Loose tools on original Leatherman PST
Offline mikekoz
on: May 02, 2016, 04:48:57 AM
   I picked up one of these at the end of last year in good condition, but it has one problem. The tools on one side of the handle are very loose, and when you turn it upside down, they just open by themselves and dangle. I can tighten the pivot with a pair of needle nose pliers, but they always loosen after a few times when any of the tools are opened and closed. Is there a way to fix this? Any help would be appreciated!
us Offline Wanimator
Re: Loose tools on original Leatherman PST
Reply #1 on: May 02, 2016, 04:50:45 AM
Use the warranty service, they'll take care of you. Make sure to tell them the problem.
Reply #2 on: May 02, 2016, 05:39:16 AM
Loosen the screw all the way out and apply some loctite before you tighten it back up.
Reply #3 on: May 02, 2016, 05:59:01 AM
That is what I was gonna recommend as well :tu: Also when you tighten it up don't overtighten it but don't undertighten it either :D You have to find a happy in between where the tools come out easy but not to easy as yours are now :tu: Then let the Loctite dry before using the tool anymore, good luck with it :cheers:
Reply #4 on: May 02, 2016, 06:01:04 AM
If you go this route they make fix the tool up for you fine but just make sure you tell them you don't want a replacement or you will end up with a Rebar more than likely. That may be fine by you though but I would rather keep my PST and just buy a Rebar :D
Reply #5 on: May 02, 2016, 06:03:50 AM
 :imws:
Offline mikekoz
Reply #6 on: May 07, 2016, 03:38:25 AM
   Thanks everybody. I guess I will just mess with it this weekend. I do not want to send it to Leatherman. It is one of the older PST tools with "USA" still on the pliers. I just got it to have it, plus it was a good deal. It is too uncomfortable in the hand to actually use.
