Honestly, it does not sound like you want a multitool, get some dedicated pliers, a good knife with a bit driver and don't expect to be able to use a knife "bending tool."
You really should carry a Pry bar separately. I assume a Skeletool failed on you?
Not to derail, but about the pry bar part. Can't (or maybe there is) they make a multitool with a pry bar integrated? Those big(ger) flat heads are so tempting to use in a bind for lighter affair. I know it would have to do with the leaverage point being the issue. Where the pry bar is "full tang" so to speak. Anyway I vote for adequate prybar and awl on every multitool going forward
A Leatherman Crater C33t/tx, a bit kit, Pocketwrench and a pair of dedicated pliers might be a good group to explore..
