Rebar Handle Help
Demel · 11 · 1288
us Offline Demel
Rebar Handle Help
on: June 23, 2016, 11:39:19 PM
I need some assistance with this guys. I removed the lanyard loop in my Rebar and added the small flat driver. Now the handles do not close completely. Pictures attached
I'm not sure why, I tried several configurations and none of them helped. The current line up is: blade, can opener, awl, small driver, large driver, and file.
When the pliers are folded on one side they close completely
But once the other handle is folded past this point
They open ever so slightly and don't close back.
Help
Re: Rebar Handle Help
Reply #1 on: June 23, 2016, 11:53:05 PM
Not sure what going on there. It should be fine with that lineup, I have the same in mine.   ???
Reply #2 on: June 24, 2016, 01:00:36 AM
 :think: That is weird
I have in one handle serrated blade, can opener, spacer, phillips driver, saw
The other handle is PE blade, large flat, awl, med flat, lanyard ring and file
I hope that helps some :tu:
Reply #3 on: June 24, 2016, 01:03:55 AM
Owe I overlooked that you added a tool :oops: I would just keep trying til it fit :tu:
Reply #4 on: June 24, 2016, 01:33:20 AM
Fully open all tools and test shut the handles. Close the tools one by one testing each time...
Are the handles fastened correctly to the pliers. Posts in fully, washers not bent, screws too loose or tight...
Something off with the pliers. Loose pivot, catching cutters etc...
us Offline Demel
Reply #5 on: June 24, 2016, 01:48:56 AM
Thanks for the replies everyone. Zoid, that helped find the problem. It's the awl and large driver that's causing the problem.
us Offline Demel
Reply #6 on: June 24, 2016, 02:25:38 AM
I took out the plain edge blade, added the lanyard loop and shifted everything. Now the configuration looks like this: opener, large flat driver, small driver, awl, lanyard loop, and file.
« Last Edit: June 24, 2016, 02:31:40 AM by Demel »
Reply #7 on: June 24, 2016, 03:48:53 AM
Glad you found the problem :cheers:
Reply #8 on: June 24, 2016, 03:49:38 AM
us Offline Demel
Reply #9 on: June 24, 2016, 04:38:25 AM
This is was brilliant, unlike myself :facepalm: Simple yet effective.
Thanks. I'm ok with dropping the plain edge because I usually carry the Rebar with a folder so it isn't necessary. With the wrenches from Loki disassembly was a breeze.
ca Offline Toolslinger
  • Thread Killer 2015
Reply #10 on: June 24, 2016, 02:49:03 PM
Nice mod.
