91mm SAK with a ... smooth backside
kosmo · 12 · 2261
00 Offline kosmo
  • "All I need now i'th a can opener!"
on: March 31, 2015, 03:42:05 PM
91mm SAK: Is there a back spring that can be swapped out (without mod of the spring or blade) with the main blade backspring, to eliminate backside tools for a ... dare I say it ... a smooth backside?
WTT Book: Victorinox - A Knife and Its History, see link:
http://forum.multitool.org/index.php/topic,57788.0.html
Will trade items for new/used Cadet Alox knives for mod projects.
Updated list: https://freeshell.de/~kosmo/sak/
:B: www.radiotell.ch
ca Offline Syph007
  • SAK Surgeon
Re: 91mm SAK with a ... smooth backside
Reply #1 on: March 31, 2015, 03:53:16 PM
Nope! :D  But what you can do is use somethign like the parcel hook and grind it down to fill the space, that would give you close to a smooth look.  Or just leave the parcel hook as is, but it would stick out below the scale bottom a bit.
Ive also put an awl in there and all it needs is a little washer, but if you already have an opener layer you probably dont want two.
« Last Edit: March 31, 2015, 03:54:55 PM by Syph007 »
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #2 on: March 31, 2015, 04:04:29 PM
How well does that work? How is the snap of the awl? Does it wiggle a bit? I wouldn't mind a setup like that (Compact with awl instead of hook, plus added Cybertool layer for example).
To be honest I was expecting more "smooth backside" jokes, but maybe that's just me :facepalm:
00 Offline kosmo
Reply #3 on: March 31, 2015, 04:12:44 PM
I was bracing for them as well.  Day ain't over yet.
ca Offline Syph007
  • SAK Surgeon
Reply #4 on: March 31, 2015, 04:15:02 PM
Awl on the blade layer works perfect snap is the same.   The awl on the back of the scissors needs some tweaking but it does also work fine.  With the right size washer there is no wiggle at all.
00 Offline kosmo
Reply #5 on: March 31, 2015, 04:15:21 PM
That's interesting.  I was looking at my Champion with all those backside springs and thinking to myself, "Shirley ... One of them will work."  :D
Reply #6 on: March 31, 2015, 04:25:14 PM
Even Victorinox themselves sometimes swap back layer tools, no idea if they use washers as well. For example the Whitetail Deer (screwdriver instead of awl) and the (X)XLT where they use a hook in a blade layer I think :think:
us Offline tattoosteve99
Reply #7 on: March 31, 2015, 04:47:03 PM
Yes one fits. It takes some mod skill though. So no and yes.
au Offline PTRSAK
Reply #8 on: April 02, 2015, 09:48:55 AM
You can use a pre-hook scissors layer backspring, but it is not a straight drop in fit. There is a tiny bit of filing to get the blade to sit right. Also you lose the small blade.
I have done this a couple of times to make 91mm Solos.
yes, I know the 4th pin is superfluous
« Last Edit: April 02, 2015, 09:52:29 AM by PTRSAK »
de Offline HankSolon
Reply #9 on: April 02, 2015, 01:28:13 PM
You can use a pre-hook scissors layer backspring, (...) I have done this a couple of times to make 91mm Solos.
He said Jehova!!! Stone him, Stone him for wasting scissor layer backsprings for solos!!!!!  :ahhh :ahhh :ahhh :ahhh :ahhh :ahhh :ahhh :ahhh
 :cry: :cry: :cry: :cry: :cry:
00 Offline kosmo
Reply #10 on: April 02, 2015, 01:31:20 PM
Good info to know.  Thanks.
Reply #11 on: April 02, 2015, 09:35:56 PM
If you only knew how many I have done!
:evil:
Also the old mag glass/inline spring works well also ;).
