Attempt at restoring an unloved Super Tool
nz Offline Syncop8r
on: August 21, 2016, 01:22:11 PM
Oh, it needs more than just a clean!
- Can opener is broken
- Plain blade is broken off leaving just a stub stuck inside the handle
- Serrated blade has been ground down into a plain edge.  :ahhh
- Plier handles are very loose - should there be any springs or anything inside the handles?
- Dome on the sheath replaced with velcro (and LOTS of glue)  :facepalm:
nz Offline Syncop8r
Re: Attempt at restoring an unloved Super Tool
Reply #1 on: August 21, 2016, 01:27:40 PM
This poor thing has since had a soak in vinegar which didn't seem to remove much rust.
I then sprayed it with CRC and managed to free up some of the seized parts.
I managed to start dismantling it as one of the pivots was only finger-tight. Someone has messed with it - some of the pivots looked a little messed up.
Once Loki's tools arrived I finished dismantling and cleaned all the parts up, mostly with 400 grit sandpaper:
I may have lost track of the correct positions of some of the washers....
wales Offline Smashie
  • In Memoriam
  • Smurf it!
Reply #2 on: August 21, 2016, 02:27:31 PM
Big improvement so far :salute:
Si vis pacem, para bellum
us Offline zrxoa1
Reply #3 on: August 21, 2016, 03:27:08 PM
Sent from my Nexus 6 using Tapatalk
england Offline Kev D
Reply #4 on: August 21, 2016, 05:07:09 PM
Looking much better, hopefully you can bring back of its former glory.
Good luck   :tu:
Reply #5 on: August 21, 2016, 08:07:48 PM
Glad you went the refurbish route :cheers: Looks good so far and a whole lot better than before :cheers: Can't wait to see what 6ou are able to do with it :dd: :like:
Reply #6 on: August 21, 2016, 08:20:03 PM
I used to love little projects like this one, you'll find quite a few on this forum if you dig back far enough!
Using increasingly finer glass / sand papers you can usually get the tools back to close to new - wet and dry paper (1200 - 1500) usually does the trick for the final "polish". Its been a while since I did one, but if I remember properly, the washers simply go between the internal tools so should be pretty straightforward.
Do you have a replacement blade for it?
Well done for saving another tool in distress  :cheers:
us Offline chrono
  • Find me if you can...
Reply #7 on: August 21, 2016, 10:59:16 PM
I recommended wired wheels or brushs to knock the rust off. The wires will get to all the peaks and valleys while the sandpaper will just glide across. Your tool will not have many scratch lines either.
us Offline sLaughterMed
Reply #8 on: August 21, 2016, 11:28:07 PM
Looks like fun! Its nice to see where you plan on putting those parts now. Good luck  :cheers:
Laughter is the best Medicine
au Offline mr626
  • We sell products and get in fights
Reply #9 on: August 21, 2016, 11:48:08 PM
Great work- I love seeing tools being rescued!
And thanks for the reminder- I need on of loki's tool myself.
nz Offline Syncop8r
Reply #10 on: August 22, 2016, 02:39:42 AM
I used a small toothbrush-sized wire brush to get into some of the nooks and crannies.
I used the sandpaper on a sanding block where possible to try to sand flat.
This tool has plenty of scratches from abuse so I'm not too worried about sandpaper scratches.
It's more likely that this tool will be the donor for yours, for reasons that shall be explained soon....
Reply #11 on: August 22, 2016, 03:23:12 AM
:popcorn:
nz Offline Syncop8r
Reply #12 on: August 27, 2016, 12:35:43 PM
I have given everything a wipe with an oily rag and I am putting it together temporarily. A couple of the washer might be in the wrong place.
If one looks at the inside of each handle in turn (with plier end at the bottom), I have, from right to left (in the order one would put the tools on, if I have the pivots around the right way):
Handle 1: (top row of egg carton)
 *washer*
- serrated knife blade
- can opener
- phillips screwdriver
 *washer*
- small flathead screwdriver
- saw
 *washer*
Handle 2: (bottom row of egg carton)
- plain knife blade
- awl
- medium flathead screwdriver
- large flathead screwdriver
 *washer*
- file
 *washer*
Is anyone able to confirm this order is correct?
This is from trying to keep everything in order whilst dismantling it, also from looking at the washer-shaped imprint on the side of some of the tools. I think my Super Tool is missing a washer from having been dismantled sometime by a previous owner.
« Last Edit: August 27, 2016, 12:43:19 PM by Syncop8r »
nz Offline Syncop8r
Reply #13 on: August 27, 2016, 12:41:41 PM
It makes sense that washers go next to the serrated blade, file and saw to give them clearance from other tools/handles.
Reply #14 on: August 27, 2016, 02:08:19 PM
Looking at my ST now and the order of washers is correct   :tu:
nz Offline Syncop8r
Reply #15 on: August 27, 2016, 02:35:52 PM
Thanks Steve  :cheers:  Therefore I am missing a washer.
Also, for some reason one of the pliers remains loose when I tighten the pivot.
Reply #16 on: August 27, 2016, 03:08:16 PM
Is there anything stuck in the female side of the plier pivot maybe preventing the screw form tightening as far as it needs too ?
nz Offline Syncop8r
Reply #17 on: August 27, 2016, 11:16:31 PM
There didn't seem to be.
I measured the length of the pivot when it was tightened as much as I dared. Then I disassembled and just did up the two pivot pieces alone and got the same distance.
I measured the other pivot and it was ever so slightly smaller, so I swapped them over and it all works fine now. The slightly longer pivot has that little washer thing on it.
Reply #18 on: August 27, 2016, 11:19:22 PM
yes, that would do it  :tu:
nz Offline Syncop8r
Reply #19 on: August 27, 2016, 11:30:12 PM
It's all assembled now and I'm enjoying opening and closing it. :dd:
Next job is to document what needs fixing now that I can see what I'm dealing with....
Reply #20 on: August 28, 2016, 05:38:37 AM
Bravo, great job getting this tool moving.
Reply #21 on: August 28, 2016, 06:16:36 AM
Glad to hear an update about it buddy :cheers:
The little washer thing is the lanyard attachment point :tu:
Can't wait to hear more :dd:
nz Offline Syncop8r
Reply #22 on: August 28, 2016, 09:56:35 AM
Thanks, I wondered if that's what it was. :tu:
Reply #23 on: August 28, 2016, 11:35:01 AM
Nice work/thread  :tu:
nz Offline Syncop8r
Reply #24 on: August 29, 2016, 09:06:34 AM
Reply #25 on: August 29, 2016, 09:51:01 AM
That looks a bit happier doesn't it?  :tu:
Reply #26 on: August 29, 2016, 02:20:21 PM
Big improvement buddy :cheers: :cheers: :cheers:
Glad you went to the trouble of trying to fix this up :like:
Reply #27 on: August 29, 2016, 04:32:16 PM
Looking good :tu: Im glad those parts found a good home.
Reply #28 on: August 29, 2016, 07:43:51 PM
What a terrific restoration.   :salute:
nz Offline Syncop8r
Reply #29 on: August 29, 2016, 11:03:10 PM
I take it it's meant to be bent up?
Total Receipts: $55.09
PayPal Fees: $3.15
Net Balance: $51.94
Below Goal: $248.06
17%
