Pruning blade mod.?
00 Offline ogrdnet
Pruning blade mod.?
on: October 18, 2016, 02:46:32 AM
I just picked up a Huntsman which I was hoping to mod by replacing (maybe) the bottle cap lifter with a pruning blade.  My question however is where I can find said blade?
Sent from my XT830C using Tapatalk
id Offline jaya_man
Re: Pruning blade mod.?
Reply #1 on: October 18, 2016, 03:01:31 AM
Try looking for an Alox Pruner or Harvester... The pivot holes on the pruning blade will have to be reduced to 2.5mm in order to fit the Huntsman
us Offline sLaughterMed
Reply #2 on: October 18, 2016, 04:46:04 AM
The pivot hole size difference wont matter, the .5mm difference is negligible.
I know that the pruner blade will fit in place of the small blade on 91mm models. It fits in the can opener slot on 93mm models, and might work there on the 91mm models too.  No idea about the bottle opener slot
Laughter is the best Medicine
00 Offline ogrdnet
Reply #3 on: October 18, 2016, 05:03:00 AM
On a separate note, does the magnifying glass have to have the philips screwdriver across, or will other tools fit?
gb Offline Oxford_Guy
Reply #4 on: October 18, 2016, 09:11:38 AM
Syph used to do a 93mm mod with both the cap lifter and can opener opposite the Philps, so perhaps those two could also go opposite the magnifying glass?
"We broke into Mir using a Swiss Army knife. Never leave the planet without one." - Chris Hadfield, Astronaut
Reply #5 on: October 18, 2016, 06:57:29 PM
They don't fit on the 91mm frame without some grinding down at the ends
us Online Poncho65
Reply #6 on: October 21, 2016, 02:12:29 AM
This is some good stuff :cheers: I am wanting to get an inline awl and now either the pruner blade or the electrician blade in lieu of the can opener  :cheers:
:popcorn:
Reply #7 on: October 21, 2016, 11:31:00 AM
 :popcorn:
The electrician blade is probably more versatile, though the pruner will be useful for opening clamshell packaging and peeling oranges, as well as pruning, obviously!
us Offline JamesJ
Reply #8 on: October 25, 2016, 07:21:00 PM
I've got a pruner knife here, the 100mm single blade type fromt he "hoticultural knives" line from Vic.
It seems bigger than the 93mm pruner blade...micrometer says 2.01mm tang thickness...
Old style 91mm main blade (without the spacer built into the outer liner) says 2.43mm, pen blade on same 91mm knife says 1.48mm
So it seems like I could put the 100mm knife pruning blade in place of the MAIN blade (This pruning blade is offset as if to allow for a small blade on the other end).
I'd need a .42mm spacer though.
Cap lifter layer reads as 2.0mm
So..perhaps the pruning blade from the dedicated 100mm Pruning Knife would work in the place of the cap lifter OR can opener, but would take up the entire layer...
-JJL
instagram: jamesjlarue (warning, lots of cat pics along with the SAKs)
Reply #9 on: October 25, 2016, 10:09:50 PM
That's a pretty interesting idea. I think it might work on replacing a thinner new blade, depending on the shape of the spring.
