Login
Register
Menu
Home
Help
Forum
Tool Talk
The Mod Squad
Hacker badge request: Waiter to Apprentice 84mm SAK modification
T14
8 ·
2182
« previous
next »
Print
Pages:
1
Go Down
T14
Hero Member
660
Embrace the SAK
on:
November 04, 2017, 09:45:39 PM
Greetings. Let us dive right in.
Tools needed
- Small ball peen hammer
- Small anvil (the flat side of a hammer or axehead will do in a pinch)
- Small hacksaw or razor saw.
- Abrasive like a metal file or sand paper
- Small pry tool for scale removal(I use a SAK can opener)
Materials needed
- Naked victorinox waiter
- donor backspring phillips. Mine came from a 91mm tinker model
- a small length of 2.2mm brass rod.
Step-by-Step procedure
The following list corresponds to the pictures no. attached at the bottom of this and subsequent posts.
Get your tools and materials together
Remove the small button head rivet on the corkscrew pin. I used the saw. You could also use a drill or a file
Once the head is removed you can remove the pin by punching it through from the flush side, or by prying it out from the reverse side. I did the latter
Once the pin is out remove the corkscrew and slide the phillips drive into place
Next you insert the brass rod into place and cut it to size with the saw. The brass rod should stick out 1-2mm on either side of the liners
If you used a saw the cuts should be nice and perpendicular to the length of the pin. If you used flush cutters you should use a file to straighten the cut
Its hammer time. place the knife across your anvil in such a way that the bottom of the pin is the only point of contact. use the ball end of the hammer to gently mushroom the pin ends on either side. I use about 20 gentle taps on one side before flipping the knife over and doing the other side. Repeat until both side are mushroomed out and there is no lateral play between the liners. I used a few hundred taps. About 5 minutes worth of peening all in all
When you are done the pin should look something like this. Reattach the scales. I do it using a "TV remote thumb squeeze"
Reinsert your scale tools of choice and slip your new apprentice into your pocket
Last Edit: November 04, 2017, 10:03:11 PM by T14
All I know is that I don't know anything - but I can't prove it!
Merit Badges
T14
Hero Member
660
Embrace the SAK
Re: Hacker badge request: Waiter to Apprentice 84mm SAK modification
Reply #1 on:
November 04, 2017, 09:47:24 PM
Last Edit: November 04, 2017, 10:02:23 PM by T14
Merit Badges
T14
Hero Member
660
Embrace the SAK
Reply #2 on:
November 04, 2017, 09:48:45 PM
Cheers
-Tom
Last Edit: November 04, 2017, 09:53:12 PM by T14
Merit Badges
magentus
Admin Team
Absolute Zombie Club
20,883
mmmmm SAKrelicious
Reply #3 on:
November 04, 2017, 10:53:31 PM
Awarded! Great write up T
Merit Badges
SteveC
Global Moderator
Just Bananas
72,479
Reply #4 on:
November 04, 2017, 11:00:58 PM
Congrats
Merit Badges
MusicMen
No Life Club
2,320
21 Badges for Eagle
Reply #5 on:
November 05, 2017, 01:57:21 AM
Congratulations
BUCK:
X-Tract
, 360
GERBER:
Clutch, Shortcut, Dime*, DimE*, Octane & Crucial FAST
Diesel*, Nickle*, Bullrush, MP600 BN, Flik & MP600DET* all in BO
LEATHERMAN:
Skeletool, Style PS, CS, ES* & Style*, Juice S2(X2), SC2, C2,
Pro, XE6
SOG:
PowerAccess, Blacktip*, HD PPP
VICTORINOX:
SwissTool Std, X(CS), & RS all with red logo, Spirit XBS
*=mod
Merit Badges
T14
Hero Member
660
Embrace the SAK
Reply #6 on:
November 05, 2017, 09:27:49 AM
Merit Badges
George S
Newbie
35
Reply #7 on:
December 29, 2017, 02:30:06 AM
That is a jolly good write-up!
I've built three SAKs 'from the pins up' now, and your great how-to showed me that there's always more to know; I learnt some useful tips, so many thanks for that.
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
The Mod Squad
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$70.65
PayPal Fees:
$4.43
Net Balance:
$66.22
Below Goal:
$233.78
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
