charge lanyard ring - silly?
danilo · 33 · 5006
it Offline danilo
on: February 01, 2015, 02:32:39 PM
Hi all,
so I have this Charge TTi I've bought less than a month ago, and after a few days I've attached a paracord lanyard to its fixed lanyard ring (the hidden one) to discover quickly after that it interferes with the scissors...  :facepalm:
now, are there any ring or something to attach to it and to which attach the paracord? how do you people use it? - it appears it has bended the ring a bit in less than a month already, today I took off the lanyard, but I've become a lanyard addicted staying here, and now I miss it so much!
Thanks in advance for any advice
Danilo
Re: charge lanyard ring - silly?
Reply #1 on: February 01, 2015, 02:38:11 PM
You can get one of the detachable ones. There are easy to take off and on.
it Offline danilo
Reply #2 on: February 01, 2015, 02:59:07 PM
hi ducttapetech,
I have it already as it came in kit with the charge, but I have the clip in its place, and I'm not replacing it as it's one of the best feature of the tool for me.
but thanks for the headup anyway
us Offline NKlamerus
  • Captain's Apprentice
Reply #3 on: February 01, 2015, 04:22:53 PM
hi ducttapetech,
Have you modded much? What if you added a hole to the pocket clip?
It would definetly require a drill press and some penetrating oil for a good clean cut.
Also, I know everyone has preferences, but why do you have to keep the picket clip if you lanyard carry?
Or maybe you could switch to a lanyard ring and a suspension Clip AND lanyard hanging off of it?
it Offline danilo
Reply #4 on: February 01, 2015, 05:03:54 PM
well I don't carry it with the lanyard, I use it to pull the tool out from the pocket, where it's secured by the clip.
Am I the only one doing that?
the thing is that it is quite handy this way, it would need some flat "ring" to attach the lanyard to the tool ring, I thought someone else had come to a similar solution here already and could help me with links or pictures...
us Offline genevabuck
Reply #5 on: February 01, 2015, 06:57:07 PM
I think the detachable lanyard ring that Leatherman has will suit your needs.
it Offline danilo
Reply #6 on: February 01, 2015, 07:03:13 PM
actually, as I said, no
but thank for your time anyway!
il Offline dan.mandiel
  • i need a surge :cry:
Reply #7 on: February 01, 2015, 07:19:17 PM
i had this problem too but what i did was that i just took off the hidden lanyard ring and now i have space to put the clip and the ring :tu: let me know if i can help :cheers:
« Last Edit: February 01, 2015, 07:22:01 PM by dan.mandiel »
- Ok sir, we've found this good multitool without scissors-
-scissors.
- but sir, we figured it might not have scissors but it does have almost everything you need for a good price! -
- scissors.
- but sir..-
- sci. ssors.
Reply #8 on: February 01, 2015, 07:21:58 PM
i had this problem too but what i did was that i just took off the hidden lanyard ring and now i have space to put the clip and the ring!
This.
It gives you a second attachment option for the removable lanyard ring.
Or you could simply attach the lanyard to the top of the pocket clip. ;)
us Offline Kampfer
  • Tactical Desk Jockey
Reply #9 on: February 01, 2015, 08:11:58 PM
This.
Yes, both men had good ideas, I was going to say the same.
Four ways to attach lanyard on Wave/Charge.
1. Hidden lanyard ring
2. detachable lanyard ring
3. Attach lanyard on clip
4. Remove hidden lanyard ring and attach lanyard on pivot post.
I don't like lanyard and Wave/Charge's deep carry clip sometime lead the tool stuck, so what I do is grab the tool outside of pocket ; give it a little push upward then pull it out. That works for me.
« Last Edit: February 01, 2015, 08:16:50 PM by Kampfer »
Reply #10 on: February 01, 2015, 08:23:59 PM
Reply #11 on: February 01, 2015, 08:24:36 PM
The simplest thing to do so far would be to just tie the lanyard to the top of the clip? Plus when you pull the lanyard it should pull it straight out of your pocket
it Offline danilo
Reply #12 on: February 02, 2015, 08:23:44 AM
OK,
thank you all for the suggestions!
I hadn't thought about replacing the fixed ring with the removable one (although it will present the same problem, except you can detach it to deploy the tool next to it, either the scissors or the bit holder).
Since the charge is quite new, I'm not into modding it as of yet, so I'll try some other ways before removing the fixed ring, or drilling the clip (this one would be a soft mod, as the clip is easily replaceable, but I see there isn't much space in there anyway...)
Anyway I was thinking that maybe some flat paracords, which I've seen in some videos, maybe they'll fit in there without mods? Has anyone tried them out?
Danilo
au Offline DazMechanical
Reply #13 on: February 02, 2015, 09:26:00 AM
I'm with the other guys! Remove the fixed lanyard ring, that's what I did with my wave and it works great. What this does is allow you to attach the pocket clip on either side so you can have your preferred blade ready for quick deployment straight out of the pocket, if you know what I mean. Using the standard pocket clip location in a right pocket it lends towards the plain edge blade being first preference, without flipping the tool over. Removing the fixed lanyard ring allows you to put your pocket clip there so the serrated blade is first preference out of the pocket for an emergency situation, eg. cutting your way out of a seatbelt in a flipped car leaking petrol onto you... Anybody else done this??
darren
Reply #14 on: February 02, 2015, 02:53:31 PM
OK,
Danilo
Well from what i tried gutted paracord doesn't work quite well.
I also have a quite new charge that im not afraid to mod because it is just taking a simple piece off.
I recommend storing the lanyard ring that you don't use  where you'd put the clip or ring when not in use :tu:
-scissors.
- scissors.
- but sir..-
- sci. ssors.
it Offline danilo
Reply #15 on: February 02, 2015, 04:12:45 PM
oh! you just made me realize I can unscrew the handle and remove the ring without cutting out anything.
I'm in for a reversible mod like that !
And thanks for the tip on how to not lose the small part :)
ok, so in the end I now need two t10s, I knew I was ending up buying something, I just needed to focus on _what_  :cheers: :cheers:
Danilo
Reply #16 on: February 02, 2015, 09:35:17 PM
Danilo
Unless they changed them like with the Surge you'll only need one t10 as the post is keyed and does not rotate.
The screw is on the pocket clip and lanyard sides of the handle. Heat the screw to break the loctite. Hope that helps.
us Offline Kampfer
Reply #17 on: February 02, 2015, 09:37:07 PM
You will need T-10 security bit. not the normal ones.
it Offline danilo
Reply #18 on: February 02, 2015, 09:41:32 PM
Danilo
oh I see, and I've read something about it before now that you say that...
thanks for the info, but how can I heat it up? with just a cigarette lighter?
p.s. I've mistakenly reported your message as spam while trying to quote it... darn Tapatalk... sorry
it Offline danilo
Reply #19 on: February 02, 2015, 09:42:36 PM
yes thanks, I thought t10s was their name...
Reply #20 on: February 02, 2015, 09:59:21 PM
Danilo
Yeah a lighter works fine. No stress re the spam report mate.  :)
Reply #21 on: February 02, 2015, 10:40:50 PM
Danilo
Yup, the bottom, inside tools pivot pin is D shaped so one screwdriver should be enough. I'm just not sure which side is the actual screw. :P
If you ever decide you need to tighten or unscrew the plier pivots, then you'll need two screwdrivers.
it Offline danilo
Reply #22 on: February 02, 2015, 11:05:40 PM
ah the other side  isn't d-shaped, nice to know.
but I also understand tightening the pliers end screws doesn't make the plier head tighter, I can't remember the thread I l've read it in, but someone said it just acts on the external tools tension (blades, file and saw)
nice to know anyway,  thanks
Reply #23 on: February 02, 2015, 11:36:33 PM
Correct. :tu:
us Offline Kampfer
Reply #24 on: February 03, 2015, 06:52:52 AM
A 15mm split ring will do the trick:
Simply slide it on clip, once clip in place the split ring won't fall out.
Tool can be pull out quickly with index finger.
The ring is small enough not to interfere the usage of any implement.
« Last Edit: February 03, 2015, 09:47:55 AM by Kampfer »
nz Offline Syncop8r
Reply #25 on: February 03, 2015, 09:50:19 AM
Danilo
Standard response to Zoidberg posts right there.^
Reply #26 on: February 03, 2015, 09:54:51 AM
Danilo
Exactly.  :D
us Offline Kampfer
Reply #27 on: February 03, 2015, 08:32:26 PM
My solution to an issue I didn't even bother to resolve until now.
http://forum.multitool.org/index.php/topic,51718.msg1034292.html#msg1034292
it Offline danilo
Reply #28 on: February 03, 2015, 08:45:47 PM
lol,
it is also a nice idea, and one can attach the lanyard to the ring and fix my problem as well, I'll try it out!
us Offline Kampfer
Reply #29 on: February 03, 2015, 08:54:14 PM
I am not a fan of lanyards, but do what you gotta do. :tu:
October Goal: $300.00
Due Date: Oct 31
Total Receipts: $193.03
PayPal Fees: $9.58
Net Balance: $183.45
Below Goal: $116.55
61%
October Donations
