Quote from: radioz on February 14, 2010, 09:24:08 PMjazzbass:QuoteAre you positive it has the Victoria and crossbow stamp? And not the standard "Officier Suisse" crossbow stamp? Because if you have a SwissChamp with a Victoria stamp, that means someone at Victorinox found some very old blades when they were making that knife. That would be a very, very unique knife to say the least.Ah, my mistake. It is the "Officer Suisse" crossbow stamp. Rats! Here I was hoping for something etherial! That being the case, when was the Officer Suisse crossbow stamp last used?Thanks for your help! "Victoria" stamps ended c. 1974. For about a year there was no stamp on the back, then the "Officier Suisse" stamp went from roughly 1975/6-2005. Last year for them was after the switch from 2.4mm to 2.0mm tangs in 2004. So there is one year out there where you can find the older stamp on the newer, "thin tang" blade. Most of the ones I've seen are on Spartan Lites, for whatever reason. As with anything parts related with Victorinox, left over inventory can create some odd outliers, but these are the generally accepted dates.
Need close up pictures of the front and rear tang stamps to date with relative precision. The small one looks like a Model 234k (aka Tourist) from c. 1958-1961. The large one is a Champion, Model 246fmaU from c. 1957-1958. A better shot of the saw (both sides, without being obstructed by the other tools) would help.
29 tooth with a nail nick, so I'd estimate that on the 1958 side of things.
Hi Novice,Those are lovely old knives you lucky sod!!The Champion is in amazing condition - Look at the liner under the awl and the awl itselfNot a mark - I think that is quite rare.PS. Welcome to the forum
(snip) then the "Officier Suisse" stamp went from roughly 1975/6-2005. Last year for them was after the switch from 2.4mm to 2.0mm tangs in 2004. So there is one year out there where you can find the older stamp on the newer, "thin tang" blade. Most of the ones I've seen are on Spartan Lites, for whatever reason. As with anything parts related with Victorinox, left over inventory can create some odd outliers, but these are the generally accepted dates.
My Hiker(did I say it was new?) has that "Officier Suisse" stamp and ALSO a 2mm thick tang (as well as I can measure it). So the blade at least is from '04? Are there any other signs I can look for in the rest of the tools to help me determine roughly when it was assembled? I'm quite interested in this.
Quote from: Pablo O'Brien on June 09, 2015, 11:56:26 PMMy Hiker(did I say it was new?) has that "Officier Suisse" stamp and ALSO a 2mm thick tang (as well as I can measure it). So the blade at least is from '04? Are there any other signs I can look for in the rest of the tools to help me determine roughly when it was assembled? I'm quite interested in this.You can use this modern tang stamp guide to help narrow down when your knife was made:(Image removed from quote.)
This picture is very helpful on aging. Is there a picture for older SAK's like from the 1990's.
Sorry for double post, but basically:"Officier Suisse" means made between '75-6 and '05.2mm tang thickness means '04 to present day.And this means that a blade made in '05 has a 2mm and "Officier Suisse" tang. Am I wrong?I get this so far, but how does the small 'V' (see above post) fit in all this?Am I missing something? Thanks.
Thanks Jazz and Zoid, thats some great info. I have a boring brand new SAK than. Thanks again.
Hey 360BT,You can try this post which has a SAK dating guide based on tool evolution:http://forum.multitool.org/index.php/topic,51872.msg881641.html#msg881641There is also the brilliant SAAMS blog - Google 'saams' , 'swiss army knife' and maybe 'tool'Also Ulli's brilliant tang stamp guide here:http://forum.multitool.org/index.php/topic,50014.msg1008991.html#msg1008991My photo below shows some of the older common tang stamps:From left to right: Smaller V - 1974 - 1986 Larger V - 1986 - 2005Then revert to the picture above for the 'Swiss Made' stampsPS. Please note I am a real amateur at this compared to many members on this forum (eg Jazzbass, Ulli) so please always revert to them if there is a conflict!!
