SOG Switch Plier 2.0
us Offline Demel
Re: SOG Switch Plier 2.0
Reply #90 on: July 06, 2015, 10:58:07 PM
That's good to know. It seems they are the only ones who have it in stock. What's going on with Sog. I will be ordering one. Thanks again
Reply #91 on: July 06, 2015, 11:01:54 PM
Where can I get one? Niether Amazon nor Sog has it available. Has anyone ordered from this site before? http://m.academy.com/shop/pdp/sog-switchplier-2-0-multi-tool/pid-1504132?deviceType=true
That's where I bought mine.  Very smooth transaction.
Still extremely happy with my SP 2.0, btw.  :tu:
Nate, Switchplier vs Minigrip.... thoughts? How do they stack up against one another?
us Offline Demel
Reply #92 on: July 06, 2015, 11:50:21 PM
Order is in. Can't wait :mail:
Reply #93 on: July 07, 2015, 12:09:40 AM
You will love it.
That's us mobile
um Offline Mr. Whippy
Reply #94 on: July 07, 2015, 02:56:38 AM
The Minigrip still has the best pliers IMO because of the head shape, but the funky lock makes it pop open at inconvenient times.  Also, the SOG just carries so well, that it makes up for the lack of OHO blades and fewer tools (compared to the LM Charge).  If the pliers lock were better on the Minigrip, it would still edge out the SOG.
Basically, I rate them SOG > Minigrip 》Charge
us Offline Demel
Reply #95 on: July 07, 2015, 03:04:18 AM
Minigrip? Please educate me on what that is.
Edit: Nevermind found it
« Last Edit: July 07, 2015, 03:49:07 AM by Demel »
Reply #96 on: July 07, 2015, 08:30:25 AM
Thanks Nate  :cheers:
us Offline Demel
Reply #97 on: July 09, 2015, 06:06:02 PM
Got it today.  will put it in the ring and see how she holds up. First impression: very compact, light weight, and awesome tool set, I just wish it had scissors. Otherwise it's a good start.
Reply #98 on: July 09, 2015, 06:09:48 PM
The first one could take scissors (I've fitted SOG scissors in mine) so there's no reason that I can see why you can't fit them in this. Remember, they are meant to be customised without voiding warranty, and the scissors are available as an aftermarket addition from SOG or dealers
us Offline Demel
Reply #99 on: July 10, 2015, 11:01:20 PM
The switchplier has been with me the last couple days and seen much variety. Yesterday she helped me with change my brakes, used while wearing gloves, rode in jeans and sweatpants (carried well in btw), went to work with me today, cut stranded and solid wire, used the blade and awl for light task, pliers feel really good to use thanks to being spring loaded. I must say this is a very good tool.
The main "flaw" I have is a good and bad thing. The plastic may or may not hold up in time, but it does make the tool much lighter. The wire cutters work better on solid wire but struggle with stranded wire. Compound leverage would've been nice, but you can't have it all. Thus, the cutters work when need but are not the best in the league. Once I replace the file with scissors, this will be a good urban carry tool. After the last couple days the switchplier has definatly earned a spot in my collection
us Offline Kampfer
  • Tactical Desk Jockey
Reply #100 on: July 11, 2015, 12:08:20 AM
Scissors take up two long slots, while SP2.0 only has one long slot on each side of pliers, not sure if you can fit scissors in.
« Last Edit: July 11, 2015, 12:30:46 AM by Kampfer »
us Offline Demel
Reply #101 on: July 11, 2015, 12:20:01 AM
It's worth a shot. Thanks for the heads up. I haven't tinkered with sog tools before.
Edit:
Is it two long slots or just two slots all together. Example: the powerlock has four "long" tools one of them being scissors. Is that five long slots or four long slots with the scissors taking one extra small slot?
I hope that made sense
« Last Edit: July 11, 2015, 12:23:07 AM by Demel »
us Offline Kampfer
Reply #102 on: July 11, 2015, 12:25:28 AM
well, scissors are made of two blades, so How is it going to work if two blade are not together?  :twak:
« Last Edit: July 11, 2015, 12:32:28 AM by Kampfer »
us Offline Kampfer
Reply #103 on: July 11, 2015, 12:28:59 AM
Quote from: SOG
SCISSORS * °   LARGE   2 SLOTS
* Special positioning required
° PowerLock exclusive component
Scissors and Wirecutters MUST be positioned on the far left side of any configuration
http://www.sogknives.com/knife-tool-care.html
us Offline Demel
Reply #104 on: July 11, 2015, 01:54:54 AM
Quote from: SOG
It says large tool, far left, two slots, not two long slots. And I'm guessing the second slot would be for the spring (which is shorter than the scissors themselves) ergo making it able to fit in a small slot, I had planned on removing can opener and file. So let's reserve the :twak: until it has been tried. :tu: thanks for the link tho. That is helpful. :salute:
Reply #105 on: July 11, 2015, 02:31:35 AM
The scissors should fit in the file slot.  That's where I put the wire strippers.  Works great.  :)
us Offline Demel
Reply #106 on: July 11, 2015, 03:41:35 AM
I just need to get some. Sog is out of stock.
us Offline SAKnight
  • 5.0 HO
Reply #107 on: July 11, 2015, 03:48:08 AM
I want some too, smkw only had saw, file, knife, and Phillips.
Reply #108 on: July 11, 2015, 12:24:28 PM
Demel, what plastic on switch plier are you talking about?
That's us mobile
us Offline Demel
Reply #109 on: July 11, 2015, 03:10:34 PM
That's us mobile
Aren't the black scales made from a hard plastic? I could be wrong, but It doesn't seem like steel, unless it is a very light and thin steel.
Offline Omar Rapace
Reply #110 on: July 11, 2015, 06:16:58 PM
That's us mobile
Not sure what Demel is talking about, but I can assure you that on my SwitchPlier, the scale are definitively metal (also tested that it is ferromagnetic) and pretty thick.
us Offline Demel
Reply #111 on: July 11, 2015, 06:42:18 PM
That's us mobile
You are right. I just assumed because of the weight it was plastic. After looking closer it is metal. That is even better. Sog has done great with this tool
us Offline Jegred2
Reply #112 on: July 14, 2015, 06:55:49 PM
Picked one up a few weeks ago, I like it. It has a very good tool selection, and the tapered end makes for a more comfortable use of the tools. Had to ditch the godawful combo blade that SOG makes though, put in a plain edge one then swapped the sides that it and the file were on.
I just wish it had a better pocket clip, and that SOG would stop plastering their name on every square inch of the tool.
us Offline Kampfer
Reply #113 on: July 14, 2015, 10:53:00 PM
If anyone successfully fit scissors into it I like to see.
us Offline Demel
Reply #114 on: July 15, 2015, 12:01:23 AM
I just called sog to see if they had any in stock. The rep said he spoke to the warranty department and he didn't suggest putting scissors in because they may or may not interfere with the plier head. :-\ I will still order some to test it out.
us Offline Demel
Reply #115 on: July 15, 2015, 12:06:59 AM
After using it for a while, I do believe I will replace the blade with__________. It has the perfect setup for a bladeless multi. I'm thinking combing it with a mini vulcan or mini grip. I wanted a knifeless fuse, but this will work out better.
Edit:
Has anyone tried carrying one in a sheath?
« Last Edit: July 15, 2015, 12:10:37 AM by Demel »
Reply #116 on: July 25, 2015, 03:43:41 PM
It works  :tu:
Pics and write up to follow  :salute:
us Offline Demel
Reply #117 on: July 25, 2015, 05:26:41 PM
It works  :tu:
opcorn:
us Offline Kampfer
Reply #118 on: July 25, 2015, 05:28:15 PM
 :gimme:
Offline Omar Rapace
Reply #119 on: July 26, 2015, 02:06:38 AM
Alright, I think I cracked the code too...  :cheers: "50ft-trad": hope you don't mind but I was too curious to wait for your pictures  :pok:
My current config, from scissors to blade:
  • Scissors
  • thin metallic spacer (1x)
  • Can opener
  • thin metallic spacer (2x)
  • Phillips
  • Bottle opener / Large flat screwdriver
  • Knife blade
Not an ideal set of tools but a good starting point to experiment. Everything opens and closes smoothly and pliers deploy and close as expected. Oh, and you don't even need to deploy the pliers to access the scissors!
For reference, here is the original tool layout (don't remember about any spacer/washer):
  • File
  • Awl
  • Can opener / small screwdriver
  • Phillips
  • Half serrated knife blade
« Last Edit: July 26, 2015, 04:56:18 AM by Omar Rapace »
