I'm gonna check the auction bay, but if anyone knows of a 91mm Waiter (and doesn't want it themselves lol) can ya PM me
Good luck. The 91mm Waiter Plus is the one knife on my wish list that I don’t expect I’ll ever find.
Side view showing the thickness. The oak started at 4mm thick. Now a little less from the sanding, but does create a bit more bulk to the Waiter!(Image removed from quote.)Sent from my Nokia 1 using Tapatalk
Looks great GreyLife!Sent from my iPhone using Tapatalk
Thanks, no power tools were used! It was mainly done using tools from SwissChamp and Leatherman. The fine finishing was all sandpaper, finishing with 1000 grit paper and teak oil. The grooves for the tools were done with the file/saw from SwissChamp, and for fine finish wrapped sandpaper around the file. To get the initial positions of the rivets, I gently squeezed the SAK and wood in a soft jaw vice and then used the chisel tool from SwissChamp to 'drill' the holes until the wood lay flat against the side of the SAK. Finally I used superglue to hold the scales on. Hope this helps! Sent from my Nokia 1 using Tapatalk
...got a Wenger Entree' version. Has no split ring, checked our Wiki but...didn't see anything by phone...just wondering...
Picture?
...you'll have to settle for the Sak Wiki above. I'm pic challenged right now...
That's an awesome mod Greylife!
+1
Found this on the Home Depot website. A knife set and block that not only includes a Waiter, but a place for it in the block. Personally, I'm not sure about combo tool vs. regular openers. Small cans, yeah, my Waiter and Bantam do just fine. Big cans; I opened a huge can of green beans with my Bantam a few months back, and it was really testing on the pins. (Image removed from quote.)
Found this on the Home Depot website. A knife set and block that not only includes a Waiter, but a place for it in the block. Pretty neat, but I keep a full-sized Nogent Le Kim in my block, and I'm sure the Waiter would end up in my pocket; even though I already have and use one. (Image removed from quote.)
Will be carrying the Waiter or Entre' more as Spring turns to Summer and we hope for gatherings to increase!
