1st mod.....2nd finished.
us Offline leathermon
  • Better to have a tool, than be a tool.
on: March 30, 2016, 04:08:31 AM
I actually finished another first,  but I started this one first. It wasn't working,  so I gave up,  but it was eating at me so I  tried,  tried again.  I bought a mini,  but the flat blade/file was broken. I removed it added the bottle opener from the micra. I had to adjust the position and size of the hole. Then I worked with finding the right washer.  I ended up with plastic/cloth material washer and cut to size. As I needed the right balance of pressure.
Sent from my SAMSUNG-SM-N920A using Tapatalk
us Offline yud
  • Still has a SOGgy feeling
Re: 1st mod.....2nd finished.
Reply #1 on: March 30, 2016, 04:30:19 AM
Cool :tu:
Reply #2 on: March 30, 2016, 04:43:46 AM
Excellent.   :tu:   I have always liked that tool on the micra.
au Offline pietervn
Reply #3 on: March 30, 2016, 08:09:46 AM
G'Day,
That is a cool mod!!!
What did you use to enlarge the pivot?
Is there a major difference is thickness between the file and the Micra bit you inserted?
Cheers,
Pete
Reply #4 on: March 30, 2016, 11:50:48 AM
G'Day,
Cheers,
Pete
Major Difference!
 :salute:
Reply #5 on: March 30, 2016, 07:24:19 PM
G'Day,
Cheers,
Pete
Yes,  that is why I needed the washer, the file was much thicker. I used a 3/16th metal drill bit. That was just a hair too small still, so I flipped it on its side and used pressure with the  drill bit until it fit.
