New Rebar Fan
Nix · 45 · 2364
ph Offline an0nemus
  • I Tool Therefore I Am
Re: New Rebar Fan
Reply #30 on: November 26, 2017, 04:41:05 AM
Thanks! I think this will be a keeper and I'll just sell the regular Rebar  :think:
Re: New Rebar Fan
Reply #31 on: November 26, 2017, 05:17:10 AM
That or do a color swap :whistle:
Congrats on getting one so reasonable as well  :cheers: :like:
« Last Edit: November 26, 2017, 06:28:39 AM by Poncho65 »
ph Offline an0nemus
Re: New Rebar Fan
Reply #32 on: November 26, 2017, 05:57:14 AM
That is do a color swap :whistle:
Great idea! But the Rebar tools arent available here  :(
The black Rebar does come with sticker residue. I hope i can remove it without damaging the black coating too much. I think someone glued a clip
« Last Edit: November 26, 2017, 06:02:06 AM by an0nemus »
00 Offline Dutch_Tooler
Re: New Rebar Fan
Reply #33 on: November 26, 2017, 10:14:58 AM
Nice catch. Had my eye on it as well but the sticker residue put me off... hope it cleans off nicely, good luck :tu:
Cheers!
Dutch_Tooler
ph Offline an0nemus
Re: New Rebar Fan
Reply #34 on: November 26, 2017, 10:30:48 AM
To be honest I didn't see the sticker residue pics when I bid and was surprised that I won. Oh well, I'll call it "character"
nz Offline Syncop8r
Re: New Rebar Fan
Reply #35 on: November 26, 2017, 12:04:44 PM
Nail polish remover is good for removing sticker residue. I have no idea if it will affect the BO though.
EDIT: I mean from price stickers etc though, that indeed looks like glue.
« Last Edit: November 26, 2017, 12:06:07 PM by Syncop8r »
Re: New Rebar Fan
Reply #36 on: November 26, 2017, 02:14:01 PM
Olive oil or mineral oil will melt most sticker residue. WD40 also works great
ph Offline an0nemus
Re: New Rebar Fan
Reply #37 on: November 26, 2017, 02:20:59 PM
Sounds like it will affect the BO coating.... ???
ph Offline an0nemus
Re: New Rebar Fan
Reply #38 on: November 26, 2017, 02:21:38 PM
Will try that....and also boiling the whole MT then scraping off the glue :D
Re: New Rebar Fan
Reply #39 on: November 26, 2017, 03:11:06 PM
I've seen WD-40 work wonders. You may need to soak it in WD-40 for a while, though. And Acetone is a great solvent as well for this kinda sticky stuff. Again, it may need to soak for a bit. Keep in mind that both of those are highly flammable and produce combustible fumes---use in a well ventilated area, away from flames.  :ahhh
ph Offline an0nemus
Re: New Rebar Fan
Reply #40 on: November 26, 2017, 03:14:39 PM
You think Acetone will affect the BO coat, J?  :think:
Re: New Rebar Fan
Reply #41 on: November 26, 2017, 03:50:58 PM
I would try the WD40 first or the olive or mineral oil as some of the other stuff sounds like it would mess with the BO coating :ahhh Boiling it would be safer on the BO coating as well probably :think:
Good luck in getting the glue off it :tu:
ph Offline an0nemus
Re: New Rebar Fan
Reply #42 on: November 26, 2017, 03:56:46 PM
Noted and thanks! For sure I'll post updates here  :cheers:
Re: New Rebar Fan
Reply #43 on: November 26, 2017, 04:45:25 PM
I doubt it. But....I'm not an expert. You could try a little test spot.
I think the oxide coating is a chemical process where the surface of the steel develops an oxide. I don't see that being soluble, because it is bonded. I am sure that the oxide can be worn off with abrasion. Some coatings, like the duracoat-type finished found on some knives, will readily dissolve with acetone or paint stripper. I used to have a BO SOG tool that I'd use as a test subject for you, but I don't seem to be able to find it.....I may have given it away.
But paint stripper may be another easy to use option on that gum. Often it comes as a gel and could just be gooped onto the problem area. Nasty stuff--wear gloves.
If the BO finish does wear off, you might be able to find someone local who does oxide coating or hot bluing (which is essentially an Oxidation process). If there is anyone nearby who repairs firearms, he or she would know someone who does "Hot Bluing".
As a last resort, you could use some "Cold Blue" to restore the black patina to the Rebar. Cold bluing is weakly protective, and often looks uneven, but I kinda like it and have used it to stain some of my knives with carbon steel blades. Cold bluing wears off pretty easily with use, but it's also easy to touch up as you like.
Or......if you wanted a crazy blinged-out Rebar, you could see if somebody could electroplate it with gold. Bet for the money, you could buy 3 or 4 new Rebars, but sometimes you have to do what you have to do.  :rofl:
ph Offline an0nemus
Re: New Rebar Fan
Reply #44 on: November 26, 2017, 04:48:52 PM
Wow. As in wow. So many gems of info there to digest, and options to pursue! Whatever happens, I think I will have a pretty unique Rebar to end up with
Total Receipts: $55.09
PayPal Fees: $3.15
Net Balance: $51.94
Below Goal: $248.06
17%
