SOG phillips driver
us Offline Kampfer
  • Tactical Desk Jockey
SOG phillips driver
on: December 13, 2016, 10:21:09 PM
Just give a quick shout for SOG phillips driver.
It blows.  :td: Not only it slips a lot, it is too big for small screws and too small for the bigger ones.
When use in conjunction with non-locking MT just makes the saturation much worst.
 :surrender:
http://www.sogknives.com/phillips-screwdriver-1.html
Re: SOG phillips driver
Reply #1 on: December 14, 2016, 02:00:44 AM
I agree, other than I do not consider the implement any less appalling in a locking frame
es Offline ThePeacent
Reply #2 on: December 16, 2016, 03:04:19 PM
hateful invention, that driver  :twak:
Easily solved
« Last Edit: December 16, 2016, 03:07:59 PM by ThePeacent »
My toys:
fi Offline Padre
Reply #3 on: December 16, 2016, 08:53:54 PM
I found it good on some countersunk heads, But yeah, its pretty bad compared to many others...
Leatherman:
Charge TTi, AL, Squirt PS4, Surge, Juice XE6, CS4, S2, ST300, Crunch, OHT, MUT, Rebar, Brewzer, Signal, Raptor, Tool Adapter, Croc, Wave, Style CS, Freestyle, Skeletool RX, Micra, Wingman
SOG:
PPP, PowerLock, SwitchPlier 2.0, Paratool, PowerAssist, Reactor, CrossCut, PowerPlay
Gerber:
FliK, MP600 ProScout, MP600 blunt, Dime, MP-1, Diesel, MP400
Bahco:
MTT151, MTT051, MTT121
Knives:
Spyderco PM2, Tatanka, Bug, ZT 0452CF, CS Recon1XL, Benchmade 940-1 and 482
SAKs:
Too many to list here...
us Offline clown
  • Learn to swim...
Reply #4 on: December 18, 2016, 02:20:36 AM
Easily solved
Is that a plug and play swap or would it need some modification?
Reply #5 on: December 18, 2016, 08:38:18 PM
Easily solved
it was plug and play (that last one especially, as the driver locks into place but the lock has to be engaged with your finger, otherwise it wiggles and has play)
My toys:
Reply #6 on: December 20, 2016, 03:19:03 AM
Easily solved
I do quite :like: that mod Peacent :cheers: :cheers: :tu:
dk Offline Troels
Reply #7 on: February 24, 2017, 11:17:28 PM
Its wiers how many of the tools SOG got wrong  :facepalm: ...  phillips driver that dont drive much, scissors that barely cuts paper, the dull file ... any others ?
... at least the pliers has good recommendations  :tu:
se Offline Fortytwo
Reply #8 on: February 26, 2017, 04:46:37 PM
Don't forget the can('t) opener.
dk Offline Troels
Reply #9 on: February 26, 2017, 06:55:26 PM
us Offline Kampfer
Reply #10 on: February 27, 2017, 08:53:30 AM
Yep, the infamous cant opener.
us Offline Wallace72
Reply #11 on: February 27, 2017, 05:24:30 PM
and the crappy chisel grind blade...at least I never feel bad taking a bench grinder to it.
The Americanized tanto awl is a bit odd too but at least that has functionality.
Don't the phillips cast shank snap a lot too under little pressure?
us Offline Kampfer
Reply #12 on: February 27, 2017, 08:46:01 PM
While the awl is pointy and sharp, I always feel it was made for leftyies
dk Offline Troels
Reply #13 on: February 27, 2017, 09:39:01 PM
Exactly the grinding is on the wrong side of the awl  :doh:
I messed it up my self while making an awl out of a screw driver on a Gerber mp600 > its quite anoying with a lefty awl for right handed person :doh: :doh:
I have a Sog PPP on the way so be intersting with some first hand impressions  :)
« Last Edit: February 27, 2017, 09:40:49 PM by Troels »
se Offline Fortytwo
Reply #14 on: February 28, 2017, 12:45:22 AM
The blade too seems to be for left handed people, in no other way can I explain the choice of side the grind is on. As it is the bevel is hidden from sight, and since it's a chisel grind I can't use the side towards me to see how it's angled to the workpiece. This means less precise cuts.
The chisel grind could even bring some extra use as a great marking knife if it was inverted which make this an extra missed opportunity.
