Knives hit frame in powerlock
us Offline NetsNJ
on: August 21, 2017, 01:27:23 AM
I love the power lock, but I've noticed that there is basically zero knife rest. You can just push the blade edges directly into the handle.  (I have a similar issue on some of my Gerber mps, but not as bad.)
Does anyone else have an issue with this?
« Last Edit: August 21, 2017, 01:29:41 AM by NetsNJ »
Re: Knives hit frame in powerlock
Reply #1 on: August 21, 2017, 01:48:06 AM
I noted a similar problem over here, BlackTip Fishing Multi-Tool.
Any pressure to the back of the blade will push the cutting edge into contact with the lock release.
It happens when closing the blade too.
es Offline ThePeacent
Reply #2 on: August 21, 2017, 03:56:30 PM
My Blacktips have the same problem, I've learned to live with the dent in the blade on all of them...
such a  :facepalm:
My toys:
us Offline NetsNJ
Reply #3 on: August 21, 2017, 08:18:58 PM
I think I am going to try to install some sort of plastic blade rest in the corners.   :-\
Blade edge hitting plastic has to be better than blade edge hitting sheet metal.   ???
