Are you practicing for your First aid badge
Actually beer or any alcoholic beverage may not be a good idea at that moment. Alcohol widens the venes (that is why it's a no-no if you're moutaineering in winter; it causes you to lose heat much easily) and may increase your bleeding. In any case, I wish you a quick recovery Don't forget to apply for the badge
Quote from: ddogu on August 10, 2016, 09:45:20 AMActually beer or any alcoholic beverage may not be a good idea at that moment. Alcohol widens the venes (that is why it's a no-no if you're moutaineering in winter; it causes you to lose heat much easily) and may increase your bleeding. In any case, I wish you a quick recovery Don't forget to apply for the badge In my family saying that would be sacrilege
Some instant glue might help you.
Quote from: styx on August 10, 2016, 11:23:59 AMQuote from: ddogu on August 10, 2016, 09:45:20 AMActually beer or any alcoholic beverage may not be a good idea at that moment. Alcohol widens the venes (that is why it's a no-no if you're moutaineering in winter; it causes you to lose heat much easily) and may increase your bleeding. In any case, I wish you a quick recovery Don't forget to apply for the badge In my family saying that would be sacrilegeWell, gotta admit, what I said above probably would not stop me, if I had some rakija at hand
Quote from: Crow on August 10, 2016, 11:59:16 AMSome instant glue might help you.So might a trip to your local clinic or ER for some stitches. I hope you heal up quickly and cleanly man- and as soon as we get a first aid badge put together, it's yours!Def
You gotta be careful SG Look like you got yourself pretty good there Hate it when I cut myself on a knife that I have sharpened Makes you proud and sick at the same time
WP_20160810_025 by magpie2112, on Flickr
Quote from: Poncho65 on August 10, 2016, 02:04:41 PMYou gotta be careful SG Look like you got yourself pretty good there Hate it when I cut myself on a knife that I have sharpened Makes you proud and sick at the same time
Quote from: magentus on August 10, 2016, 01:59:26 PMWP_20160810_025 by magpie2112, on Flickr I'm reminded of the ill fated Spongebob Necker....(Image removed from quote.)The most often heard comment...."No way the little yellow guy would be that happy".
Quote from: SAK Guy on August 10, 2016, 04:17:54 PMQuote from: magentus on August 10, 2016, 01:59:26 PMWP_20160810_025 by magpie2112, on Flickr I'm reminded of the ill fated Spongebob Necker....(Image removed from quote.)The most often heard comment...."No way the little yellow guy would be that happy". I must know about the Spongebob Necker SG
Keep your hand elevated, to decrease blood pressure. Avoid using it (less muscle work, less pressure). 1. Sterilize the wound, clean it weel and just let the band aid hold the cut shut. 2. Use warm water to remove the band aid, so as not to have it pull the skin. 3. If WoundShut=False GoTo 1.4. Resume daily activities.Hope you heal well and fast!
Quote from: pfrsantos on August 10, 2016, 05:25:31 PMKeep your hand elevated, to decrease blood pressure. Avoid using it (less muscle work, less pressure). 1. Sterilize the wound, clean it weel and just let the band aid hold the cut shut. 2. Use warm water to remove the band aid, so as not to have it pull the skin. 3. If WoundShut=False GoTo 1.4. Resume daily activities.Hope you heal well and fast! +1 SG
