http://forum.multitool.org/index.php/topic,67028 I only ended up going down that road because I couldn't get hold of any reasonably-priced deep carry clips here though.If you already have clips, drilling and tapping the scales is the way to go. For alox that means disassembling the knife. Easier for celidor, just remove the scale, but as Steve said you'd need some sort of backing in the scale to get a secure hold. Filling the back of the scale with "Quik Steel" type epoxy putty might be an option, they say it can be drilled and tapped when cured.
Quote from: shibafu on October 13, 2016, 06:48:46 PMhttp://forum.multitool.org/index.php/topic,67028 I only ended up going down that road because I couldn't get hold of any reasonably-priced deep carry clips here though.If you already have clips, drilling and tapping the scales is the way to go. For alox that means disassembling the knife. Easier for celidor, just remove the scale, but as Steve said you'd need some sort of backing in the scale to get a secure hold. Filling the back of the scale with "Quik Steel" type epoxy putty might be an option, they say it can be drilled and tapped when cured.No need to disassemble Alox for clips. A drill bit and 2 taps is all you need. A regular tap to start the threads and a bottom tap to finish it off . Sent from my iPhone using Tapatalk
