(Image removed from quote.)Scissor duty on my new Harley Quinn Tshirt.
The kind of person I picture when I know they wear both scrubs and Harley Quinn t-shirts...(Image removed from quote.)
I should have picked a tool with a file. I use one quite a bit. I've not cheated and used another tool with a file, but I've bummed an emory board a couple of times from the ladies in my life.
Mail call.
Quote from: pipedreams on November 04, 2015, 05:52:46 AMI should have picked a tool with a file. I use one quite a bit. I've not cheated and used another tool with a file, but I've bummed an emory board a couple of times from the ladies in my life.What Juice one has a file? You can always sharpen the awl up some!
Quote from: pipedreams on November 04, 2015, 02:16:26 PMMail call.No problems with the padded envelope, or were you a chicken and did cut where there is no padding?
Spring popped off the jaw hinge of my (other) skull. The fine tips of the Juice's pliers were the perfect tool to put it back in place. And, yes, it is a real skull.
I don't generally use a MT to cook, but it seems to be something members here like to see. Venison, onions and garlic for chili. It worked OK.
