My rice cooking techniques came from the Filipino culture. Calrose rice was mostly used and typically cooked in a rice cooker. The thing I didn't understand early on was how my Filipino friends measured the rice to water after washing it. Anyone see how Filipinos measure the rice to water? Pretty neat and possibly done in other cultures tho I'm not aware.
If it is some fancy rice I wash it in the cooking pot until the water seems reasonably clear.But usually we use parboiled, which we don't bother washing before.Then add 2 cups (cold) water per 1 cup rice, add some salt, bring to a rolling boil. Reduce temperature, let it simmer with a lid on until all the water is evaporated/absorbed. Usually I turn of the plate with a little water left and let it sit on the plate for some minutes.What is the knuckle method of measuring?
Quote from: RT1969 on January 01, 2016, 07:41:20 PMIf it is some fancy rice I wash it in the cooking pot until the water seems reasonably clear.But usually we use parboiled, which we don't bother washing before.Then add 2 cups (cold) water per 1 cup rice, add some salt, bring to a rolling boil. Reduce temperature, let it simmer with a lid on until all the water is evaporated/absorbed. Usually I turn of the plate with a little water left and let it sit on the plate for some minutes.What is the knuckle method of measuring?So you pour in the desired amount of rice, and level it in the cooker/pot. Then you touch the top of the rice with your first finger, and add water until it comes up to your first knuckle. It's supposed to work regardless of how much rice you use, though I haven't tested this. Works for my uses though
As far as answering the question on if you should wash your rice or not here is a link I found quickly that should explain.http://www.chowhound.com/food-news/148823/nagging-question-should-you-rinse-rice-before-cooking/
Quote from: eddie1115 on January 01, 2016, 10:26:11 PMQuote from: RT1969 on January 01, 2016, 07:41:20 PMIf it is some fancy rice I wash it in the cooking pot until the water seems reasonably clear.But usually we use parboiled, which we don't bother washing before.Then add 2 cups (cold) water per 1 cup rice, add some salt, bring to a rolling boil. Reduce temperature, let it simmer with a lid on until all the water is evaporated/absorbed. Usually I turn of the plate with a little water left and let it sit on the plate for some minutes.What is the knuckle method of measuring?So you pour in the desired amount of rice, and level it in the cooker/pot. Then you touch the top of the rice with your first finger, and add water until it comes up to your first knuckle. It's supposed to work regardless of how much rice you use, though I haven't tested this. Works for my uses though It's the same way I do it, although I use my middle finger. Works from 2 to 20 cups of rice
Quote from: Aloha007 on January 01, 2016, 05:42:01 PMMy rice cooking techniques came from the Filipino culture. Calrose rice was mostly used and typically cooked in a rice cooker. The thing I didn't understand early on was how my Filipino friends measured the rice to water after washing it. Anyone see how Filipinos measure the rice to water? Pretty neat and possibly done in other cultures tho I'm not aware. My Filipino family used the knuckle method, I wasn't sure if that's a Filipino thing or just my grandma's thing, but it works
Quote from: eamo on January 01, 2016, 04:27:32 PMwash the rice ? ok . . . . before or after i cook it ? (seriously)Before.Quoteso, whats the best way to cook rice then ? I just throw on a pot of water, boil the rice and drain it - i haven't poisoned my kids or myself (yet) so how wrong am i doing it ?How wrong?! Everything is ruined forever! I have heard rumours about tastes differing, but I think that can't be right, right? I wash the rice, bring a measured amount of water in a pot to a boil, add the rice, and let it simmer with a lid on till all the water is absorbed. I let it rest with the lid on for some minutes after removing the pot from the heat. Also, I never stir the rice after I have put the lid on the first time. An added benefit of washing the rice when doing it this way is less chance of rice sticking to the put.Some people let the rice soak in cold water for a while after washing, before cooking. I guess what works best differs with types of rice, but rice isn't really a part of the diet I grew up with, so I don't know too much about the dos and don'ts.
Don't think I've ever washed Rice
I use a small wire mesh collider. I rinse mine until the water is clear. Of course this is for sushi
Quote from: tattoosteve99 on January 01, 2016, 11:31:51 PMI use a small wire mesh collider. I rinse mine until the water is clear. Of course this is for sushi Same here...small wire mesh colindar.
We wash the rice before cooking simply because we have no idea where/what touched the grains before it got packaged in the bag. Kinda like washing your fruits or veggies before taking the first bite. For white rice: from the container, just pour enough water to submerge all the rice you have then "mash" the grains with your hand as you would do to sand and let it pass through between your fingers. Strain as you pour out as you don't want to throw away any of the rice grains. Do it twice. For brown/red rice: wash as above but you can let it soak for 30mins to 1hr to come up with fluffier brown/red rice. Brown/red rice is supposed to be healthier and heavier on the tummy but usually doesn't go down quite as smoothly as the white rice (go ask the kids). Hence, the soak to soften it up.To cook, it would usually be trial and error depending on the rice variety. Though the knuckle measurement method usually works, one can always do the 1 cup of rice : 1.5 cups of water ratio. If the rice ends up being too soft, reduce the ratio of water. If the rice is too hard for your palette then add more water. If cooking without rice cooker (such as over an open flame or stove), bring above preparation to boil then lower heat. Yes, the water will spill over because it's boiling. Check every 5mins to see if the water has dried up or not visible from the surface. You can use a spoon to poke to the bottom to check if there's no more water. Serve while hot! To reheat (say you left some steamed rice during lunch and want some for dinner), put rice in microwavable container-- Add a few teaspoons of water depending how much rice is left, then place for a minute in the microwave. The idea is you'll use the water to steam the rice using the microwave.
I wash rice in the rice cooker bowl itself. Then double the water to the rice and add a little salt. Once done and if you got left overs, throw it in and mix it with the fresh rice.I like parboil the most because it's soft. Out of the fast food rice Popeye's Cajun rice is my favorite followed by Chipotle's Cilantro-Lime rice. Somehow I cannot get to like brown rice but I try it from time to time to see if my taste buds has changed but then regret the decision but never learn.
Quote from: rishardh on January 13, 2016, 06:34:53 AMI wash rice in the rice cooker bowl itself. Then double the water to the rice and add a little salt. Once done and if you got left overs, throw it in and mix it with the fresh rice.I like parboil the most because it's soft. Out of the fast food rice Popeye's Cajun rice is my favorite followed by Chipotle's Cilantro-Lime rice. Somehow I cannot get to like brown rice but I try it from time to time to see if my taste buds has changed but then regret the decision but never learn.Popeyes is just the best all around. Seriously I love that place. I go every Tuesday. Yes I went today. They put KFC to shame. Before the east coast people ask Popeyes is very similar to Bojangles. Oh how I miss the steak biscuit.
what I understand is your not suppose to wash regular white rice because they are pre-washed and then sprayed with vitamins (with an oil like spray) after washing and drying (wasn't this on "How It's Made?!"). so if you wash white/regular rice you wash away the vitamins added. organic rices are not usually sprayed/fortified.
Quote from: WhichDawg on January 15, 2016, 02:57:18 AMwhat I understand is your not suppose to wash regular white rice because they are pre-washed and then sprayed with vitamins (with an oil like spray) after washing and drying (wasn't this on "How It's Made?!"). so if you wash white/regular rice you wash away the vitamins added. organic rices are not usually sprayed/fortified.Just makes me want to wash it more. I don't like people spraying my food with stuff even if it is vitamins. Just my personal preference.
