High Tensile Wire Cutting Test, Warning: Minor Tool Abuse
zoidberg · 100 · 11641
Re: High Tensile Wire Cutting Test, Warning: Minor Tool Abuse
Reply #60 on: December 23, 2015, 10:10:24 AM
MP600, bike brake cable stripped - not good.
Reply #61 on: December 23, 2015, 10:10:58 AM
Huh, well then...
Reply #62 on: December 23, 2015, 10:11:17 AM
One last test to go.   :ahhh
Reply #63 on: December 23, 2015, 10:11:36 AM
SwissTool, HT wire, two cuts, hard to do and tough on the hand:
Cutters - minor damage, just catching, serviceable.
HW notch - good
Reply #64 on: December 23, 2015, 10:12:51 AM
MP600, HT wire, HW notch - good, hard to do, two hands needed.
Reply #65 on: December 23, 2015, 10:13:14 AM
I certainly wasn't expecting these to still be in one piece.
Reply #66 on: December 23, 2015, 10:13:35 AM
Let me try that again.
Reply #67 on: December 23, 2015, 10:13:57 AM
Two cuts with the HW notch and no broken carbide cutters.
Reply #68 on: December 23, 2015, 10:14:29 AM
I decided to leave it at that.
Trying it on the regular cutters would be even harder on the hands.
And I was no longer willing to waste my last set of the cutters after seeing what they could do.
Reply #69 on: December 23, 2015, 10:14:47 AM
There was one fail though, the mini bolt cutters didn't open wide enough to cut the power cord.    :facepalm:
scotland Offline Sea Monster
Reply #70 on: December 23, 2015, 10:23:23 AM
Have you been using the stranded wire cutter on the Surge, or just the main jaws?
Reply #71 on: December 23, 2015, 10:32:22 AM
For these tests I only used the replaceable cutters.
For every day stuff I do use the stranded wire cutters.
I would like to see them on the smaller Wave and Charge.
ch Offline Etherealicer
Reply #72 on: December 23, 2015, 10:34:18 AM
 :salute:
Did you also test the stripped bike brake cable with the Surge and the Blacktip?
I had problems with the Surge (but not with the Rebar head in a Charge) and for me, the Spirit cut the brake cable very well (Quick Test: MTs vs. Bike Break Cable).
Reply #73 on: December 23, 2015, 10:36:09 AM
:salute:
Yes. No problems with either tool. Just didn't bother taking pics of everything.
« Last Edit: December 23, 2015, 10:37:50 AM by zoidberg »
Reply #74 on: December 23, 2015, 10:44:55 AM
:salute:
Am I correct assuming you used the wire-cutters on the Surge?
Reply #75 on: December 23, 2015, 10:49:02 AM
:salute:
I tried both the hard wire notch and the cutters.
us Offline twiliter
Reply #76 on: December 23, 2015, 12:13:15 PM
Good info there Z, thanks!  :)
Reply #77 on: December 23, 2015, 12:20:31 PM
ca Offline derekmac
  • Little to the right...
Reply #78 on: December 23, 2015, 12:27:52 PM
Great bit of testing there buddy!!! :tu:
Reply #79 on: December 23, 2015, 12:37:29 PM
no Offline Steinar
Reply #80 on: December 23, 2015, 03:28:41 PM
This thread illustrates why a SAK plus a dedicated pair of inexpensive pocket pliers is the way to go.
I am slowly reaching the same conclusion, especially considering the total loadout won't be any heavier.
Reply #81 on: December 23, 2015, 04:26:23 PM
Great test !
us Offline ToolJoe
Reply #82 on: December 23, 2015, 04:27:47 PM
A pair of dedicated pliers are looking more and more good to me.  :whistle:
Reply #83 on: December 23, 2015, 07:27:30 PM
pincers, lobster pincers...
Reply #85 on: December 23, 2015, 08:23:27 PM
Reply #86 on: December 23, 2015, 08:29:46 PM
ugly!!!!!
Reply #88 on: December 23, 2015, 09:05:48 PM
Looks like a Batman villain.
Are they using orange jumpsuits in Arkham?
Reply #89 on: December 23, 2015, 10:42:25 PM
I recently sold my backup Gerber so I wasn't brave enough to try these. Yet. I might feel up to it later.
Be prepared that you may need to replace the replaceable Gerber cutters.  IIRC they are very hard and very brittle, so they do well on cutting large quantities of softer wire (which is what they were designed for), but tend to break on hard wire.
If I had to use an MT to cut large(ish) diameter hard wire I'd consider filing a notch first to reduce the chance of smurfing up the cutters.  Or even just file a couple of notches and then bend the wire back and forth until it breaks at the weak point you have created.  There is often "more than one way to skin a cat" if you use your imagination and think laterally.
That is why I didn't want to try them.
However IMO they aren't any good at cutting soft wire either.
So I might as well kill them.
My original idea was to test multiple cutters going from easy to hard stuff and noting the outcome.
Once I sold the backup I thought I would flag the test.
Now it is just a time thing, if I can find some I'll probably do it.
I wonder how hard it is to file HT fencing wire?
Practically impossible.   I learned this the hard way when trying to free a sheep stuck in the fence in rain and mud.  The wire cutters on my first generation LM Super Tool wouldn't go through the 50 year old fencing wire we have on the farm since I couldn't get enough leverage, so I tried the teeth along the bottom edge of the file.  It barely scratched it.  While I went to get the bolt cutters to cut the wire, my grandparents were able to free the sheep without tools, so at least the story had a happy ending.
