Day 23Back on night shifts so not much done here.. Is that what you call monkey business? (Image removed from quote.)It's not failure if you learn something from it
Quote from: kottskrapa on May 08, 2017, 04:35:09 PMDay 23Back on night shifts so not much done here.. Is that what you call monkey business? (Image removed from quote.)It's not failure if you learn something from itNice picture (as long as the candle isn't lit)
That last pic is nice and peaceful looking
Day 25 Not much sleep and lots of errands, hopefully mail duties later on(Image removed from quote.)It's not failure if you learn something from it
Not a bad mail call at all
Day 26Had a dentist appointment this morning (routine check) and found out that my tung piercing had started to wear down the skeleton behind a tooth so it boiled down to the either the piercing go or I will lose the tooth.. So it is bye bye piercing but after 10+ years it feels a bit wierd and empty.. (Image removed from quote.)It's not failure if you learn something from it
Quote from: kottskrapa on May 11, 2017, 09:27:07 AMDay 26Had a dentist appointment this morning (routine check) and found out that my tung piercing had started to wear down the skeleton behind a tooth so it boiled down to the either the piercing go or I will lose the tooth.. So it is bye bye piercing but after 10+ years it feels a bit wierd and empty.. (Image removed from quote.)It's not failure if you learn something from itI can imagine, after 10 years.
Coffeeeee! Almost at day 30!
