Warning: this topic has not been posted in for at least 120 days.Unless you're sure you want to reply, please consider starting a new top
(In an effort to keep Nomad from feeling bad about starting an old thread noone might care about)
QuoteWarning: this topic has not been posted in for at least 120 days.Unless you're sure you want to reply, please consider starting a new topIt's midnight and I'll resurrect whatever damn threads I like, thank you very much Mr Automatic Warning guy!If the Fuse had an Awl instead of the second Flat head screwdriver, and a second blade (Serrated Sheepsfoot) instead of the Scissors, it just might make me a happy scout.
1) Get rid of the silly lanyard ring and the waste-of-space spacer alongside it.2) Swap the scissors out of handle A and put it in handle B where the lanyard ring and spacer were.3) Insert sheepsfoot blade (or diamond file blade!) or whatever the heck into spot vacated by scissors.
Quote1) Get rid of the silly lanyard ring and the waste-of-space spacer alongside it.2) Swap the scissors out of handle A and put it in handle B where the lanyard ring and spacer were.3) Insert sheepsfoot blade (or diamond file blade!) or whatever the heck into spot vacated by scissors.Is that possible, or are the scissors too big and prevent the plier from folding away neat?
Since my girlfriend dropped the calipers behind the damn couch
Blast:I.D. 13mmKick:I.D.: 9mm
Some of you may spot some strange coloured dots on the blade in the first pic.I want to assure you these are Go-Faster markings, nothing more.
OK - what did you do to the SAK? Did you set fire to it?
