SOG Switch Plier 2.0
us Offline campussecurity
Re: SOG Switch Plier 2.0
Reply #150 on: September 13, 2015, 08:46:46 PM
I say just get one as well. It's great.
fr Offline hellsing
Reply #151 on: September 16, 2015, 07:39:41 PM
i'm weak, i just bought one, will have it in 2 weeks.
Impossible to find it in shop here in France, i bought it on the evil bay, 60$ with shipping, quite good deal.
Reply #152 on: September 17, 2015, 12:46:45 AM
Nice!
us Offline 3rdpig
Reply #153 on: September 20, 2015, 10:22:35 PM
Well, based on this thread I ran right down to my local Big5 and bought one.  They had one left and the box had been opened, but I bought it anyway.  There are no signs of use at all on it anywhere, so I'm guessing they opened it to show someone who didn't buy it.
My first impressions aren't that great.  The pliers are as gritty as hell and about half the time they won't deploy all the way.  Also, if I squeeze them shut and release slowly, they'll hang up halfway.  The inside tools are loose and wobbly and the plier handle has a 20 degree twist to it.  In other words, the typical Made in China Sog quality I've come to know and hate.
I'm going to clean it and lube it, tweak the plier handle straight and hopefully it will turn out better than the horrible Power Duo I own.
I want to like this tool, a buddy had an original Switchplier and he loved it but I could never find a decent one.  So I'm predisposed to liking it despite my bad experience with the Power Duo.
« Last Edit: September 20, 2015, 10:34:19 PM by 3rdpig »
Reply #154 on: September 21, 2015, 02:42:13 AM
Well mine was pretty good out of the box. And the Switchplier2.0 is made in Taiwan and I've had good experience with things from there. Have many blades made there and never a complaint.
us Offline 3rdpig
Reply #155 on: September 21, 2015, 03:09:17 AM
I'm happy that you got a good one, mine was awful.  If they had have had another one on the shelf I'd have taken it back immediately.  Not only was it gritty, it had a "detent" feel in the middle of the plier movement range where it would often stop when deploying or when squeezing and then releasing the pliers slowly.
Using a pair of channel locks and a shop towel, I tweaked the pliers handle back into alignment.  Then I adjusted the tension on the tools.
Then I soaked the plier head in a thin, abrasive solution I used for brass cleaning and then spent an hour or two working the pliers, both with the handle and by working the jaws themselves.  After that I washed it in degreaser, rinsed it and blew it dry with compressed air and relubed it.  Now it feels halfway decent.  It's still nothing to brag about, but it springs open freely and doesn't catch in the middle anymore.  It still has some tight spots, but at least it's not gritty anymore.  I can use it without grinding my teeth every time I squeeze the pliers.
I must have got one on the bad end of the quality spectrum, but that seems to be my luck with Sog, my last 3 tools from them have been terrible.  I expect my review of my Power Duo is still on the site somewhere.  I disassembled that and spent a few hours getting the worst of problems fixed.
us Offline 3rdpig
Reply #156 on: September 22, 2015, 03:09:15 AM
Well, after bitching about it, then fixing it, I have to admit that I like it.  In fact, I like it quite a bit.  Had it come out of the box the way it is now I'd have raved about it.  As it is, a little elbow grease for those that get a rough one is all it takes. I'm tempted to go to another Big5 tomorrow and see if they'll take one out of the package for me so I can compare it.
So far, ignoring the intitial problems, here are my likes and dislikes.
It's fun to play with.  No, that's not a joke, it IS fun to play with.
The pliers deploy quickly and fit together very nicely at the tip.  They are very usable and comfortable.
The wire cutters are a pleasant surprise, mine worked well on everything I tried them on including stranded, automotive wiring.
The phillips bit.  It fits in the screws I deal very well and folded out it makes for a very easy to use phillips screwdriver.
Overall build quality and materials seem pretty good.  It's a solid little package.
It has a belt clip.
Most of the inside tools are quick to deploy and stow.
Bottle opener works.
The knife blade is actually sharp.
Minor annoyances
The awl needs to be sharper and have a sewing eye.
The large, flat screwdrive blade is poorly shaped on the end, but a small file will fix it.
The file is a typical, non leatherman file, meaning it's fine for wood, plastic or soft aluminum, but useless on anything else.
I don't like partially seratted blades, but I know some people do, and this is a tool without a full seratted blade, so it's bearable.
The belt clip doesn't have a lot of holding power. It's OK, but I'd like to see a dimple or something to keep it from coming off a pocket so easily.
The tiny flat blade screwdriver is too sharp and poorly shaped, but a small file will cure that.
The phillips bit can't be accessed without deploying the pliers.
None of the internal tools locks up tight, they all have considerable wiggle.
The writing on the ruler is so tiny I have to use the mag glass on my SAK Explorer to read it.
Dislikes
The can opener is a sad joke.  It's not sharp, the "hook" is rounded and doesn't catch the lip of cans reliably and it's not shaped quite right.
That's it for now.  I've got a half dozen other Sog tools around, including a Power Lock, Power Assist, Power Duo, PPP and Paratool and a box of extra tool bits, so I may play musical chairs with some of the tools.
« Last Edit: September 22, 2015, 03:12:26 AM by 3rdpig »
hr Offline styx
Reply #157 on: September 22, 2015, 06:26:54 AM
:drink:
Had to laugh at that can opener bit. First thing I griped about too
us Offline Kampfer
  • Tactical Desk Jockey
Reply #158 on: September 23, 2015, 06:29:49 PM
:drink:
Yeah it really sucks.
hr Offline styx
Reply #159 on: September 23, 2015, 07:24:25 PM
I think it could be fixed to get a decent performance out of it
fr Offline hellsing
Reply #160 on: September 25, 2015, 06:36:06 PM
It seems mine is near like you, quite rugged.
I will play with it as for a brand new leatherman to make it smooth.
us Offline Demel
Reply #161 on: September 27, 2015, 03:08:32 AM
My new switchplier setup. Added the 2 washers in between flat driver and phillips. I really get tired of can openers. I wanted to put the awl instead of the bottle opener, but settled on this setup.
It is great being able to swap tools on here. The scissors make it very complicated, but well worth it.
us Offline 3rdpig
Reply #162 on: September 27, 2015, 06:04:50 AM
I added a pair of scissors to a Powerlock I have and they were terrible, they'd cut paper, but not much else.  They were so bad I replaced them with the V cutter. Did I just get a bad pair?  How is everyone else's SOG scissors working?
us Offline Demel
Reply #163 on: September 27, 2015, 12:52:38 PM
They are not the best for sure. Mine are slightly better than wingman scissors, I'd rather have a decent pair of scissors than a file. Only because I rarely use a file on my mt. so you're not alone.
gb Offline shibafu
Reply #164 on: September 27, 2015, 09:28:52 PM
Curiously I found the wire cutters very disappointing when I tried them on 2.5 sq.mm (13 AWG) insulated copper wire.  They seem to have poor geometry, with very little overlap of the cutting jaws and not enough clearance around them.  The result is that you end up having to crush the wire before you've cut all the way through it.  Stranded wire seems less of a problem because it deforms more easily.  But with the solid wire, even a little Leatherman Squirt seems to do a better job.
fr Offline hellsing
Reply #165 on: October 27, 2015, 09:19:03 AM
Is there a way to remove the pocket clip? I don't use it and as a left hander it isn't convenient.
hr Offline styx
Reply #166 on: October 27, 2015, 09:38:14 PM
Yea but you need a torx driver and it is the same screw as the pivot
us Offline parnass
  • 4x4 since '74
Reply #167 on: October 29, 2015, 03:47:10 AM
Curiously I found the wire cutters very disappointing when I tried them on 2.5 sq.mm (13 AWG) insulated copper wire.  ...
This Youtube video contains an experiment showing the difficulty of cutting various wires using the SOG Switch Plier 2.0.   The video is in German.  I don't understand German, but the video was clear enough to understand without understanding the language.
Retired engineer, author.
hr Offline styx
Reply #168 on: October 29, 2015, 06:27:03 AM
I've tried cutting stranded wire (one of those mechanic's keyring things) and it did have issues. But not nearly as the LM
fr Offline hellsing
Reply #169 on: October 29, 2015, 08:56:30 AM
You're right, i wasn't confident in doing it cause the bit is hard to put correctly, but i manage to do it without destroying the bit. Thanks!
hr Offline styx
Reply #170 on: October 29, 2015, 07:49:21 PM
glad you managed to get a good fit for yoruself
us Offline WoodsDuck
  • Duck!
Reply #171 on: November 06, 2015, 03:16:36 AM
I keep hearing the SOG scissors are bad, and it's disappointing. I've been planning to pick up a SOG MT sometime after Christmas, and it sounded like a cool idea to make up a bladeless build that contains scissors so I can still get some cutting done.
But if the scissors are that bad, I'm not sure I want to bother. A shame, since the easy modability is a brilliant feature in theory, and one I wish more manufacturers would try.
us Offline Demel
Reply #172 on: November 06, 2015, 03:38:59 AM
The scissors aren't the best but they aren't horrible. I have them in my Switchplier and I wouldn't replace them. What would you plan on using them for?  They are worth having. :2tu:
  • Duck!
Reply #173 on: November 06, 2015, 02:42:36 PM
I use scissors all the time on my MTs, for just about everything. That's why when I'm not doing a challenge, I always have a SAK in my pocket.  :climber:
us Offline Demel
Reply #174 on: November 07, 2015, 05:28:20 PM
How is it the signal got an owners club before the Switchplier? Or did I miss it. :think:
Maybe this thread can be it
us Offline sLaughterMed
Reply #175 on: November 07, 2015, 06:51:39 PM
I just don't think there's much love for SOG these days. They have everything they need to be a real competitor, but until they start coming out with more quality multi tools , they will continue this downward trend.
I think the switch plier may be my next purchase, but I'm not ready to purchase any more tools for the time being
Laughter is the best Medicine
us Offline Demel
Reply #176 on: November 07, 2015, 09:20:58 PM
That may be so. The Switchplier is a good tool. They just need to continue to perfect their tools.
gr Offline firiki
Reply #177 on: November 07, 2015, 11:14:47 PM
The Signal also had a Haters Club before its release ::)
Reply #178 on: November 07, 2015, 11:50:51 PM
Some of us have good foresight  :D
As to the Switchplier, I really need to find time to fix that escaping spring on mine. It's not getting carried because of it.
hr Offline styx
Reply #179 on: November 08, 2015, 10:10:04 AM
Well it is easy to get excited over LM no matter what the product is. I guarantee you that if they put out a toilet paper keeper with a few drivers and the internet would go nuts, you'd see nothing but "reviews" of it on YT and there would be half a dozen "WTF were they thinking threads" on here before someone starts a Fan club (which I would actually join) even as a mild spoof of the current craze. One thing thing that LM does exceptionally well is bank on the niche needs of popular pastimes or large first world problems.
When it comes to SOG, there are very few people who's first thought wouldn't be "great concept, so how are they gonna f it up this time?". So every new tool they put out needs to prove itself against the high mark staples of other companies and attract enough of a following to warrant a fan club. If you're looking beyond your casual, semi interested user then it is an uphill battle
Total Receipts: $10.00
PayPal Fees: $0.69
Net Balance: $9.31
Below Goal: $290.69
 3%
