Showcase: Mods to plier-based multitools
00 Offline Dutch_Tooler
Re: Showcase: Mods to plier-based multitools
Reply #90 on: February 18, 2018, 04:00:12 PM
:nanadance: :nanadance: :nanadance: :nanadance: :nanadance:
That could be applied for, if there is enough interest, I guess. Hadn't intended to so far though.
It would be nice to keep this information
On the first page for anyone to see if they
are thinking of doing a mod  :think:
Or to ad more mods after someone has done some
It's just when I was looking for mods that I found it
A bit hard to find the mods I was looking for
It would of been a lot easier if it was all on the first page as a sticky :tu: :like:
 :imws:
 :gimme: sticky!!
Requested.
Cheers!
Dutch_Tooler
Reply #91 on: February 18, 2018, 04:15:51 PM
Excellent  :woohoo:
es Offline ThePeacent
Reply #92 on: February 18, 2018, 07:12:05 PM
thanks! It'll prove useful in the future   :salute:
My toys:
Reply #93 on: February 19, 2018, 04:06:36 AM
Someone beat me too it :salute: Congrats on the sticky :like:
Reply #94 on: February 19, 2018, 07:13:24 AM
Thanks (whoever it was :D) :cheers:
Cheers!
Dutch_Tooler
gr Offline Sakpan74Gr
Reply #95 on: February 27, 2018, 06:50:27 PM
Hi guys, I admire your great work, and I found the courage to share with you two humble mods I did.
Tool mames: Leatherman Style PS NN, and  Leatherman Skeletool CX NN
Basis: Leatherman Style PS, and  Leatherman Skeletool CX
Aim: Needlenose Pliers
Mods: Reshaping the pliers into needlenose pliers for greater reach.
I enjoyed the Deluxe Tinker mini pliers because they can reach into tight places and help grab stuff that normal pliers can't. Being the EDC guy at work with always a solution to any problem in my pockets, you can imagine my embarrassment when my Leatherman Style PS pliers couldn't remove a broken key from a keyhole.
So enter the Style PS NN:
Στάλθηκε από το HUAWEI VNS-L31 μου χρησιμοποιώντας Tapatalk
Reply #96 on: February 27, 2018, 06:52:00 PM
At the top you can see the original tool, then one part of the pliers treated with the Dremel 3000, and a comparison with the Victorinox pliers.
Reply #97 on: February 27, 2018, 06:58:27 PM
Tool name: Leatherman Skeletool CX NN
Basis: Leatherman Skeletool CX
Aim: Skeletool with needlenose pliers.
Mods: Needlenose pliers
I treated my new Skeletool with my Dremel 3000 to optimise the pliers for better reach.
You can see the original, one part done the complete pliers done, and the tool I used.
Reply #98 on: February 27, 2018, 08:39:12 PM
Nice refinements Sakpan, thanks for sharing :tu:
Cheers!
Dutch_Tooler
Reply #99 on: February 27, 2018, 08:59:47 PM
Nice job Sakpan on those pliers :tu: :like: :like:
Reply #100 on: February 27, 2018, 10:53:29 PM
 :like: :tu:
id Offline jaya_man
Reply #101 on: February 28, 2018, 03:53:15 AM
:like: :tu:
+1 :like:
us Offline Random_Username
Reply #102 on: March 06, 2018, 04:12:12 AM
Just bought a lightly-used Wave today. It won’t be long before I post it on this thread. Now to track down a rebar for parts/pliers!
Reply #103 on: May 11, 2018, 09:41:46 AM
Leatherman chisel bit mod.
Since the second flat driver was essentially redundant, I turned it into something more useful.
Reply #104 on: July 30, 2018, 10:52:27 AM
Tool name: SOG Power Access Deluxe Plus
Basis: SOG Power Access Deluxe
Aim: Install a file in the PAD. What SOG call a file isn't.
Mods: Inserted a ST300 file after drilling a new pivot hole and profiling a locking surface into it
Links: https://forum.multitool.org/index.php/topic,78075.msg1731938.html#msg1731938
« Last Edit: July 30, 2018, 10:53:54 AM by Dutch_Tooler »
Cheers!
Dutch_Tooler
00 Offline Sam Lim
Reply #105 on: July 30, 2018, 06:22:30 PM
Tool Name: Matte
Basis: Gen II Leatherman Wave
Aim: Customizing to what I need. More for fun really... ;)
Mods: A few of them...
Links: https://forum.multitool.org/index.php/topic,76771.0.html
Tool frame and pliers are acid washed giving it a duller appearance. Thus, the name Matte.
Most of the OHO tools are replaced other than the file. Most recent added is the small utility cutter. May change out the keyport tool as it underutilized. Probably going to switch in a BO 154cm blade. :think:
Some changes on the internal load out. Awl added from the rebar, eyeglass screwdriver sharpened to a needle point. Added a 3D philip and moved the bit exchanger to the outer frame. Drivers are high on my priority list so it pisses me off when I encounter regular/common screws I cannot tackle. On Matte, I have quite a number of drivers - Philips no.0, no.1, no.2( 3D), no.3 and Long shank (no.2). Flat Head- 3.5mm, 4mm and a larger long shank. Borrowed the idea of the long shank on the pocket clip from Obi. :angel:
se Offline RF52
Reply #106 on: July 30, 2018, 06:29:40 PM
Great mods guys :like:
Reply #107 on: July 30, 2018, 06:32:51 PM
+1 :like: :like:
il Offline pomsbz
Reply #108 on: July 30, 2018, 06:46:31 PM
Tool Name: Um, modded Charge? Never thought of naming it.
Basis: Leatherman Charge AL
Aim: Two bit tools always available and more readily available scissors. To create a great work/urban tool rather than the Charge/Wave which tries to be rather too many things at once.
Mods: I swapped out the scissors and eyeglass tool for a second bit holder. That was the easy part. I then switched out the serrated blade for 91mm SAK Scissors. These required the pivot hole in the scissors enlarged significantly and with the heels of both tools perfectly aligned so that the LM pivot fits and the tool clears the lock.
Link: https://forum.multitool.org/index.php/topic,67874.0.html
Reply #109 on: July 30, 2018, 09:01:44 PM
Very nice mods Sam Lim and pomsbz :tu: thanks for posting  :cheers:
Cheers!
Dutch_Tooler
Reply #110 on: July 30, 2018, 09:14:27 PM
Nice mods pomsbz :like: :like: :tu:
Reply #111 on: July 31, 2018, 02:57:57 PM
excellent mods!!!  :like: :like:
My toys:
us Offline Corso
Reply #112 on: August 10, 2018, 04:07:41 PM
Tool Name: Modded Wave and Blast
Basis: Wave and Blast
Aim: Remove small bit exchanger and install awl in both
Mods: Blast was a straight-forward swap, Wave required a little work
Links: https://forum.multitool.org/index.php/topic,78358.0.html
gb Offline BePrepared
Reply #113 on: August 11, 2018, 03:54:16 PM
Toolname: KF4-X
Basis: LM Juices
Aim: To build a KF-4, but add scissors instead of the saw
Mods: Strip down a juices for parts, paint scales
Reply #114 on: August 11, 2018, 03:56:36 PM
Toolname: No name yet
Basis: LM Juices
Aim: To build a "Slim Jim" juice
Mods: Use left over juice  parts from other mods
Reply #115 on: August 11, 2018, 03:57:42 PM
Basis: LM Juices
Aim: To build a bladeless "Slim Jim" juice
Mods: Use left over juice  parts from other mods, and cut down the can opener to make a package opener
us Offline ChopperCharles
Reply #116 on: August 16, 2018, 12:34:31 AM
Toolname: Senior Ouchie (Mr. Pinchy was taken)
Basis: Sheffield A100 clone
Aim: To get rid of useless scissors and duplicate flat driver/bottle opener, which tends to twist when force is applied. Also, to fix looseness of tool.
Mods: Scissors replaced with saw from a Coleman Pro Lock, bottle opener/flat driver replaced with a scraper blade from a Schrade Tough Tool. Lower pivot repaired with a pivot from an old Kobalt tool.
Link: https://forum.multitool.org/index.php/topic,78407.0.html
id Offline jaya_man
Reply #117 on: August 16, 2018, 02:29:35 AM
Toolname: Half-a-Squirt
Basis: Leatherman Squirt PS4
Aim: To salvage remaining usable parts
Mods: Got rid of the broken plier head and file. Fit all remaining tools on one handle
Link:
https://forum.multitool.org/index.php/topic,78289.0.html
« Last Edit: August 16, 2018, 02:30:48 AM by jaya_man »
il Offline pomsbz
Reply #118 on: August 16, 2018, 06:33:39 PM
Basis: LM Juices
That is a really neat tool.
Reply #119 on: September 11, 2018, 10:19:25 AM
Not sure if this is the best place for a reference on tool thicknesses, but might be useful for others planning mods. It could be (much) expanded to cover other tools...
Rebar/Wave/Charge tool thicknesses
Cheers!
Dutch_Tooler
