Nice one! It's not failure if you learn something from it
The Pythagorean theorem in 12 Classics.
Quote from: Ronald Schröder on May 24, 2017, 08:38:34 PMThe Pythagorean theorem in 12 Classics. Cool!Now make one in 5, 12, 13! And 12, 35, 37! And 48, 55, 73!How many Classics do you have?
what if you were to switch things up and mix in the 84mm, 111mm and 93mm?
Brilliant.The full representation requires drawing the full rectangulars, which means 4x the SAKs used. But this is an elegant abstract solution, similar to the one Pythagoras used the first time. Perhaps he used tiles or building blocks or something. This way he didn't have to prove that the angle is right, something you would have to prove when using sticks, or SAKs.
Quote from: styx on May 24, 2017, 09:46:03 PMwhat if you were to switch things up and mix in the 84mm, 111mm and 93mm?I think it can be done with 12 times 84 times 93 times 111 SAKs at most.
Quote from: Ronald Schröder on May 24, 2017, 09:58:25 PMQuote from: styx on May 24, 2017, 09:46:03 PMwhat if you were to switch things up and mix in the 84mm, 111mm and 93mm?I think it can be done with 12 times 84 times 93 times 111 SAKs at most.Maybe SAK Guy can do it
Finally somebody has proven a universal truth, smart people collect SAKs and MTs
Quote from: pa_strunk on May 24, 2017, 10:28:44 PMFinally somebody has proven a universal truth, smart people collect SAKs and MTs correlation vs causation...I'm really kinda dumb... but then again I ONLY collect SAKs, not MT's too...
Quote from: El Corkscrew on May 24, 2017, 10:48:56 PMQuote from: pa_strunk on May 24, 2017, 10:28:44 PMFinally somebody has proven a universal truth, smart people collect SAKs and MTs correlation vs causation...I'm really kinda dumb... but then again I ONLY collect SAKs, not MT's too...Nobody is perfect. I think.
Quote from: kottskrapa on May 24, 2017, 08:40:54 PMNice one! It's not failure if you learn something from it+1
Quote from: styx on May 24, 2017, 09:46:03 PMwhat if you were to switch things up and mix in the 84mm, 111mm and 93mm?Way to throw a wrench in the gears, Styx!
Quote from: pa_strunk on May 24, 2017, 10:28:44 PMFinally somebody has proven a universal truth, smart people collect SAKs and MTs I'm not smart. I'm horrible at math and exact sciences in general. But, then again, I'm not a collector xDEnviado do meu iPhone usando Tapatalk
