Parts for Upgrade/Repair Leatherman multitools
Offline chas brookes
Re: Parts for Upgrade/Repair Leatherman multitools
Reply #450 on: December 27, 2019, 11:54:59 AM
Hi Loki
can I take the following bits I am in UK and have purchased of you on Ebay
Wave/Charge big bits holder - $15
Kick Pocket Clip - $20
Thanks Charlie (Dennis8216 on Ebay)
Actual price and available
Pliers:
ST300/NEW Surge/MUT Pliers - $35
Blast/Fuse/Wave/Charge Ti/AL Pliers - $32
Blast/Fuse/Wave/Charge Ti/AL Pliers Black - $35
Charge ALX TTi/Xti Pliers with CC Black - $35
Old Surge/Core - $38
Old Surge/Core with CC Black- $35
Blades:
Wave - $20
Wave Serrated - $20
Charge Ti/Al/ALX (154CM) - $25
Charge ALX black (154CM) - $32
Charge TTi/XTi/ALX Serrated Blade with Hook - $25
Charge TTi/XTi/ALX Serrated Blade with Hook Black -$32
Skeletool/Freestyle (Combo 154CM) - $32
Surge - $22
Surge serrated - $22
Surge - $25
Surge serrated - $25
MUT - $27
MUT black - $32
ST300 EOD Semiserrated blade black - $28
ST300 Black blade (not new, but excellent condition) - $19
Blast/Fuse blade - $19
ST300 Blade - $18
Other:
Wave/Charge saw - $22
Wave/Charge file - $22
Blast/Fuse File - $30
Blast Saw - $30
Wave/Charge/Blast small bits holder - $15
Wave/Charge/Blast/Rebar flat screwdriver - $15
Wave/Charge/Blast/Rebar flat screwdriver black - $17
Blast/Fuse small flat screwdriver - $15
Rebar small flat screwdriver - $15
Wave/Charge/Blast/Rebar opener - $15
Wave/Charge/Blast/Fuse scissors - $20
Blast/Fuse/Kick phillips screwdriver - $15
Surge/ST300 awl - $17
Surge/ST300 awl black - $20
Surge big bits holder - $17
Surge small bits holder - $22
Surge saw/file holder - $25
Surge saw/file holder black - $26
Surge scissors - $28
Surge scissors black - $30
Surge/ST300 small flat screwdriver - $15
Surge/ST300 small flat screwdriver black - $17
Surge/ST300 big flat screwdriver - $15
Surge/ST300 big flat screwdriver black - $17
MUT saw - $30
ST300 saw holder - $45 (High price, picked to try & my progect :)
Wingman  scissors - $19 (High price, picked to try & my progect :)
ru Offline loki-mobile
Reply #451 on: January 02, 2020, 02:28:18 PM
Kick Pocket Clip - out of stock
gb Offline Mart0923
Reply #452 on: January 08, 2020, 12:43:30 AM
Hi there can I get fuse scissors please
Reply #453 on: January 11, 2020, 08:26:32 PM
Pliers:
Blades:
Wave - $20
Wave Serrated - $20
Charge TTi/XTi/ALX Serrated Blade with Hook Black -$35
Surge - $22
Surge black - $25
Surge serrated black - $25
MUT - $27
MUT black - $32
ST300 Blade - $18
Other:
Wave/Charge saw black- $25
Blast Saw - $30
Wave/Charge/Blast/Rebar opener black - $17
Wave/Charge/Blast/Fuse scissors black - $23
Blast/Fuse/Kick phillips screwdriver black- $17
MUT saw - $30
gb Offline Benji
Reply #454 on: January 16, 2020, 12:57:48 PM
Hi Loki, do you think you might be gettting any more Surge small bits holder part? Id like one if you ever do :)
Cheers
Benji
Reply #455 on: January 16, 2020, 03:45:50 PM
Cheers
Benji
you need adapter from a large bit holder to a eyeglass screw?
gb Offline Benji
Reply #456 on: January 17, 2020, 12:16:52 AM
This part i think. i was going to swap out with the medium the flat head.
But there is an adapter from large to small? I havent seen this.
Reply #458 on: January 17, 2020, 05:44:01 AM
Old Surge small bits holder - $25 with shipping
gb Offline Benji
Reply #459 on: January 17, 2020, 11:22:47 PM
Sounds great , thanks Pm you?
us Offline WrenchHeadFox
Reply #460 on: January 20, 2020, 04:32:11 AM
loki-mobile, are you able to get a replacement file for a Leatherman Crunch? If so, how much would that cost? Thank you.
Reply #461 on: January 20, 2020, 06:03:10 PM
There is no file for crunch in stock. I will not disassemble the multitool due to one file.
Reply #462 on: January 20, 2020, 07:45:05 PM
Thanks. Do you have any replacement tools for the Crunch at all? Or I might be willing to buy some other parts alongside the file depending on how much you would need to sell to make disassembly worthwhile.
Btw my order would also include the Surge saw/file holder (stainless) and a set of your "lite" wrenches (or preferably the new, longer wrenches if you have any in stock again) if that makes any difference.
nz Offline Syncop8r
Reply #463 on: January 20, 2020, 07:52:35 PM
I wonder if there is a file from another multitool that could be substituted without too much modification.  :think:
Or if yours has broken, is sending it in to Leatherman to get fixed under warrantee an option?
Reply #464 on: January 20, 2020, 08:12:59 PM
Of parts I've looked at, I don't think they have the same profile. I would love to be wrong and informed if there is another Leatherman that has interchangeable tools with the Crunch. Seriously if anyone knows this info, I'd be super grateful to have it.
My file is fine, I just want to make my Crunch bladeless. Ideally I want to have a t-shank blade exchanger where the knife was so I can have a metal jigsaw blade in there, and ditch it if I can't have a blade somewhere. For now though, just replacing the knife with a second file would be fine with me and give me some time to better figure out how to handle the t-shank situation.
I would loathe to buy a second crunch just to start tearing it apart, but I'm tempted. I wouldn't mind having spare parts around, and I'm sure I could come up with at least a couple of uses for it if I had to.  :dunno:
nz Offline Syncop8r
Reply #465 on: January 21, 2020, 06:14:41 AM
Not really what you are looking for but it's another option:
Pretty good hack for using the Saw and File from the Surge  :tu:
https://forum.multitool.org/index.php/topic,10261.msg2060390.html#msg2060390
Reply #466 on: January 21, 2020, 05:25:01 PM
I think it will be easier to find a donor for ebay than I disassemble the crunch. I don’t really like to disassemble working multitools, but I don’t have a broken crunch
Reply #467 on: January 21, 2020, 05:29:00 PM
Not really what you are looking for but it's another option:https://forum.multitool.org/index.php/topic,10261.msg2060390.html#msg2060390
Hmmm, holding a blade in the locking jaws. An obvious solution I hadn't considered. Perhaps I'll just keep it simple and grind the knife into an awl and call it a day, and fashion a t shank holder that gets gripped in the vise jaws. Thanks for the suggestion!
Reply #468 on: January 22, 2020, 01:55:51 AM
Thank you for the reply.. I will hunt for a damaged crunch.
Loki, would you be willing to measure the thickness of the Surge blade changer vs the thickness of the Super Tool blade changer? I want to buy one of the two, but have not decided 100% which.
Thanks for your time.
« Last Edit: January 22, 2020, 02:57:11 AM by WrenchHeadFox »
Offline Eriequiet
  • New User
Reply #469 on: January 29, 2020, 06:02:51 AM
Pliers:
Blades:
Wave - $20
Wave Serrated - $20
Surge - $22
Surge black - $25
MUT - $27
MUT black - $32
ST300 Blade - $18
Other:
Blast Saw - $30
MUT saw - $30
Hi Loki, been planning some mods for a while and hear your the guy to get parts from
Finally ready to get started
Would like a
surge saw file holder
Surge small screwdriver
Surge mini bit holder? (Looks like possibly out?)
How do we do this?
Reply #470 on: January 29, 2020, 08:38:35 PM
Would like a
How do we do this?
all in stock, I write to PM. For reply to PM you can have 5 posts in forum//
Offline Eriequiet
  • New User
Reply #471 on: January 30, 2020, 12:34:31 AM
Well this is number 2 I guess
I was wondering why I couldn’t reply... been forever since I’ve used one of these forums
Glad to hear you have the mini bit holder in stock
I’m hoping to cut off the small screw driver section and weld on a small pin punch... I do a lot of firearm stuff so that’s a must have
Torn on if I really want to install the mini bit since you can use the locking tabs to hold a smal bit, but it just seems nicer (still buying either way)
Which saw file holder is it? Just bought a new surge and it looks like it has a spring arm... does this help with non LM blade wobble I’ve read about?
Any issues or work needed to install it to replace the serrated on a surge?
« Last Edit: January 30, 2020, 01:25:24 AM by Eriequiet »
Reply #472 on: January 30, 2020, 01:48:55 AM
I was wondering why I couldn%u2019t reply... been forever since I%u2019ve used one of these forums
I%u2019m hoping to cut off the small screw driver section and weld on a small pin punch... I do a lot of firearm stuff so that%u2019s a must have
Which saw file holder is it? Just bought a new surge and it looks like it has a spring arm... does this help with non LM blade wobble I%u2019ve read about?
These are questions you could ask in the mod forum.  :tu:
https://forum.multitool.org/index.php/board,16.0.html
gb Offline Benji
Reply #473 on: February 03, 2020, 01:38:48 PM
Mini screwdrive bit holder for old surge arrived from Loki today,  Fits perfectly to new surge , thanks Loki, perfect service , easy transaction  :hatsoff:
Reply #474 on: February 13, 2020, 05:42:07 PM
Pliers:
Blades:
Wave - $20
Wave Serrated - $20
Surge - $22
Surge black - $25
MUT - $27
MUT black - $32
ST300 Blade - $18
Other:
Blast Saw - $30
MUT saw - $30
Offline IntnlManOfCode
Reply #475 on: March 01, 2020, 11:31:17 PM
I am interested in the wingman scissors.  Home much for shipping to New Zealand?
Reply #476 on: March 04, 2020, 07:17:15 PM
Reply to PM
00 Offline ajcole
  • Would MacGyver use Leatherman?
Reply #477 on: March 07, 2020, 02:50:55 PM
Hello,
I am thinking about modding my WAVE PLUS. I would like to have these things fitted:
-S30V blade (from CHARGE TTI?)
-serated blade with hook (from CHARGE PLUS?)
-full size scissors (from WINGMAN?)
-blade exchanger (from SURGE?)
-exchangable file with diamond coating (from SURGE?)
-small flat screwdriver (from SURGE?)
-bit set incl. bit extension
-holster with pockets for bit set, bit extension and small lamp
Can you help me buying those things? Only the flat blade has to be new.
And one question: Would it be useful changing the pliers?
Kind regards
Shipping would be to EU.
« Last Edit: March 07, 2020, 02:56:53 PM by ajcole »
Reply #478 on: March 07, 2020, 06:11:51 PM
Hello,
Kind regards
-S30V blade - out of stock (only 154CM available)
-serated blade with hook - in stock
-full size scissors WINGMAN - in stock
-blade exchanger (from SURGE?) - saw|file holder in stock
-exchangable file with diamond coating out of stock (only saw available)
-small flat screwdriver (from SURGE?) - may be better blast/fuse small scredriver (in stock)?
-bit set incl. bit extension - out of stock
-holster with pockets for bit set, bit extension and small lamp - out of stock (i can add bonus plastic sheath - https://forum.multitool.org/index.php/topic,83116.new.html)
And one question: Would it be useful changing the pliers? - Why change the pliers? At the wave+ they are one of the best...
PS You must have 5 forum posts in order to write private messages
00 Offline ajcole
Reply #479 on: March 07, 2020, 06:53:23 PM
OK, thanks for your answer, you can also write a private message if you prefer...
So, more questions:
1. Are the prices the same without ebay?
2. seperate bit extension in black available?
3. why small screwdriver of BLAST / FUSE? I want to remove the standard scissors, what would be a good tool instead? Is there some other opening hook or tool fitting?
4. What would post and package cost to germany? You only take dollar?
thank you very much.
aj
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
