: New SOG multis?
Reply #72 on: February 08, 2015, 12:51:51 AM
Pre-order on knife center for $43.95. I like that price a lot more than the $65 msrp
http://www.knifecenter.com/item/SOGSWP1001/sog-swp1001-switchplier-20-multi-tool-black-and-silver
ca Offline Syph007
  • SAK Surgeon
Re: New SOG multis?
Reply #73 on: February 08, 2015, 01:46:41 AM
The price worries me a bit actually.  Thats less that a power duo, and we all know what kind of quality processes those were constructed with.  I'll still buy one though.  :D
us Offline rdub934
Re: New SOG multis?
Reply #74 on: February 08, 2015, 03:25:06 AM
I see what you are getting at but I don't think it will be as garbagey as the PowerDuo. The SP2 uses the same implements that the good SOGs use, plus the locking system from the PowerLock. So I would be surprised if there were any more play than is found on the PowerLock. We will have to see about the pliers.
The price of the PowerDuo is a reflection on the Lock-Back knife first, multi-tool second nature of the PowerDuo, IMO
us Offline rdub934
Re: New SOG multis?
Reply #75 on: February 08, 2015, 09:48:18 PM
 :think:
http://mygunculture.com/two-handy-tools-from-sog/
Shopped, or something SOG considered/is considering for the future?
Re: New SOG multis?
Reply #76 on: February 08, 2015, 10:37:56 PM
Totally shopped
us Offline rdub934
Re: New SOG multis?
Reply #77 on: February 09, 2015, 12:19:10 AM
It doesn't look like it would be able to close the handles together all the way.
The fact that the handles look slightly different and that it has two flats, as well as a CE and SE blade had me thinking prototype
us Offline Demel
Re: New SOG multis?
Reply #78 on: March 09, 2015, 02:30:20 AM
I wonder if you will be able to swap out the file for scissors? I would even lose file and can opener for a pair of scissors.
Any news on a release date yet?
us Offline Kampfer
  • Tactical Desk Jockey
Re: New SOG multis?
Reply #79 on: March 09, 2015, 08:41:23 AM
You can order one from SOG web site right now.
us Offline Demel
Re: New SOG multis?
Reply #80 on: March 09, 2015, 10:22:23 PM
They have it up, but it just says coming soon.
us Offline Kampfer
Re: New SOG multis?
Reply #81 on: March 10, 2015, 12:07:57 AM
I will wait until retailers have them in stock to order one.
Don't want to pay MSRP ordering from SOG directly.
Back two months ago i was able to order it, but i didn't.
What is going on there? :think:
Offline Ryo Saeba
Re: New SOG multis?
Reply #82 on: March 15, 2015, 01:26:57 AM
Academy had the new switchpliers on the self today.
us Offline rdub934
Re: New SOG multis?
Reply #83 on: March 17, 2015, 04:05:00 AM
:think:
In regards to the image, which shows a Switchplier 2.0 with tools in BOTH handles, I asked the guy who posted the article with the picture in question and he says:
"This is from the media kit I picked up at SHOT Show. If I remember correctly, the “more tools” version is coming out soon."
Pretty cool.
us Offline Demel
Re: New SOG multis?
Reply #84 on: March 21, 2015, 12:38:16 AM
As I look at the switchplier, I keep thinking, "What if the other components (knife, drivers...) were available on the outside?" Is sog against outside access tools?
us Offline rdub934
Re: New SOG multis?
Reply #85 on: March 21, 2015, 01:53:35 AM
Apparently they are, lol. They would be my favorite MT company if they would update their designs.
us Offline Demel
Re: New SOG multis?
Reply #86 on: March 21, 2015, 02:05:54 AM
Ditto
