October 30 day minimalist SAK challenge
hiraethus · 1369 · 56789
nl Offline glenfiddich1983
Re: October 30 day minimalist SAK challenge
Reply #1110 on: October 26, 2016, 01:07:06 PM
Where's the visuawl awl joke Glen-Fiddy?  :pok:
Didn't bring my awl today. But I can offer R2 a toothpick!
[--- arms length ---] (-.-)
                                ^-- where the cat sits
us Offline zrxoa1
Reply #1111 on: October 26, 2016, 01:16:19 PM
Day 26...
My Ambassador helped to trim my eyebrows.  No picture of that, so this will have to do...
Sent from my Nexus 6 using Tapatalk
wales Offline magentus
  • mmmmm SAKrelicious
Reply #1112 on: October 26, 2016, 01:56:25 PM
Oh way to go G-Fiddy! You've caused an oil leak  :facepalm: I'm sending you the Cleanup Bill bill, (Medical Bill is also the cleaner).
WP_20161026_007 by magpie2112, on Flickr
us Offline twiliter
Reply #1113 on: October 26, 2016, 02:57:03 PM
26. Going with the OC Settler, this is going to be challenging.  :ahhh
The Settler is a good companion knife, but my dedicated tools will definitely see some use today.  :salute:
us Offline Mizedog
  • Mizedog
Reply #1114 on: October 26, 2016, 03:54:52 PM
Day 26/30
The Classic makes it so easy to access caffeine;)
Sent from my SAMSUNG-SM-N900A using Tapatalk
us Offline jalind
Reply #1115 on: October 26, 2016, 05:39:43 PM
We're with you awl the way today (even if it doesn't have one)!
John
us Offline jalind
Reply #1116 on: October 26, 2016, 06:12:18 PM
Day 22:
(Attempting it ALL single layer!)
Yesterday, the recently arrived Prince was polished, cleaned and lubed. Today it has the honors. Went to find a large serving fork when I was carving the Cornish hen and couldn't find one, nor could I find any large serving spoon or a ladle. I've little doubt where they are and I'll never see them again. Snagged these while grocery shopping (Meijer, a regional store chain similar to Target), and they're quite large, but robust and serviceable which is what matters most. The price was right too. Unfortunately they're imprisoned to very heavy cardboard hang tags by large zip ties that cannot be broken by twisting the utensils. Out comes the Prince to perform the Dirty Deeds Done Dirt Cheap.
Recalling The Wedge is one of the Six Classical Simple Machines, I first attempt to use it double, by slipping it under the zip tie with its spine against the hang tag, using the height of the blade as a wedge to force its cutting edge, another wedge, to cut the tie.
This works, but not very well, as the spine of the blade digs into the cardboard. The cutting edge wedge is being forced to cut the entire width of the zip tie all at once. Using the cutting edge as a wedge against the side of the zip tie should require much less force to cut it. The following may be disturbing to Medical Bill, but the Danger Club living life on the precipice is no stranger to the hazards here.
This works much better and by using just enough force, it glides gently through the zip tie without impacting and wedging apart the dermal layers of flesh on my thumb. The remaining zip ties are quickly cleaved and I declare a victory for the Victorinox Prince.
While doing the photos I discovered a thumbnail needed a bit of touch-up. The unique file on the Prince does the job quickly.
The Prince is a nice one and its major feature is the file. With the Ambassador and its scissors I can understand why the Prince was discontinued. Too bad they couldn't have found a way to put this file on the multi-layer Executive as it's much nicer with this side slotted and a very fine cross-cut on the other side.
John
P.S.
The Six Classical Simple Machines from which all mechanical machines are constructed using some combination of them:
  • Lever
  • Wheel and Axle
  • Pulley
  • Inclined Plane
  • Wedge
  • Screw
« Last Edit: October 26, 2016, 06:28:11 PM by jalind »
John
us Offline twiliter
Reply #1117 on: October 26, 2016, 08:58:17 PM
John
Thanks John, I'm with your single layer method today actually. It's not easy to carry a basic jack knife for me anymore, old cross or not. I think it's making me older and crosser...  ;)
Reply #1118 on: October 26, 2016, 09:11:13 PM
I better lawyer up then  :wait:
Where's my attorney at awl when I need him  :think:
us Offline jalind
Reply #1119 on: October 26, 2016, 09:16:08 PM
When you're back's against a wawl . . . and you need to awlyer up, better call Sawl!
dk Offline T14
  • Embrace the SAK
Reply #1120 on: October 26, 2016, 10:01:14 PM
T14 Day 26:
There is Bantam on the Jar  :cheers:
All I know is that I don't know anything - but I can't prove it!
gb Offline Oxford_Guy
Reply #1121 on: October 26, 2016, 10:18:45 PM
Day 25
Carried my new Danish green Cadet today, was used to open a special package from Hiraethus...
"We broke into Mir using a Swiss Army knife. Never leave the planet without one." - Chris Hadfield, Astronaut
Reply #1122 on: October 26, 2016, 10:19:34 PM
Day 25
These two were a Compact and Explorer when I originally sent them to him...
us Offline Mizedog
  • Mizedog
Reply #1123 on: October 26, 2016, 10:21:22 PM
I live at 7,000 feet above sea level,  and found out the hard way when I moved here,  that you can't just peel open a yogurt the conventional way.  If you do,  you will get sprayed  with projectile yogurt.
What's the solution? The Classic,  of course!
Poking a small hole in the lid depressurizes the container so it can be safely peeled back.
I can't tell you how many times I've seen people here with yogurt all over their face (along with a victimized look).
« Last Edit: October 26, 2016, 10:24:20 PM by Kurt Misner »
dk Offline T14
  • Embrace the SAK
Reply #1124 on: October 26, 2016, 10:33:46 PM
Day 25
Lovely x3  :like:
Reply #1125 on: October 26, 2016, 10:45:02 PM
Day 25
Nice! Well done Hiraethus and congrats Ox-Guzzle  :salute:
us Offline zrxoa1
Reply #1126 on: October 26, 2016, 11:01:26 PM
Day 25
I'm still new to SAKs, what was done to them?
Sent from my Nexus 7 using Tapatalk
Reply #1127 on: October 26, 2016, 11:11:49 PM
Day 25
They were converted into a modern Yeoman and a Climber... The original Yeoman model is long discontinued: http://www.sakwiki.com/tiki-index.php?page=Yeoman
us Offline zrxoa1
Reply #1128 on: October 26, 2016, 11:46:17 PM
Day 25
Nice!  I'd like to remove the can opener on my Centurian and replace it with that straight Phillips driver!  Then add a hook underneath where the current Phillips driver is.
us Offline jalind
Reply #1129 on: October 27, 2016, 12:25:13 AM
Day 25
I'd thought about doing this conversion myself to create a Yeoman Plus from an Explorer Plus, and give the resulting Climber to a deserving friend, but it's on a back burner indefinitely as I'm well satisfied with the Explorer Plus for now. They're the two logical models to start with.
John
Reply #1130 on: October 27, 2016, 12:42:36 AM
Day 25
John
You don't need an Explorer Plus to create a Yeoman Plus, the Compact already has all the Plus bits, just an ordinary Explorer is needed
se Offline Fortytwo
Reply #1131 on: October 27, 2016, 01:20:56 AM
Day 26
Today I though I should say a few words about my least used tool on the Soldier, the screwdriver. It's not often you see large flat screws these days and especially with such a thin slot. I am actually thinking that this may well be the only tool here meant* to serve multiple purposes. The slim edge together with the fact that the SwissTools comes with prybars/crate openers makes me think this is the intended use here as well.
*The can opener works surprisingly well for lifting caps but I don't think that was intentional.
us Offline twiliter
Reply #1132 on: October 27, 2016, 01:30:55 AM
I think so too 42, I use them for prying, levering and scraping quite a lot. The ones I like best are on the Spirit and the locking 111 version, but neither is as heavy duty as the old Soldier knife.
us Offline jalind
Reply #1133 on: October 27, 2016, 01:46:16 AM
Day 25
John
us Offline JasonJ
Reply #1134 on: October 27, 2016, 02:22:58 AM
Day 25:  I think
I must've missed yesterday... Or a day.
Made a projector screen for the basement today... Pioneer came in handy trimming a piece of the mdf.
us Offline JasonJ
Reply #1135 on: October 27, 2016, 03:07:13 AM
Day 26:
Looks like I drank "awl" of my iced tea!
Reply #1136 on: October 27, 2016, 04:02:26 AM
Day 26
Package duty again for the black Classic with the purple fob.
us Offline kaput
Reply #1137 on: October 27, 2016, 06:51:26 AM
26/30 always with me
fr Offline m47mu74nt
Reply #1138 on: October 27, 2016, 07:48:11 AM
If anyone wondered from where this lovely brown micarta came from, here is a hint :  :angel:
Reply #1139 on: October 27, 2016, 08:16:57 AM
Day 27, compact!
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
