Quote from: rishardh on October 20, 2015, 11:27:13 PMTo awl or not to awl that is the question?Does not compute, must have at least one functional awl
Quote from: firiki on October 20, 2015, 11:40:25 PMQuote from: rishardh on October 20, 2015, 11:27:13 PMTo awl or not to awl that is the question?Does not compute, must have at least one functional awl Haha... I am with you. I'd rather have a Juice with an awl than a Charge without one.
I think the decision should be based on your usage (or simply take the Spirit )Good stuff!!!! Surge is on the way :multi:so ill its up for trial, But def next after surge will be spirit .thanksQuote from: zoidberg link=topic=62596.msg1168229#msg116plierdate=1445376539Quote from: Ifeexpert on October 17, 2015, 05:53:41 PMAnd lost a pivot screw which icant find replaecement for Just the screw? Get a Rebar, use the screw and plier head (and awl if you like) to upgrade your Wave.Lots of metal filing/sawing: Definitely the SurgeMostly blade: Charge for the OHO blade with higher quality steelLots of different bit sizes but fairly infrequent: LM with bit kit (small package)Lots and often of different bit sizes on rusty screws: Vic with bit kit (standard bits are easier to replace)All tools are used often Spirit for its all outside toolsOther factors:Tool should be rust resistant: SpiritWork in oily-slippery conditions: LM
Rebar? Are those plier screws or rivets? I really don't know, never had a rebar, but on pictures they look like rivets, but im willing to try just to save a wave life....Thanks
Actually, I have a couple screws left over from a sidekick mod... ill check if they fit a wave tonight, and send it on over to ya if it does
Why don't you just go to home depot to find a screw? It won't look perfect, but I bet it would be functional, and much cheaper than parting a rebar. Just take the wave to the hardware store, find a screw that threads into the wave, and cut the length to fit
I actually went to home depot , nothing fit and the only thing that worked was some aluminum post and screw that snapped the very next morning on first job
any recommendations for upgrade from a wave to? From you pros.
Quote from: Ifeexpert on October 17, 2015, 05:31:46 PM any recommendations for upgrade from a wave to? From you pros.So an update:Found a decent used Surge which i received a couple days ago, (fairly huge, but cool, handles are rough when using pliers) Rebar on its way (going to use screw/posts and plier head to repair my raiders wave) also couldn't help it, charge is on it's was as well........ What y'all think???
